Learning to fly
On Sat, 7 Jul 2007 17:23:32 +0100, "GB"
wrote in : 40 years or so ago, I learned to fly, at least a bit. I did some solo circuits in gliders. I would like to come back to flying, and I was wondering about whether to learn on powered or unpowered planes? The answer to that question depends on what sort of flying you want to do once you have your airmans certificate, and how much you can afford to spend on flying. Glider instruction can be very inexpensive if you join a soaring club, and you will get some fundamental experience in aerodynamics and meteorology that powered flyers only get a smattering of. However, you will be mostly limited to summer days, and costs will be about as low as possible. Powered flight is less of a sport, and can be useful for air touring, but the cost of flight instruction and aircraft operation is significantly more that soaring. If I learn on gliders, will this be any help towards getting a PPL? It should make your transition to powered flight significantly easier, if that's what you meant. Actually there are several private pilot licenses: Single Engine Land and sea, Multiengine, Glider, Lighter Than Air, ... I apprecaite that it's all good experience, but I have a feeling that the PPL only counts hours in a powered plane. Is that right? A Private Glider certificate requires instruction in gliders. Also, any recommendations for places to learn to fly, powered or unpowered, near North London? I'll cross post this follow up article to the uk.rec.aviation and rec.aviation.soaring newsgroups, and you should receive some replies from knowledgeable folks in that location. Finally, I am very overweight (over 18 stone). Does that rule out gliders unless I lose quite a bit of weight? I'll leave that question to the airmen in rec.aviation.soaring. Thanks very much. You may want to consider inquiring at one of the soaring advocacy groups like the Soaring Society of America; you'll find a lot of good information on their web site: http://www.ssa.org/ . I can also recommend the Aircraft Owners and Pilots Association web site for more power oriented information: http://www.aopa.org/ . Unfortunately, I unable to provide information for the similar European organizations. |
Learning to fly
"Larry Dighera" wrote in message
... On Sat, 7 Jul 2007 17:23:32 +0100, "GB" wrote in : 40 years or so ago, I learned to fly, at least a bit. I did some solo circuits in gliders. I would like to come back to flying, and I was wondering about whether to learn on powered or unpowered planes? ...Also, any recommendations for places to learn to fly, powered or unpowered, near North London? I assume you mean London in the UK and not in Canada or whatever other contries have cities named "London" :-) British Gliding Association http://www.gliding.co.uk/ Club locations http://www.gliding.co.uk/findaclub/ukmap.htm There are more gliding clubs in the UK than you can shake a stick at... But if you did mean London Canada: http://www.sac.ca/ :-) -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Learning to fly
In rec.aviation.soaring Larry Dighera wrote:
On Sat, 7 Jul 2007 17:23:32 +0100, "GB" wrote in : 40 years or so ago, I learned to fly, at least a bit. I did some solo circuits in gliders. I would like to come back to flying, and I was wondering about whether to learn on powered or unpowered planes? The answer to that question depends on what sort of flying you want to do once you have your airmans certificate, and how much you can afford to spend on flying. Glider instruction can be very inexpensive if you join a soaring club, and you will get some fundamental experience in aerodynamics and meteorology that powered flyers only get a smattering of. I would say that if you are planning to fly purely for fun, go for gliders. If you imagine using it for useful things (or if "fun" for you means using the plane to go on vacation somewhere) then go for powered. (Full disclosure, I'm a glider pilot.) However, you will be mostly limited to summer days, and costs will be about as low as possible. I must object to this, as some of the most spectacular soaring can happen in the dead of winter, in the form of ridge and wave soaring. I don't know how things are in the UK, but here in Virginia even for thermal soaring the definition of "summer" is pretty loose, and really includes a great deal of the spring and fall. But the general theme is still true; gliders are much more weather-dependent. You can fly in the same weather as a VFR powered plane, but you can't *stay up* and therefore make it really fun on a lot of those days. -- Michael Ash Rogue Amoeba Software |
Learning to fly
On Sat, 07 Jul 2007 18:34:35 -0500, Michael Ash
wrote in : You can fly in the same weather as a VFR powered plane, but you can't *stay up* and therefore make it really fun on a lot of those days. Not to mention the nights. :-) |
Learning to fly
"Larry Dighera" wrote in message ... On Sat, 07 Jul 2007 18:34:35 -0500, Michael Ash wrote in : You can fly in the same weather as a VFR powered plane, but you can't *stay up* and therefore make it really fun on a lot of those days. Not to mention the nights. :-) Thanks to all who replied. You have helped me to make my mind up about one thing. I am only interested in flying 'for fun', so I'll go the gliding route. You seem to get a lot more time in the air for your money with a glider. Now to tackle the weight issue. |
Learning to fly
glider. A lot more hanging about waiting to get a launch as well. I have never really "got" gliding, being a die'd in the wool power chap. Too much down time for me. I'd recommend the NPPL M David |
Learning to fly
"D" wrote in
: You seem to get a lot more time in the air for your money with a glider. A lot more hanging about waiting to get a launch as well. I have never really "got" gliding, being a die'd in the wool power chap. Too much down time for me. I'd recommend the NPPL M David My experience with soaring is that you are always doing something when you are not flying. Socializing with club members is part of the experience, and much more common in my experience than in power-plane flying clubs. Right now I fly my own plane for pleasure, and occasionally for business, but I look forward to the day when I can return to soaring. Flying to the soaring club appears to be a good justification for owning a power plane :-) Rob Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
Learning to fly
wrote: I must object to this, as some of the most spectacular soaring can happen in the dead of winter, Assuming that paragliding is similar, one of the great treats of skiing at Aspen is watching the fliers play off the open slopes (pistes to the lad in the UK) and forests. I've never seen a hard-shell glider doing this, perhaps because the airport is near 8,000 feet and the tow plane would really have its work cut out for it. The paragliders just ski down the mountain a few hundred feet, then pop the chute out of a very large backpack. Blue skies! -- Dan Ford Claire Chennault and His American Volunteers, 1941-1942 forthcoming from HarperCollins www.flyingtigersbook.com |
Learning to fly
Cubdriver wrote:
On Sat, 07 Jul 2007 18:34:35 -0500, Michael Ash wrote: I must object to this, as some of the most spectacular soaring can happen in the dead of winter, Assuming that paragliding is similar, one of the great treats of skiing at Aspen is watching the fliers play off the open slopes (pistes to the lad in the UK) and forests. I've never seen a hard-shell glider doing this, perhaps because the airport is near 8,000 feet and the tow plane would really have its work cut out for it. Glider towing is done out of Telluride and Buena Vista, both above 8000 feet, and Salida at 7000 feet. Tows out of Front Range glider operations are routinely higher than 8000 feet as well. Shawn |
Learning to fly
On Jul 8, 6:23 pm, Peter wrote:
Rob McDonald wrote My experience with soaring is that you are always doing something when you are not flying. Socializing with club members is part of the experience, and much more common in my experience than in power-plane flying clubs. The social scene seems to be a way of life. It's OK if you want that, not OK if you don't. But one needs to be clear that this is the choice. I looked into gliding and it was obvious one would spend the whole weekend hanging around. I think it depends on where you're flying. I understand that in the US you can book lessons with instructors and turn up a set time, fly, and go home again. In the UK you get instruction for free but have to spend the whole day on a cold field being bored for twenty minutes of flying. In theory you can entertain yourself by doing some other jobs e.g. helping launch gliders, driving winch retrieve etc. but if you do that people will quickly come to expect it of you, and you'll rapidly find yourself part of a small group which does all the work while everyone else shirks. And people wonder why UK gliding is shrinking faster than the icecaps... A couple of clubs have got their arses into gear and introduced booking systems and are indeed reaping the results (more members flying than they know what to do with), but those clubs are very much in the minority (introducing something new implies the old system was inadequate, and it's very hard for people to admit that they were inadequate). Dan |
Similar Threads | ||||
Learning to fly | GB | Piloting | 19 | July 17th 07 09:40 AM |
Question about Learning to fly? | Dwayne Smith | Piloting | 11 | November 27th 05 03:51 PM |
Learning to fly... | JohnWN in Burke, VA | Soaring | 7 | October 25th 04 01:09 PM |
Learning To Fly? | John | General Aviation | 2 | June 20th 04 01:53 PM |
Re-learning IFR | Jim | Instrument Flight Rules | 9 | November 25th 03 07:38 PM |
