Intercom Problem with New Radio
Old May 27th 07, 12:32 PM posted to rec.aviation.owning
Steve - KDMW
Default Intercom Problem with New Radio
I had my old Narco COM 120 replaced with a new Garmin SL40 and now
when the new radio is turned on my intercom volume drops by at least
half. Anyone seen this before? It has the avionics shop baffled. I
have an SPA 4000 intercom and a King KA-134 audio panel. I looked on
the Bendix website and I see a notice in their manual's list for a
"blocking diode for audio muting" installation but I can't get the
manual without a dealer login. I wonder if that has any relevance.
Anyone come across this before?
Steve
KDMW
PA28-151
Old May 28th 07, 04:28 AM posted to rec.aviation.owning
mikem
half.
Steve, coupla questions?
Is the "HEADPHONE" OUTPUT of the SL40 wired into a COM1 or 2 INPUT on
the Audio Panel?
Is the OUTPUT of the audio panel wired to the SPA400 INPUT?
Is the SPA OUTPUT tied to the aircraft headphones?
Have you defeated the built-in intercom inside the SL40?
Did everything work right before the SL40 install? (All the installer
should have had to do was wire the SL40 headphone out to the whereever
the previous COM was wired)
It sounds like they may have tied two OUTPUTs together, which with
modern avionics is a no-no. Even though the headphone audio is
nominally at 500 Ohms impedance, the OUTPUT impedance of the headphone
amplifier inside the SL40, and the one inside the audio panel are
really a voltage source with VERY LOW output impedance, and two of
these cannot be tied together ( and there is actually no reason to tie
them together) without using series resistors, otherwise they will
fight each other, sort of like your symptoms.
Old May 28th 07, 04:39 AM posted to rec.aviation.owning
mikem
On May 27, 9:28 pm, mikem wrote:
I forgot to mention, I have a KX155, SL40, KMA24, SPA400, and other
stuff, and it all works perfectly. I have the SL40 interfaced to a
Garmin 496, and can load the SL40 standby frequency from the 496...
Old May 28th 07, 06:09 PM posted to rec.aviation.owning
Steve - KDMW
half.
the Audio Panel?
Thanks for your suggestions. The COM 120 was wired to the COM 2 input
of the audio panel (KMA-134), and the audio panel output wired to the
SPA-4000. I believe the shop just removed the COM 120 and wired the
SL40 in it's place, so it should still be the same. I haven't noticed
anything different or unusual, i.e. if I select COM 2 I only hear COM
2.
I didn't check the intercom mode of the SL40. I'll do that.
Old May 28th 07, 06:36 PM posted to rec.aviation.owning
RST Engineering
You really need to be quite specific when you make statements like this.
What lead/terminal/connection of the COM-120 was wired to which lead/... of
the audio panel? Audio panels will generally have two inputs, speaker and
phones. Each is terminated differently and are quite different
electrically. Was this the only connection between the COM 120 and the
audio panel or were the mic audio and key lines also connected? Did they do
an exact wire-for-wire swap or did they do some other mickey motion with the
new radio installation?
SPA-4000.
Again, specifics please. Was the audio panel output wired to an input on
the intercom or were the two outputs paralleled?
2.
So how does "the shop" explain it? You paid good money for an installation
and you didn't get it. Can they explain it away to you?
That's a possiblity if the SL40's intercom is inverted in phase to the
intercom's output.
You say the intercom volume drops in half when you turn on the SL40. Is it
just turning on the power or do you have to have both transmit and receive
selected to the SL40 before the volume drop occurs?
Old May 29th 07, 01:30 PM posted to rec.aviation.owning
Steve - KDMW
SPA-4000.
2.
intercom's output.
Jim,
I haven't delved that deeply into the wiring (yet) because the shop
has told me that they will get me back on their schedule to bring it
in and they will make it right. They have a pretty good reputation, so
I'm not too worried yet (Penn Avionics at Brandywine airport near
Philly). If I hit a wall, I will pull out my multimeter and dive in
and make it right myself if I have to (and then never use that shop
again).
To answer your questions that I can answer right now...
They indicated that they did an exact wire-for-wire swap with the COM
120. The intercom volume drops as soon as you turn the SL40 on. You
don't have to be transmitting or receiving for the problem to occur.
Steve
Old May 30th 07, 03:42 PM posted to rec.aviation.owning
mikem
Steve
When the SL40 is powered up, the feedback around its audio output
amplifier becomes active, creating a very low- output impedance. If
this is paralled with something it shouldn't be, then this is what
caused the audio level to drop.
This leads me to believe that the headphone COM120 output was NOT
wired to the isolated summing input on the audio switching panel as it
should have been. AFIK, Narco products have an internal resistor in
series with the headphone output, which might prevent the volume drop
even as wired.
A half-assed fix would be to insert a series 100 Ohm resistor in the
wire coming from the SL40 headphone output. A better fix would be to
trace out where that wire actually goes...
Old May 30th 07, 04:12 PM posted to rec.aviation.owning
Steve - KDMW
Steve
even as wired.
Excellent suggestion. I'll ohm it out. According to my diagrams, pin
14 of the SL40 (headphone) should read to pin D of the KA-134 (Com 2
Audio In).
Old May 30th 07, 04:54 PM posted to rec.aviation.owning
RST Engineering
Agreed. Good place to start.
"mikem" wrote in message
should have been.
Old June 2nd 07, 12:03 AM posted to rec.aviation.owning
Steve - KDMW
On May 30, 11:54 am, "RST Engineering"
should have been.- Hide quoted text -
- Show quoted text -
OK. Well, I ohmed out the wiring and found nothing unusual. The SL40's
headphone output was wired to the KA-134's Com 2 Audio In (and nowhere
else). I checked to see that it was not paralleled (shorted) to any
other inputs. All of the grounds read properly, i.e. to ground, and
nothing shorted to ground that shouldn't be.
The one thing I have not checked yet is to make sure that the radio
goes only to the audio panel, and not paralleled to the intercom. Only
the audio panel output should go to the intercom. I don't believe
there is a problem there or it would seem that I would always hear the
Com 2 radio regardless of audio panel selection. But I'll check it out
anyway.
Another tidbit of info. The intercom comes back to normal if the
Garmin radio is on and not selected. It doesn't load down the intercom
simply by virtue of being on, it has to be on and selected.
Still waiting for the shop to get back to me with their suggestion.
Maybe the 100 ohm resistor on the radio's headphone output is the way
to go. Also, I'll be going to the AOPA fly-in tomorrow and I'll pick
the brains of the avionics shop's booths and Garmin's reps.
more than 1 radio with Sigtronics Sport 200 S Two Place Intercom John Foreman Home Built 1 December 21st 06 07:24 PM
Garmin 496-XM Radio-PS Engineering Intercom Follow up... Jay Honeck Owning 25 December 9th 06 12:26 PM
Good panel mount COM radio and intercom w/push-to-talk? John Huebbe Home Built 10 November 27th 04 07:58 PM
FS Helmets, Intercom, Radio [email protected] Aviation Marketplace 0 April 17th 04 04:40 PM
Intercom Audio Input and Satellite Radio John Golovich Owning 5 August 7th 03 10:00 AM
