antenna dilemma
In article bikensoar writes:
On May 25, 5:57=A0pm, Brad wrote: My buddies tell me my handheld is too painfull to listen to anymore. I would put in a panel mount, but since I have a mostly carbon aircraft, where should I put the antenna? Too late to install it in the rudder, or is there a solution that would allow me to install one in the rudder?? I think the main issue with the handheld, is line-of-sight from the antenna to who I am talking to, it works fine when the aircraft is pointing towards them, or they are on the side of the glider the radio is on, but as I turn (while thermalling) I am told the transmissions cut out. Any thoughts on this? Thanks, Brad Brad, The all carbon Sparrowhawks have a little external antenna on the bottom of the fuselage, just behind the main gear. It can be twisted off and removed similar to a handheld antenna. It works very well. George (yes old, but antennas came up again recently) I would think that an antenna sticking *down* is a poorer choice than one sticking up from the top of the aircraft. Down does pretty poorly when on the ground, and is at extra risk of damage. Has anyone measured the drag from a simple 1/4 wave wire monopole sticking up from the aircraft? Alan |
Similar Threads | ||||
Aviation Dilemma 101 - How much trust in a 10 day forecast?? | Kyle Boatright | Piloting | 25 | July 22nd 06 12:52 PM |
More on Fuel Management - and an Ethical Dilemma | Greg Farris | Instrument Flight Rules | 46 | July 22nd 05 06:38 PM |
More on Fuel Management - and an Ethical Dilemma | Greg Farris | Piloting | 47 | July 22nd 05 06:38 PM |
Briefing Dilemma | Kyle Boatright | Piloting | 15 | February 7th 05 07:10 PM |
Small dilemma...YES, this is true.... | Halen19717 | Piloting | 12 | December 2nd 04 01:12 PM |
