Speed Records around FAI triangles
Old April 27th 09, 03:27 AM posted to rec.aviation.soaring
Default Speed Records around FAI triangles
Does anyone have a internet reference for FAI rules for speed records
around FAI triangles? Specifically to set speed records around FAI
triangles do the turn points have to be declared in advance? Is there
a requirement for the start and finish to be less than 1000 meters
above the ground?
Bill Snead
Old April 27th 09, 04:40 AM posted to rec.aviation.soaring
Darryl Ramm
around FAI triangles? *Specifically to set speed records around FAI
triangles do the turn points have to be declared in advance? *Is there
above the ground?
Bill Snead
Read the FAI sporting code. Section 3. http://www.fai.org/gliding/sc3.
Actually read it many times.
Yes you need to declare the triangle. Which means you need to declare
the turnpoints. Now wether you declare the start and finish is a
different question.
If you don't declare a start and do a start off tow you need to finish
within 1,000m laterally of the finish to be considered a closed
course, and since your undeclared finish will be by landing you then
have also introduced the unneeded complication of not being able to
start off tow more than 1,000m above your landing point. But why do
that? You would normally either declare a start/finish point and two
waypoints or less likely declare a three waypoint triangle with remote
start finish - this might be done for also capturing other flights
claims withing the same flight. With a declared start/finish, all you
are watching is the 1,000m total loss of height during the task and
forget anything about height above ground (except just worry about
staying above ground during the flight...).
You also need to get the FAI triangle distance and ratios correct for
a record flight. See SC3.
There are many more things to worry about, these questions indicate
you likely need to read SC3 a few more times and then you'll be able
to come up with some really good questions to worry about. :-)
Darryl
Old April 28th 09, 12:25 AM posted to rec.aviation.soaring
[email protected][_2_]
above the ground?
Bill Snead
Read the FAI sporting code. Section 3.http://www.fai.org/gliding/sc3.
different question.
Darryl
thanks for the help. I will read the rules.
Bill
New Records in Arizona Mike the Strike Soaring 2 June 15th 07 07:50 PM
STC records at FAA [email protected] Owning 6 April 2nd 05 04:01 PM
B-1B speed records ratified by FAI Paul Hirose Military Aviation 0 May 11th 04 03:12 AM
World Records Nick Gilbert Soaring 2 February 26th 04 06:43 PM
B-1 sets speed records at air show Paul Hirose Military Aviation 0 November 1st 03 02:32 AM
