slide-in replacement for Cessna 300 series nav-com?
Old November 11th 03, 10:50 PM
Bill T.
Default slide-in replacement for Cessna 300 series nav-com?
hi-
i have an old Cessna (arc) 300 series 100 channel nav-com i'd like to
replace. (it's a cc-312A).
is there a slide-in replacement for this radio avail? or any used
radios that will slide into this chasis?
thanks for any advice!
Old November 14th 03, 10:47 PM
SeeAndAvoid
I have 2 16 year old TKM (Michel) MX300's, and their still doing great.
If you're looking for a cheap replacement unit and are used to using your
radios, this is an easy choice. Not the best choice, but for the money a
fine functioning unit. They don't have a built-in Glideslope, but you
probably already have a separate one. If you have a newer audio panel, the
audio from COM & NAV are not separate, same audio channel.
I thought I had to ditch mine as power would cut out, or I'd only transmit
carrier with no modulation. But got a new audio panel (PS Engineering
PMA7000B) and fixed tons of questionable wiring from previous owner, and the
radios work and sound terrific. The avionics shop, who isnt a big fan of
these cheap slide-in replacements, was pretty impressed. So they'll stay
for a little while longer. I think you can get them for about $1,500.
Good luck, Chris
"Bill T." wrote in message
hi-
FS: 1992 "Space Age: The Companion Volume To The PBS Television Series" Book J.R. Sinclair Aviation Marketplace 0 October 26th 04 06:30 AM
FS: 1992 Space Ventures "SpaceShots" Series 3 International Edition Set J.R. Sinclair Aviation Marketplace 0 August 27th 04 05:44 AM
A-4 slide collection for sale TOPFLIGHTPICS Military Aviation 0 August 17th 04 10:02 PM
Narco MK 16 replacement SoulReaver714 Aviation Marketplace 1 September 23rd 03 04:38 PM
TKM MX-11 Com true slide replacement ? Rohit Fedane Owning 0 September 21st 03 05:02 PM
