Running XCSOAR on an ereader
I would like advice on tablets such as KOBO mini which will
run XCSOAR; my Kobo Usb port has died. stay safe. John Firth |
On 2/24/2021 2:23 PM, john firth wrote:
I would like advice on tablets such as KOBO mini which will run XCSOAR; my Kobo Usb port has died. stay safe. John Firth I use Tophat on both Nooks and a Kobo. My experience is that the micro USB connector breaks very easily. So I try to avoid using it. Moreover GPS input via USB was flaky on the Nook, sometimes froze up in mid flight and I had to reboot it (not a big deal). So I hard-wired a GPS module (in one Nook) or an RS232 adapter (in another Nook) to the serial port that is hidden inside, that has worked great. While at it, I added a (non-micro) USB cable to one Nook for external power. For more details see the Tophat forum, or send me personal email. (Tophat is based on XCsoar, and these hardware issues are the same for both.) |
... my Kobo Usb port has died. You can usually find Kobo on eBay for around $50. Well OK $750 Canadien... I use the Kobo Glo (not Glo HD) with TopHat. |
On Wednesday, February 24, 2021 at 1:23:50 PM UTC-6, john firth wrote:
I would like advice on tablets such as KOBO mini which will run XCSOAR; my Kobo Usb port has died. stay safe. John Firth I've got this color e-ink reader: http://www.onyxbooxusa.com/products/...ox-poke-color/ Checked it out (XCSoar) with an external GPS source (WiFi and BT connection available) and it works fine on the ground; still need to check it in the air. No speaker, but can attach one using either BT or USB-C OTG adapter (checked positive). |
On 2/24/2021 5:45 PM, Tom BravoMike wrote:
On Wednesday, February 24, 2021 at 1:23:50 PM UTC-6, john firth wrote: I would like advice on tablets such as KOBO mini which will run XCSOAR; my Kobo Usb port has died. stay safe. John Firth I've got this color e-ink reader: http://www.onyxbooxusa.com/products/...ox-poke-color/ Checked it out (XCSoar) with an external GPS source (WiFi and BT connection available) and it works fine on the ground; still need to check it in the air. No speaker, but can attach one using either BT or USB-C OTG adapter (checked positive). Interesting. Seems like a recent model. Did you have to hack control away from the e-reading software, or does this model allow installing other Android apps (such as XCsoar) in addition to the e-reading software it comes with? |
On Wednesday, February 24, 2021 at 5:11:02 PM UTC-6, Moshe Braner wrote:
On 2/24/2021 5:45 PM, Tom BravoMike wrote: On Wednesday, February 24, 2021 at 1:23:50 PM UTC-6, john firth wrote: I would like advice on tablets such as KOBO mini which will run XCSOAR; my Kobo Usb port has died. stay safe. John Firth I've got this color e-ink reader: http://www.onyxbooxusa.com/products/...ox-poke-color/ Checked it out (XCSoar) with an external GPS source (WiFi and BT connection available) and it works fine on the ground; still need to check it in the air. No speaker, but can attach one using either BT or USB-C OTG adapter (checked positive). Interesting. Seems like a recent model. Did you have to hack control away from the e-reading software, or does this model allow installing other Android apps (such as XCsoar) in addition to the e-reading software it comes with? It's a regular Android 9.0 OS, it has the Google Play Store. No issue and no hacking needed to install the XSSoar and other Android apps so far. |
On Wednesday, February 24, 2021 at 11:59:58 PM UTC, Tom BravoMike wrote:
On Wednesday, February 24, 2021 at 5:11:02 PM UTC-6, Moshe Braner wrote: On 2/24/2021 5:45 PM, Tom BravoMike wrote: On Wednesday, February 24, 2021 at 1:23:50 PM UTC-6, john firth wrote: I would like advice on tablets such as KOBO mini which will run XCSOAR; my Kobo Usb port has died. stay safe. John Firth I've got this color e-ink reader: http://www.onyxbooxusa.com/products/...ox-poke-color/ Checked it out (XCSoar) with an external GPS source (WiFi and BT connection available) and it works fine on the ground; still need to check it in the air. No speaker, but can attach one using either BT or USB-C OTG adapter (checked positive). Interesting. Seems like a recent model. Did you have to hack control away from the e-reading software, or does this model allow installing other Android apps (such as XCsoar) in addition to the e-reading software it comes with? It's a regular Android 9.0 OS, it has the Google Play Store. No issue and no hacking needed to install the XSSoar and other Android apps so far. There is also a 7,8 inch version due out next month |
On Thursday, February 25, 2021 at 1:55:40 PM UTC, Muttley wrote:
On Wednesday, February 24, 2021 at 11:59:58 PM UTC, Tom BravoMike wrote: On Wednesday, February 24, 2021 at 5:11:02 PM UTC-6, Moshe Braner wrote: On 2/24/2021 5:45 PM, Tom BravoMike wrote: On Wednesday, February 24, 2021 at 1:23:50 PM UTC-6, john firth wrote: I would like advice on tablets such as KOBO mini which will run XCSOAR; my Kobo Usb port has died. stay safe. John Firth I've got this color e-ink reader: http://www.onyxbooxusa.com/products/...ox-poke-color/ Checked it out (XCSoar) with an external GPS source (WiFi and BT connection available) and it works fine on the ground; still need to check it in the air. No speaker, but can attach one using either BT or USB-C OTG adapter (checked positive). Interesting. Seems like a recent model. Did you have to hack control away from the e-reading software, or does this model allow installing other Android apps (such as XCsoar) in addition to the e-reading software it comes with? It's a regular Android 9.0 OS, it has the Google Play Store. No issue and no hacking needed to install the XSSoar and other Android apps so far. There is also a 7,8 inch version due out next month my previous e-mail forgot to add https://tinyurl.com/h1dek3nr |
On 2/25/2021 9:00 AM, Muttley wrote:
On Thursday, February 25, 2021 at 1:55:40 PM UTC, Muttley wrote: On Wednesday, February 24, 2021 at 11:59:58 PM UTC, Tom BravoMike wrote: On Wednesday, February 24, 2021 at 5:11:02 PM UTC-6, Moshe Braner wrote: On 2/24/2021 5:45 PM, Tom BravoMike wrote: On Wednesday, February 24, 2021 at 1:23:50 PM UTC-6, john firth wrote: I would like advice on tablets such as KOBO mini which will run XCSOAR; my Kobo Usb port has died. stay safe. John Firth I've got this color e-ink reader: http://www.onyxbooxusa.com/products/...ox-poke-color/ Checked it out (XCSoar) with an external GPS source (WiFi and BT connection available) and it works fine on the ground; still need to check it in the air. No speaker, but can attach one using either BT or USB-C OTG adapter (checked positive). Interesting. Seems like a recent model. Did you have to hack control away from the e-reading software, or does this model allow installing other Android apps (such as XCsoar) in addition to the e-reading software it comes with? It's a regular Android 9.0 OS, it has the Google Play Store. No issue and no hacking needed to install the XSSoar and other Android apps so far. There is also a 7,8 inch version due out next month my previous e-mail forgot to add https://tinyurl.com/h1dek3nr Looks great! Moshe, why don't you update TopHat to run on this one! |
Similar Threads | ||||
Oudie 2 Lite Running XCSoar, any fix yet? | Blake Seese 3Y | Soaring | 0 | June 1st 15 02:04 AM |
Anybody running a Butterfly Vario with XCSoar? | jfitch | Soaring | 26 | July 18th 13 04:41 PM |
XCSoar and Top Hat issues running on Samsung Galaxy Tab 3 | Gary Adams | Soaring | 4 | July 11th 13 02:55 PM |
I am up and running again | Danny Deger | Piloting | 2 | June 27th 07 05:20 PM |
Running an 0-235 well beyond TBO | Paul Folbrecht | Owning | 8 | March 14th 04 01:30 AM |
