Condor2, inbound on final glide!
Old February 12th 18, 03:06 AM posted to rec.aviation.soaring
sisu1a
Default Condor2, inbound on final glide!
https://www.facebook.com/CondorSim/
Condor2 is finally here/around the corner. The new site is up, the old forum imported to the new one, and the store is up (buy links not active yet but prices are there)
http://www.condorsoaring.com/order/?cn-reloaded=1#
http://www.condorsoaring.com/forums/ (old forum towards bottom, threads still active)
Yay!
Old February 12th 18, 12:11 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Yay!
You beat me to it my friend
Chris Wedgwood
Condor Team
Here's the 'what's new' from the webpage:
What’s new in Condor 2
Graphics engine:
Rendering code completely rewritten to DirectX 11, allowing extensive use of GPU shaders (vs DirectX 7 of Condor 1 with fixed pipeline rendering)
Screen resolution limited only to hardware (vs max 2048 in Condor 1)
Fullscreen ALT-TAB functionality is now supported (vs. full screen switching not supported in Condor 1)
Weather model:
Many improvements to thermal model (higher cloud base, thicker clouds, streeting, flatlands activity)
Completely new Cu cloud model, much less strain on the GPU and more realistic lighting, will enable much bigger clouds (2.x version)
Improved ridge lift model
A new high level wind speed setting with wind speeds up to 100 km/h (vs.. no high level wind setting and wind speeds of max 50 km/h in Condor 1)
Completely rewritten wave lift with multiple waves and lenticularis clouds (vs. single wave and no lenticularis clouds in Condor 1)
Adjustable cirrus density (vs static in Condor 1)
Multiplayer:
64 planes or more in MP with better (smarter) plane position data exchange (vs max 32 planes in Condor 1)
Automatic port forwarding (vs manual NAT setup in Condor 1)
Flight physics model:
Improvements to flight physics model
Nicer plane handling
Scenery rendering:
30 m resolution scenery, internally 22.5m (vs 90 m in Condor 1)
Default scenery texture size is 2048 (vs 512 in Condor 1, that is 16x more texture data)
Much lower terrain texture memory footprint despite higher texture resolution
Much denser forests with real size trees and more accurate tree placement (vs less dense forests with 3x too big trees and 16x worse tree placement in Condor 1)
Multithreaded terrain loading which loads terrain tiles much faster (vs.. single threaded terrain loading in Condor 1 which would now take 8+ seconds if not multithreaded)
Water is “alive” with sun reflections and waves (vs static texture in Condor 1)
Sky and shading:
New sky model with more realistic sunrise/sunset effects
Exponential (realistic) haze (vs linear haze in Condor 1)
Cu clouds cast shadows depending on the sun position (vs shadow always vertically below cloud in Condor 1)
Lenticularis clouds cast shadows on ground and planes
New sun and flares model, sun is hidden behind objects, flares disappear (vs. sun and flares always ON even if behind an object in Condor 1)
Realtime scenery lighting and shadows, mountains cast shadows (vs. static texture shadows in Condor 1)
Trees, planes, airports and all ground objects lighted from sun and shadowed from mountains and clouds (vs. static color in Condor 1)
All ground objects cast shadows (vs no shadows in Condor 1)
Realtime self shadowing of planes in cockpit and outside (vs. no self shadowing in Condor 1)
Specular highlights on planes and other objects (vs no specular highlights in Condor 1)
Planes:
Much higher poly count of planes (exterior and cockpit)
3D instrument models (vs 2D textures in Condor 1)
Reflections of pilot on instruments (vs no reflections in Condor 1)
New, high poly and high resolution texture pilot model
Completely new wing bend model, wings now have inertia (vs. no inertia in Condor 1)
New animation for hand to see wris****ch which is animated
Rotating wheels on planes (vs static wheels in Condor 1)
Improved high/low G effects
Airports:
Completely redesigned airport rendering with high resolution asphalt and grass textures (vs. low resolution textures in Condor 1)
Scenery designer controlled placement of windsocks. Multiple windsocks per airport are allowed, with adjustable size (vs. 1 windsock with generic placement in Condor 1)
Much higher poly count and higher resolution airport objects
Other:
New, higher resolution GUI
High resolution flighttrack logging (vs. low resolution in Condor 1)
Right button mouse “zooming” allows camera placement almost everywhere (vs static distance camera in Condor 1)
Moved all user files (flighttracks, flightplans etc) to documents\Condor folder (vs “virtualstore” issues in Condor 1)
Revised registration and verification to eliminate installation counter problems
Many other improvements (variable tow rope length etc.) …
Old February 12th 18, 03:12 PM posted to rec.aviation.soaring
kirk.stant
Yay!
VR support? Once you fly a sim in VR, it's hard to go back to a screen!
Kirk
66
Old February 12th 18, 03:26 PM posted to rec.aviation.soaring
Matt Herron Jr.
Yay!
What is the pricing? Can't seem to find it. Any upgrade path?
Old February 12th 18, 03:46 PM posted to rec.aviation.soaring
I wish these guys would hurry up and take my money.
I've been looking forward to this for quite some time.
Matt
Old February 12th 18, 07:16 PM posted to rec.aviation.soaring
Dan Stroschine
Yay!
And for those that want to get a start on creating scenery you can download the manual in the downloads section.
Old February 12th 18, 10:24 PM posted to rec.aviation.soaring
Chris Wedgwood[_2_]
This evenng I uploaded the Condor Landscape Toolkit for Condor 2, so landscape developers can get going.
We've had a few developers running with us through beta, so there are some projects in the pipeline already
Chris
Condor Team
Old February 13th 18, 01:17 AM posted to rec.aviation.soaring
Chris
Condor Team
Congrats on Condor 2 Chris, I'm sure it will be fantastic. Can you recommend a joystick? What are the current favorites?
Old February 13th 18, 12:31 PM posted to rec.aviation.soaring
Chris Wedgwood[_2_]
We do prefer Force feedback joysticks, and the only decent one is the old Microsoft force feedback 2. Discontinued over 10 years ago..
You can still find good examples on eBay.
Chris
Condor Team
Old February 13th 18, 04:10 PM posted to rec.aviation.soaring
I would like to take some credit for the recent release of Condor2.
After working on it for nearly two years (not steadily), I recently published a Condor Orientation document to my website, gliderCFI.com. The orientation, while not everything there is to know about Condor, is a compilation of everything I have learned about the software over the last 8 years as I have levered its features and capabilities to improved glider flight training.
As a disciple of Murphy, I firmly believed the instant I completed my work, based on Condor version 1.1.5, the Condor guys would announce the new release, likely rendering my work obsolete. And so it came to pass, at least the release timing.
To all of you who have waiting so patiently for this day, you are welcome.
This is however some evidence here that Murphy may be getting a little soft.. After a quick read through the Condor2 manual, it would appear that much of what I have documented about the software may still be true, so my labor may not have been entirely in vain.
If you are interested, my orientation document is available (as are all my Version 1.1.5 training resources) at no charge, from my website. Follow the drop-down menu under "Condor" or use the link below.
http://glidercfi.com/condor/orientat...tion-document/
Congratulations to the entire Condor2 team, and thank you for all you have done to produce a truly amazing simulation of soaring flight.
Sincerely,
Scott Manley - 3167160CFI
a.k.a. The Condor Guy
Clarence See....final glide Gregg Leslie[_2_] Soaring 2 December 27th 12 09:52 PM
Final glide ppp1 Soaring 8 January 6th 11 02:21 PM
Final Glide Roy Clark, \B6\ Soaring 1 December 23rd 10 04:45 PM
Final Glide - JD (US) Roy Clark, B6 Soaring 1 September 19th 07 07:17 AM
AC Williams -Final Glide [email protected] Soaring 4 January 23rd 06 04:52 AM
Copyright 2004-2024 AviationBanter.
