Skin repairs on a Schroeder type trailer
I've got a trailer that was damaged a few years back when a load of
snow slid off the roof and landed right on the skin. About 5 of the fiberglass ribs are broken and the skin is fractured, split and generally ripped apart in a few areas. Has anyone got some idea about how to repair the broken skin? I can easily make new ribs, but the skin looks a bit challenging to repair. Maybe replacing the broken sections with pre-cured laminated sheets is the way to go? Any thoughts would be appreciated................heck, I guess if I can build a glider I can repair a busted trailer top! Thanks, Brad |
On Dec 30, 6:06*pm, Brad wrote:
I've got a trailer that was damaged a few years back when a load of snow slid off the roof and landed right on the skin. About 5 of the fiberglass ribs are broken and the skin is fractured, split and generally ripped apart in a few areas. Has anyone got some idea about how to repair the broken skin? I can easily make new ribs, but the skin looks a bit challenging to repair. Maybe replacing the broken sections with pre-cured laminated sheets is the way to go? Any thoughts would be appreciated................heck, I guess if I can build a glider I can repair a busted trailer top! Thanks, Brad Did one of those a few years ago- Yep snow made shed fall on it. We made replacement bows from 3/4 EMT and bonded them in next to damaged bows. Much less work than making a form to do proper repair on fiberglass bows. Skins will be a bit of a problem because they are probably brittle and it will be a challange to get stuff to go to contour. We only had a few minor repairs. I'd suggest premaking flat skin using 3 layers of 92110 bid and bonding to the inside. If there is a good straight section, you could just lay some plastic on it and laminate skin pre bent. Good Luck UH |
On Dec 30, 8:55*pm, wrote:
On Dec 30, 6:06*pm, Brad wrote: I've got a trailer that was damaged a few years back when a load of snow slid off the roof and landed right on the skin. About 5 of the fiberglass ribs are broken and the skin is fractured, split and generally ripped apart in a few areas. Has anyone got some idea about how to repair the broken skin? I can easily make new ribs, but the skin looks a bit challenging to repair. Maybe replacing the broken sections with pre-cured laminated sheets is the way to go? Any thoughts would be appreciated................heck, I guess if I can build a glider I can repair a busted trailer top! Thanks, Brad Did one of those a few years ago- Yep snow made shed fall on it. We made replacement bows from 3/4 EMT and bonded them in next to damaged bows. Much less work than making a form to do proper repair on fiberglass bows. Skins will be a bit of a problem because they are probably brittle and it will be a challange to get stuff to go to contour. We only had a few minor repairs. I'd suggest premaking flat skin using 3 layers of 92110 bid and bonding to the inside. If there is a good straight section, you could just lay some plastic on it and laminate skin pre bent. Good Luck UH On old friend of mine, Steve Bowen, had the same thing happen. He found a source of a fiberglass panel and replaced the complete top. The last I knew he was in the Winona, Minnesota area. Perhaps he reads RAS. |
Thanks to all for your suggestions! At first I was going to buzz the
top off and make a metal clamshell top. Spent a few weeks designing the top and making sure everything fit inside ok. Actually had something that looked really good. However, upon reflection, and the fact that I don't have unlimited time and money, I think I'll just repair what I've got now. Will let you know how it goes! Brad hpaircraft.com |
On Dec 31, 3:06*pm, Brad wrote:
Thanks to all for your suggestions! At first I was going to buzz the top off and make a metal clamshell top. Spent a few weeks designing the top and making sure everything fit inside ok. Actually had something that looked really good. However, upon reflection, and the fact that I don't have unlimited time and money, I think I'll just repair what I've got now. Will let you know how it goes! Brad hpaircraft.com We thought about the clamshell idea and decided the time was better spent on the glider going in it. Interesting how the thinking follows the same pattern. HNY UH |
Similar Threads | ||||
TM6 repairs in the UK | Ian Johnston | Soaring | 2 | January 21st 06 10:26 PM |
COBRA Skin Trailer Protector - Commercial | John Seaborn | Soaring | 0 | July 20th 04 04:38 PM |
flight navigator3.0 Helga Schroeder | [email protected] | Piloting | 0 | January 28th 04 05:08 PM |
flight navigator3.0 Helga Schroeder | [email protected] | Piloting | 0 | January 28th 04 05:00 PM |
1894 Driggs-Schroeder 6 pdr surviving | old hoodoo | Naval Aviation | 8 | December 2nd 03 11:28 PM |
