Radios, Intercoms & Inputs.
As my name implies I'm building a Zenith 601XL. The avionics I'm planning on
are as follows... Garmin SL40 and a Garmin 496. I know that the SL40 has a built in intercom and I assume it is good enough for two headsets. My questions is is there an input for the external audio that will be coming from the XM side of the 496? Or will I have to install a stand-alone intercom for that? Also, I have considered a secondary audio input for an iPod. If the SL40 is capable of dealing with outside audio on its own does anyone have an idea as to what I need to do to put an external switch in the system to switch between the XM and the iPod? |
On Dec 13, 7:34 am, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net
wrote: As my name implies I'm building a Zenith 601XL. The avionics I'm planning on are as follows... Garmin SL40 and a Garmin 496. I know that the SL40 has a built in intercom and I assume it is good enough for two headsets. My questions is is there an input for the external audio that will be coming from the XM side of the 496? Or will I have to install a stand-alone intercom for that? Also, I have considered a secondary audio input for an iPod. If the SL40 is capable of dealing with outside audio on its own does anyone have an idea as to what I need to do to put an external switch in the system to switch between the XM and the iPod? The easiest way to add an alternative input for the SL40 is add a switched panel mount stereo jack to your panel. When nothing is plugged in it will feed the XM to the SL40, when the ipod is plugged in the ipod music will be fed to the SL40. An example of such a component is CP1 -3515-ND available from www.digikey.com. The wiring is fairly simple given the part datasheet http://www.cui.com/pdffiles/SJ1-3515.pdf, follow these steps. 1. Determine if the input to the SL40 is mono or stereo, and follow the table below 2. If SL40 is stereo wire as below else goto step 3. Jack Pin Number Wire To 1 496 XM ground, SL40 ground 2 SL40 Left channel input 3 SL40 Right Channel input 4 496 XM left channel output 5 496 XM Right channel output you are done. 3. If SL40 is mono wire as below. Jack Pin Number Wire To 1 496 XM ground, SL40 ground 2 SL40 Audio input 3 Not connected 4 496 XM left channel output 5 Not connected you are done. Do you have any pictures of your 601XL? One last thing before you go and purchase this jack make sure the threaded barrel is long enough compared to your panel thickness, and nut. |
markt wrote:
On Dec 13, 7:34 am, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote: As my name implies I'm building a Zenith 601XL. The avionics I'm planning on are as follows... Garmin SL40 and a Garmin 496. I know that the SL40 has a built in intercom and I assume it is good enough for two headsets. My questions is is there an input for the external audio that will be coming from the XM side of the 496? Or will I have to install a stand-alone intercom for that? Also, I have considered a secondary audio input for an iPod. If the SL40 is capable of dealing with outside audio on its own does anyone have an idea as to what I need to do to put an external switch in the system to switch between the XM and the iPod? The easiest way to add an alternative input for the SL40 is add a switched panel mount stereo jack to your panel. When nothing is plugged in it will feed the XM to the SL40, when the ipod is plugged in the ipod music will be fed to the SL40. An example of such a component is CP1 -3515-ND available from www.digikey.com. The wiring is fairly simple given the part datasheet http://www.cui.com/pdffiles/SJ1-3515.pdf, follow these steps. 1. Determine if the input to the SL40 is mono or stereo, and follow the table below 2. If SL40 is stereo wire as below else goto step 3. Jack Pin Number Wire To 1 496 XM ground, SL40 ground 2 SL40 Left channel input 3 SL40 Right Channel input 4 496 XM left channel output 5 496 XM Right channel output you are done. 3. If SL40 is mono wire as below. Jack Pin Number Wire To 1 496 XM ground, SL40 ground 2 SL40 Audio input 3 Not connected 4 496 XM left channel output 5 Not connected you are done. Do you have any pictures of your 601XL? One last thing before you go and purchase this jack make sure the threaded barrel is long enough compared to your panel thickness, and nut. Thanks for the info but it adds another question. Are some SL40s stereo and some mono? If so how can I tell? Remember we are talking about a used one that will be purchased from e-bay. And yes I have a few photos, though I haven't updated in a while. www.peoamerica.net/N601WR |
On Dec 17, 3:16 pm, Gig601XLBuilder wrote:
markt wrote: On Dec 13, 7:34 am, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote: As my name implies I'm building a Zenith 601XL. The avionics I'm planning on are as follows... Garmin SL40 and a Garmin 496. I know that the SL40 has a built in intercom and I assume it is good enough for two headsets. My questions is is there an input for the external audio that will be coming from the XM side of the 496? Or will I have to install a stand-alone intercom for that? Also, I have considered a secondary audio input for an iPod. If the SL40 is capable of dealing with outside audio on its own does anyone have an idea as to what I need to do to put an external switch in the system to switch between the XM and the iPod? The easiest way to add an alternative input for the SL40 is add a switched panel mount stereo jack to your panel. When nothing is plugged in it will feed the XM to the SL40, when the ipod is plugged in the ipod music will be fed to the SL40. An example of such a component is CP1 -3515-ND available fromwww.digikey.com. The wiring is fairly simple given the part datasheethttp://www.cui.com/pdffiles/SJ1-3515.pdf, follow these steps. 1. Determine if the input to the SL40 is mono or stereo, and follow the table below 2. If SL40 is stereo wire as below else goto step 3. Jack Pin Number Wire To 1 496 XM ground, SL40 ground 2 SL40 Left channel input 3 SL40 Right Channel input 4 496 XM left channel output 5 496 XM Right channel output you are done. 3. If SL40 is mono wire as below. Jack Pin Number Wire To 1 496 XM ground, SL40 ground 2 SL40 Audio input 3 Not connected 4 496 XM left channel output 5 Not connected you are done. Do you have any pictures of your 601XL? One last thing before you go and purchase this jack make sure the threaded barrel is long enough compared to your panel thickness, and nut. Thanks for the info but it adds another question. Are some SL40s stereo and some mono? If so how can I tell? Remember we are talking about a used one that will be purchased from e-bay. And yes I have a few photos, though I haven't updated in a while.www.peoamerica.net/N601WR- Hide quoted text - - Show quoted text - I downloaded the SL40 manual and it doesn't look like it has an aux input, so I don't think you will be able to do what you want. |
markt wrote:
- Show quoted text - I downloaded the SL40 manual and it doesn't look like it has an aux input, so I don't think you will be able to do what you want. I looked at the manual and didn't see it either but since I was only looking at the 22 page operations manual I was hoping that it was a feature that just wasn't listed. Anyone know where an installation manual may be found? The Garmin site only has the ops manual and a TSO letter. |
On Dec 18, 7:22 am, Gig601XLBuilder wrote:
markt wrote: - Show quoted text - I downloaded the SL40 manual and it doesn't look like it has an aux input, so I don't think you will be able to do what you want. I looked at the manual and didn't see it either but since I was only looking at the 22 page operations manual I was hoping that it was a feature that just wasn't listed. Anyone know where an installation manual may be found? The Garmin site only has the ops manual and a TSO letter. The ICOM A210, seems to have all the features of the SL40 and the audio input. It is new so I doubt you could get a used one. |
markt wrote:
On Dec 18, 7:22 am, Gig601XLBuilder wrote: markt wrote: - Show quoted text - I downloaded the SL40 manual and it doesn't look like it has an aux input, so I don't think you will be able to do what you want. I looked at the manual and didn't see it either but since I was only looking at the 22 page operations manual I was hoping that it was a feature that just wasn't listed. Anyone know where an installation manual may be found? The Garmin site only has the ops manual and a TSO letter. The ICOM A210, seems to have all the features of the SL40 and the audio input. It is new so I doubt you could get a used one. I saw the ICOM on some A210 even new it's cost isn't much less than a used SL30. I just hate buying the first generation of a new product like that and I'm not that familiar with ICOM to begin with. It does have the same primary feature I like in the SL40 which is the ability to monitor the standby freq. Which in the limited space of my 601 is great because it gives me half of the benefits of a second radio. I'll look at it further. |
Similar Threads | ||||
Jim Weir- need help on aux audio inputs to PM-3000 intercom | Danny | Home Built | 16 | June 8th 06 08:45 PM |
Portable 4 place intercoms-roll your own? | John T | Piloting | 5 | February 28th 06 07:08 PM |
U$ Says Prisoners Beaten With Hand-Held Radios, NOT Clock Radios! *snicker* | JStONGE123 | Military Aviation | 1 | May 11th 04 06:22 AM |
ARC Cessna 328 Aux Audio Inputs | N7155A | Owning | 2 | April 21st 04 09:25 PM |
question on intercoms for my new homebuilt | w b evans | Home Built | 1 | July 23rd 03 12:57 AM |
