In-Flight Engine Failure
Well, it happended. I have owned the plane (Piper Turbo Arrow III) for
3 months and the engine failed during climb out on Tuesday. Altitude was 4400 feet. Luckily, the engine did not entirely quit and I made it to an airport within 10 miles. TBO was 1000 hours away. Dissapointing! When we cut the oil filter, it was full of fairly large aluminum and steel bits of metal. Arg! (1) Upon examination, the wire into the left magneto was found to be broken off, just at its connection to the magneto. A mechanic theorized that it could have grounded to the magento housing. He said that that could have actually caused a grounding of both magnetos and could have fouled up the engine firing, and could have contributed to the failure. Later, he said that he thought that it was just a coincidence that the left mag wire happened to have been broken when the engine failed due to some other reason. What do you folks think? Could the two have been tied togehter? (2) Now I am faced with having to have the engine overhauled. Growl! The engine has brand new cylinders on it (well, they have about 100 hours on them) put on by the previous owner. So, I think we want to do a custom overall of this particular engine. Does that make sense? Are there different places who do this sort of thing with different reputations for quality of work? If so, I would like to hear about recommendations (the engine is a TCM TSIO-360-FB) or perhaps criteria to use in making a judgement. Also, are there different quality parts or methods in doing the overhaul that are options that I need to specify when I ask for the overhaul. In other words, if I can pay 10% more and get more reliability, then I might like to have the option to do that...but often, you have to be knowledgeable enough to ask for the right things. |
O. Sami Saydjari wrote:
Well, it happended. I have owned the plane (Piper Turbo Arrow III) for 3 months and the engine failed during climb out on Tuesday. Altitude was 4400 feet. Luckily, the engine did not entirely quit and I made it to an airport within 10 miles. TBO was 1000 hours away. Dissapointing! Way to go. I had a similar engine failure once and was able to make a nearby airport under partial power with mucho vibration. It's an unforgettable experience. When we cut the oil filter, it was full of fairly large aluminum and steel bits of metal. Arg! (1) Upon examination, the wire into the left magneto was found to be broken off, just at its connection to the magneto. A mechanic theorized What wire, the P-lead? that it could have grounded to the magento housing. He said that that could have actually caused a grounding of both magnetos and could have fouled up the engine firing, and could have contributed to the failure. Seems kinda far-fetched. Later, he said that he thought that it was just a coincidence that the left mag wire happened to have been broken when the engine failed due to some other reason. What do you folks think? Could the two have been tied togehter? I don't want to say it's impossible, but it seems unlikely to me. What do I know? Suppose the magneto could have come loose and spun around, breaking off the wire, causing gross ignition mistiming and detonation, and leading to the failure? I dunno, I'm just brainstorming. (2) Now I am faced with having to have the engine overhauled. Growl! The engine has brand new cylinders on it (well, they have about 100 hours on them) put on by the previous owner. So, I think we want to do a custom overall of this particular engine. Does that make sense? Are there different places who do this sort of thing with different reputations for quality of work? If so, I would like to hear about See if you find a copy of "The Major Overhaul", by Kas Thomas. It's out of print. You might contact Kas himself and ask him where to get a copy. recommendations (the engine is a TCM TSIO-360-FB) or perhaps criteria to use in making a judgement. Also, are there different quality parts or methods in doing the overhaul that are options that I need to specify when I ask for the overhaul. In other words, if I can pay 10% more and get more reliability, then I might like to have the option to do that...but often, you have to be knowledgeable enough to ask for the right things. |
(1) Upon examination, the wire into the left magneto was found to be broken off, just at its connection to the magneto. A mechanic theorized What wire, the P-lead? Yes, the P-lead. |
"O. Sami Saydjari" wrote: (1) Upon examination, the wire into the left magneto was found to be broken off, just at its connection to the magneto. A mechanic theorized that it could have grounded to the magento housing. He said that that could have actually caused a grounding of both magnetos and could have fouled up the engine firing, and could have contributed to the failure. If we're talking about the P-lead, I don't see how grounding one would ground out both mags. In any case, if both mags had been grounded, the engine would not run at all. Later, he said that he thought that it was just a coincidence that the left mag wire happened to have been broken when the engine failed due to some other reason. What do you folks think? Could the two have been tied togehter? I doubt it. Magneto grounding doesn't cause chunks of metal in the oil filter. George Patterson This marriage is off to a shaky start. The groom just asked the band to play "Your cheatin' heart", and the bride just requested "Don't come home a'drinkin' with lovin' on your mind". |
"O. Sami Saydjari" wrote: Well, it happended. I have owned the plane (Piper Turbo Arrow III) for 3 months and the engine failed during climb out on Tuesday. Altitude was 4400 feet. Luckily, the engine did not entirely quit and I made it to an airport within 10 miles. TBO was 1000 hours away. Dissapointing! When we cut the oil filter, it was full of fairly large aluminum and steel bits of metal. Arg! (1) Upon examination, the wire into the left magneto was found to be broken off, just at its connection to the magneto. A mechanic theorized that it could have grounded to the magento housing. He said that that could have actually caused a grounding of both magnetos and could have fouled up the engine firing, and could have contributed to the failure. Later, he said that he thought that it was just a coincidence that the left mag wire happened to have been broken when the engine failed due to some other reason. What do you folks think? Could the two have been tied togehter? Very unlikely -- all the P-lead break does is prevent you from shutting down that mag. It is a good idea to pefrorm a "both off" check when doing a mag check. That way, you will be able to find a broken P-lead. You did not state whether or not the engine ran roughly or smoothely after the failure. From your description of the metal chunks, it would appear that you had a valve failure, in which case the engine would have vibrated pretty badly. (2) Now I am faced with having to have the engine overhauled. Growl! The engine has brand new cylinders on it (well, they have about 100 hours on them) put on by the previous owner. So, I think we want to do a custom overall of this particular engine. Does that make sense? Are there different places who do this sort of thing with different reputations for quality of work? If so, I would like to hear about recommendations (the engine is a TCM TSIO-360-FB) or perhaps criteria to use in making a judgement. Also, are there different quality parts or methods in doing the overhaul that are options that I need to specify when I ask for the overhaul. In other words, if I can pay 10% more and get more reliability, then I might like to have the option to do that...but often, you have to be knowledgeable enough to ask for the right things. |
doing a mag check. That way, you will be able to find a broken P-lead. Interesting. I never was taught to do that, but it makes a lot of sense. Thanks. You did not state whether or not the engine ran roughly or smoothely after the failure. From your description of the metal chunks, it would appear that you had a valve failure, in which case the engine would have vibrated pretty badly. Well, here is a little more detail. First, I experienced a 200 RPM drop. No other obvious symptoms. Then, within 2 minutes, the RPM dropped another 200 and MP pressure seemed to drop. I boosted throttle. At that point, I was getting vectors to the nearest airport. Within about 2 more minutes, I was down into the "yellow arc" of RPM...I think it was about 2000 RPM. At that point the engine began running rough, although the vibration was not that bad...just sounded very rough. Then within about 5 miles of the airport, the oil pressure began dropping into the yellow arc...35 PSI or so...and dropping. On turning final, the engine was quite rough, and oil pressure was down to around 10-15 PSI (bottom of the yellow arc), after pulling off the run way, the oil pressure was at the very bottom of the yellow arc...maybe 5 PSI. I immediately shutdown. Does that help? (2) Now I am faced with having to have the engine overhauled. Growl! The engine has brand new cylinders on it (well, they have about 100 hours on them) put on by the previous owner. So, I think we want to do a custom overall of this particular engine. Does that make sense? Are there different places who do this sort of thing with different reputations for quality of work? If so, I would like to hear about recommendations (the engine is a TCM TSIO-360-FB) or perhaps criteria to use in making a judgement. Also, are there different quality parts or methods in doing the overhaul that are options that I need to specify when I ask for the overhaul. In other words, if I can pay 10% more and get more reliability, then I might like to have the option to do that...but often, you have to be knowledgeable enough to ask for the right things. |
"O. Sami Saydjari" wrote: Well, here is a little more detail. First, I experienced a 200 RPM drop. No other obvious symptoms. Then, within 2 minutes, the RPM dropped another 200 and MP pressure seemed to drop. I boosted throttle. At that point, I was getting vectors to the nearest airport. Within about 2 more minutes, I was down into the "yellow arc" of RPM...I think it was about 2000 RPM. At that point the engine began running rough, although the vibration was not that bad...just sounded very rough. Then within about 5 miles of the airport, the oil pressure began dropping into the yellow arc...35 PSI or so...and dropping. On turning final, the engine was quite rough, and oil pressure was down to around 10-15 PSI (bottom of the yellow arc), after pulling off the run way, the oil pressure was at the very bottom of the yellow arc...maybe 5 PSI. I immediately shutdown. Does that help? Well, you can rule out magneto problems being a factor here. If the temperatures were going up at the same time, something in that engine was binding, and it was getting ready to seize. The pressure drop would be caused either by a serious oil leak (you would've noticed that) or rapid clogging of oil passages by metal particles. I think it would not have kept running much longer. George Patterson This marriage is off to a shaky start. The groom just asked the band to play "Your cheatin' heart", and the bride just requested "Don't come home a'drinkin' with lovin' on your mind". |
going up at the same time, something in that engine was binding, and it was getting ready to seize. As I recall, the temperature remained in the green. The pressure drop would be caused either by a serious oil leak (you would've noticed that) or rapid clogging of oil passages by metal particles. Right. I immediately checked the oil after landing and it was at 7.5 quarts, just where it was on take-off. I think it would not have kept running much longer. Good to know George Patterson This marriage is off to a shaky start. The groom just asked the band to play "Your cheatin' heart", and the bride just requested "Don't come home a'drinkin' with lovin' on your mind". |
Orval Fairbairn writes: [...] all the P-lead break does is prevent you from shutting down that mag. It is a good idea to pefrorm a "both off" check when doing a mag check. That way, you will be able to find a broken P-lead. I've heard mechanics advising against doing this test casually. If done at even moderate power, it can apparently cause backfiring, which can in turn create induction system damage. I've seen a C172, one cylinder of which was burned out shortly after such an episode, due to extreme lean running resulting from induction cracks. - FChE |
Why,
If you check the left and then the right mag, you know that both of them will ground out properly without risking damage due to a backfire. The only thing that individually checking the mags won't find is a switch that is defective in the off position only, pretty unlikely. If you are that paranoid about the switch, you can check it with an ohmmeter with the engine stopped. Orval Fairbairn wrote: Very unlikely -- all the P-lead break does is prevent you from shutting down that mag. It is a good idea to pefrorm a "both off" check when doing a mag check. That way, you will be able to find a broken P-lead. -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
Similar Threads | ||||
p3/95 | [email protected] | Military Aviation | 1 | September 27th 04 12:27 AM |
PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 12:14 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
In Flight Failure | Charles Talleyrand | Military Aviation | 1 | August 4th 03 05:25 AM |
