IFR use of handheld GPS
Old May 7th 06, 11:08 PM posted to rec.aviation.ifr
Default IFR use of handheld GPS
Authorization to conduct any GPS operation under IFR requires that:
a) GPS navigation equipment used must be FAA-approved and the installation
must be done in accordance with FAA requirements
i) Approval for the use of the GPS for IFR operations, and any
limitations, will be found in the airplane's POH (also called
the FAA-approved Airplane Flight Manual) and the airplane's
logbook
ii) VFR and hand-held GPS systems are not authorized for IFR
navigation, for instrument approaches, or as a principle
instrument flight references. During IFR operations, they
may be considered only an aid to situational awareness.
This seems fairly clear to me.....
Shh...don't let the facts get in the way of ones mindset.
A primary reason that handheld/VFR GPS units are not acceptable for
VFR use is that they not not include an integrity capability. That is
essential for IFR ops.
Ron Lee
  #132
Old May 7th 06, 11:39 PM posted to rec.aviation.ifr
logbook
That's not fact. As far as I can tell, the advisory circular that the
"fact" supposedly came from was paraphrased by some written test
preparation materials. That is what you quoted. Not fact. See the
original message from Dane. Neither the AC nor POHs say anything about
handhelds.
  #133
Old May 7th 06, 11:53 PM posted to rec.aviation.ifr
Ron Lee
Sure, sounds good, but then if the FAA regulated by reason, NDB
approaches would have been made illegal long ago. I would bet many
more people have been injured and killed because of crappy ADFs and
just plain inaccurate old technology than by using a handheld GPS unit
while flying enroute. Even VORs don't have much for "integrity
monitoring," just that dumb little flag. I've seen many inaccurate VOR
readings and some outright failures without the flag showing red.
I've also seen handheld GPSs fail, too. But, in general, they are
probably more accurate and dependable than VOR and ADF.
Peter
  #134
Old May 8th 06, 12:04 AM posted to rec.aviation.ifr
"Ron Lee" wrote in message
This is like a religion with you people. It's strictly a matter faith that
use of handheld GPS during IFR enroute flight in US controlled airspace is
illegal and/or unsafe.
  #135
Old May 8th 06, 12:09 AM posted to rec.aviation.ifr
In article . net,
It depends on what you're using it for. A handheld GPS and a ham sandwich
are both useful objects, but using either one for the other's intended
purpose can be dangerous.
  #136
Old May 8th 06, 12:22 AM posted to rec.aviation.ifr
Well, there are those stories of the open-cockpit airmail pilots using
cigars to time approaches. Don't know about ham sandwiches though. I
suppose if you're Steve Fossett, and your sandwich starts getting
moldy, you're about to run outa gas.
  #137
Old May 8th 06, 12:31 AM posted to rec.aviation.ifr
In article .com,
handhelds.
Section 1-1-19-d of the AIM addresses the general requirements
for conducting any GPS operations under IFR. Section 1-1-19-d1a
explicitly states (and I quote):
"Visual flight rules (VFR) and hand-held GPS systems are not authorized
for IFR navigation, instrument approaches, or as a principal instrument
flight reference."
It appears that the Gleim written test prep materials I cited in my previous
posting took much of their material from the AIM and not the AC. The AIM,
however, also does cite AC 20-138.
Again, this seems fairly clear to me.
-- Dane
  #138
Old May 8th 06, 12:44 AM posted to rec.aviation.ifr
"Dane Spearing" wrote in message
flight reference."
previous
Faith is a mysterious thing.
  #139
Old May 8th 06, 02:28 AM posted to rec.aviation.ifr
"Roy Smith" wrote in message
In article . net,
that
is
If not nutritious.
  #140
Old May 8th 06, 02:33 AM posted to rec.aviation.ifr
ink.net...
flight reference."
previous
AIM,
Careful, Steven. If they determine that you are an infidel then they may
petition the Pope to excommunicate you.
HANDHELD RADIO [email protected] Soaring 22 March 17th 16 03:16 PM
Navcom - handheld VS panel ? [email protected] Home Built 10 October 31st 05 08:08 PM
GPS Handheld Kai Glaesner Instrument Flight Rules 2 November 16th 04 04:01 PM
Upgrade handheld GPS, or save for panel mount? [email protected] Owning 7 March 8th 04 03:33 PM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 01:10 PM
