Fixing a camera externally
Is there any simple way to fix a small self-contained "web-camera" to the
wing or tail of my glider? I have a Tony Hawks Helmet Cam, designed really for skateboarding, and I've worn it or affixed inside the cockpit a few times, but so far held off affixing outside. Tape would have seemed the best bet, but a little nervous it may damage the fibre-glass body when I pull it off, or it will fall off! Neil |
WARNING: None of this is something that the FAA condones and may be
downright illegal. If the ship is "experimental" then you may have more leeway. A few comments; 1) The AV industry always use "gaffers" tape to affix things. This stuff is very good at keeping things stuck while still coming off cleanly. Think of this as really good cloth "duct" tape with a price to match. 2) Most external cameras I now see being used are "lipstick" cameras which are very small and have a much lower wind loading. These are small enough to be directly taped to the wing, tail, etc. They also have smaller lenses so they are less likely to get a bug in the face. They have video out so a cable must be routed back into the cockpit to a device to record the video. 3) Non-lipstick cameras have also been used. The advantage is that they are self contained cameras plus recorders. Anchoring is typically done by using a large-ish aluminum plate which wraps around the leading edge (wing or tail) and is held in place with gaffers tape. 4) Asymetrical wind loading by putting a large camera way out on a wing tip is something to avoid. 5) Don't' do this if there is even a hint of rain as this will distroy the camera in a hurry. - John |
On Aug 6, 5:22 pm, "Neil" wrote:
Is there any simple way to fix a small self-contained "web-camera" to the wing or tail of my glider? I have a Tony Hawks Helmet Cam, designed really for skateboarding, and I've worn it or affixed inside the cockpit a few times, but so far held off affixing outside. Tape would have seemed the best bet, but a little nervous it may damage the fibre-glass body when I pull it off, or it will fall off! Neil Have one of these guys hold it for you. http://alto.nethit.fi/blanik/137.jpg http://alto.nethit.fi/blanik/122.jpg http://alto.nethit.fi/blanik/132.jpg Caution, don't blow beer through your nose onto your keyboard. |
On Aug 7, 2:48 pm, Frank Whiteley wrote:
On Aug 6, 5:22 pm, "Neil" wrote: Is there any simple way to fix a small self-contained "web-camera" to the wing or tail of my glider? I have a Tony Hawks Helmet Cam, designed really for skateboarding, and I've worn it or affixed inside the cockpit a few times, but so far held off affixing outside. Tape would have seemed the best bet, but a little nervous it may damage the fibre-glass body when I pull it off, or it will fall off! Neil Have one of these guys hold it for you. http://alto.nethit.fi/blanik/137.jpg...blanik/132.jpg Caution, don't blow beer through your nose onto your keyboard. Or this guy http://aeroklub.bialystok.biz/myegal...rderby=d ateD |
Have one of these guys hold it for you. http://alto.nethit.fi/blanik/137.jpg http://alto.nethit.fi/blanik/122.jpg http://alto.nethit.fi/blanik/132.jpg I'd have to admit, John's idea about gaffer tape was more in line with my thoughts. I'd just worry about wing-drop on launch with one of these guys. ;-) Neil |
On Aug 8, 5:13 pm, "Neil" wrote:
Have one of these guys hold it for you. http://alto.nethit.fi/blanik/137.jpg http://alto.nethit.fi/blanik/122.jpg http://alto.nethit.fi/blanik/132.jpg I'd have to admit, John's idea about gaffer tape was more in line with my thoughts. I'd just worry about wing-drop on launch with one of these guys. ;-) Neil Lipstick cams are a good way to go, but they also require power. Not sure of if the little wireless links will do a good job with 520 lines so a wire feed is likely best. Mini-DV tape may be best if going above 10000ft msl. Most HDD devices are only rated to about there. IIRC, there is a Fujitsu drive rated to 10000M but may not fit. No idea if mini-DVD works at altitude. Try a search for Blanik Boogie on YouTube. Not for everyone, but an interesting departure. Frank |
Frank Whiteley napisaĆ(a):
Try a search for Blanik Boogie on YouTube. Not for everyone, but an interesting departure. Here you can see my movie http://pl.youtube.com/watch?v=xYKELWybDc4 Not a Blanik but also starts with B Bocian skydive regards -- --=JJay=-- www.aeroklub.deblin.pl, my photos on airliners.net - http://tiny.pl/rcwl |
On Aug 6, 6:22 pm, "Neil" wrote:
Is there any simple way to fix a small self-contained "web-camera" to the wing or tail of my glider? I have a Tony Hawks Helmet Cam, designed really for skateboarding, and I've worn it or affixed inside the cockpit a few times, but so far held off affixing outside. Tape would have seemed the best bet, but a little nervous it may damage the fibre-glass body when I pull it off, or it will fall off! Neil Many years ago, I mounted a simple fixed-focus 35mm camera on a home- made contraption that I clamped to the spike that protrudes from the nose of a 2-33. The camera was triggered by a piece of choke cable threaded through the air vent, emerging from the panel right in front of the stick. The camera was pointed straight back, and so I got a picture of my smiling face through the front of the canopy. These little cameras have fairly wide-angle lenses, so the view includes a few feet of wing on each side, and a little sky above and ground below. Just in case this wasn't quite in accordance with the letter of the FARs, no evidence survives except the photo itself, which I am prepared to say was Photoshopped. By someone else. Someone I never met. OK? p. |
"Paul" wrote in message ps.com... Many years ago, I mounted a simple fixed-focus 35mm camera on a home- made contraption that I clamped to the spike that protrudes from the nose of a 2-33. Along the same lines... There is a little thumbscrew/wedge gizmo that you can buy at most any hardware store that is intended as a home window security lock. One or two of those things will clamp to that top spine on a Blanik fuze and will hold a light camera just fine without puting a scratch on the glider. Just in case this wasn't quite in accordance with the letter of the FARs, no evidence survives except the photo itself, which I am prepared to say was Photoshopped. By someone else. Someone I never met. OK? I don't remember who it was that mounted the camera on the Blanik, or when or where it happened...Honest! Vaughn |
Similar Threads | ||||
Fixing brackets to new house walls | Michael Baldwin, Bruce | Products | 26 | January 18th 07 03:11 AM |
Fixing brackets to new house walls | Michael Baldwin, Bruce | Products | 0 | January 3rd 07 05:26 AM |
Fixing screw holes in fabric | Brian Huffaker | Home Built | 4 | May 21st 05 02:16 AM |
Tu-22M3 Backfire-C Fixing the Esci Kit | Ken Duffey | Military Aviation | 1 | December 11th 03 11:23 PM |
The joy of fixing 'repairs' | Michael | Owning | 3 | November 6th 03 05:47 PM |
