What to use to make a mold?
Old March 23rd 09, 12:23 AM posted to rec.aviation.soaring
AK
Default What to use to make a mold?
I want to make a small mold I would later use to create a fiberglass
container to hold lead weight. It would be nice if mold material can
withstand 500 degrees Fahrenheit so I can pour lead into it and then
cover it by fiberglass. Alternatively I would use the mold to create a
fiberglass container first and fill it up with lead pellets. So my
question is what do I use to make a mold, gypsum if so what kind,
anything else?
Andrzej
Old March 23rd 09, 12:37 AM posted to rec.aviation.soaring
sisu1a
container to hold lead weight. It would be nice if *mold material can
anything else?
Andrzej
High temp RTV rubber can withstand up to 1000deg F. It's not cheap
stuff, but it will work quite nicely...
If you use gypsum or plaster products, just make two molds, (after
your first mold is made make a male model from it to cast new females
off of...) as it would be difficult to get out your lead w/out
breaking it, assuming it survives the thermal shock of the pour. Heat
up your plaster mold in an oven to within 100deg of your pour first to
avoid that pitfall, but you must very slowly heat the plaster up since
it may have micro water in pores that will superheat and make it crack
as the steam exits. Take at least 4 hrs to bring your mold up to temp
(after 24 hrs minimum cure) , ramping up 100deg/hr until at
400ish... plaster is cheap and easy to work with, so it will
probably be most practical. note-plaster expands 1-3% when cured, so
take this into account for allowances if you have critical tolerances.
If you need precision plaster/gypsum there is a product called
Ultracal (in 30 or 60 minute cure versions) made by US gypsum that
does not expand or shrink. it's cheap enough to use too at like
$30/50# . It feels and mixes just like plaster of paris but is
gypsum based so it cures like cement. Phenomenal product actually...
There's always the option to just trap your lead shot in epoxy
thickened with cabosil or microballoons etc, which seems much easier
but will obviously not provide the same density as a solid block...
-Paul
Old March 23rd 09, 02:01 AM posted to rec.aviation.soaring
Eric Greenwell
It does avoid the breathing of lead vapors, something even a pilot
should avoid.
* "Transponders in Sailplanes" http://tinyurl.com/y739x4
* Sections on Mode S, TPAS, ADS-B, Flarm, more
Old March 24th 09, 04:18 PM posted to rec.aviation.soaring
The Real Doctor
On 23 Mar, 02:01, Eric Greenwell wrote:
should avoid.
Is the sublimation rate of lead at room temperature significant?
Church roofs seem remarkably resistant to evaporation after hundreds
of years, as do the 120 year old lead water pipes in my house.
Ian
Old March 23rd 09, 02:30 AM posted to rec.aviation.soaring
Steve Leonard[_2_]
For a single pour mold, you can even carve it out of wood, like a 2 by 4.
It will smoke, burn the wood (you can blow out the fire), but it will hold
up for a single lead weight making. How heavy a weight are you trying to
make? And about how big?
You could then make the glass cup from the lead part, or even from a block
of foam that you cut to about the same shape.
A friend once got in trouble with his wife by using one of her frying pans
to make lead disks for putting in the seat pan of our old club two place!
One thing to watch out for (may not be this way with the gypsm stuff that
Paul mentioned), but anything that used water in its making, can trap
water inside. Put molten lead in it, and it can be a bad thing.
Happy slug making!
Steve Leonard
Old March 23rd 09, 07:45 AM posted to rec.aviation.soaring
Ian Burgin
hold
to
block
pans
place!
that
Happy slug making!
Steve Leonard
Lead has a melting temp of about 500 degrees C commercial moulds for
casting batches are usually cast iron as are some pans.
If you make a mould using sheet steel this would then encapsulate the lead
after pouring and prevent the soft lead from deforming under pressure from
the fastening bolts.
Old March 24th 09, 04:24 PM posted to rec.aviation.soaring
The Real Doctor
On 23 Mar, 07:45, Ian Burgin wrote:
Lead has a melting temp of about 500 degrees C ...
It might be worth thinking about using plumber's solder instead. It's
a lead-tin eutectic alloy, which means it melts at a significantly
lower temperature (183 degrees C), but still has a high density (84%
that of lead).
Ian
Old March 24th 09, 11:20 PM posted to rec.aviation.soaring
AK
On Mar 24, 12:24*pm, The Real Doctor
that of lead).
Ian
Do you know of good source for this alloy (I don't know if I want to
go to Radio Shack to buy 40 lb of solder? My wallet would be way too
light and then I would have to buy even more of the alloy.
Old March 25th 09, 02:59 PM posted to rec.aviation.soaring
The Real Doctor
that of lead).
Builders' merchants used to sell it by the kilogram, but it's banned
or about to be banned for domestic use so may be harder to find in the
UK now. Dunno about where you are.
Ian
Old March 23rd 09, 03:28 PM posted to rec.aviation.soaring
anything else?
Andrzej
sand
Lyc IO-540 won't make RPM. [email protected] Owning 12 December 14th 06 10:21 PM
How did he make this joint? Michael Horowitz Home Built 4 September 16th 05 06:14 PM
Fiberglass / Mold release advice requested Mark Zivley Home Built 10 April 2nd 04 11:15 PM
How much does a CFI make? Peter Gibbons Piloting 27 August 17th 03 02:48 AM
$$$'s make right? Sydney Hoeltzli Piloting 9 July 15th 03 04:54 AM
