Need Help Configuring Power FLARM Portable
Set the baud rate to 57600 in the config file. CN2 will connect.
If you reset the serial port rate on powerflarm after you've powered things up, you'll (afaik) have to do a power cycle/reboot on CN2. CN2 will connect at any rate between 19.2 and 57.6, performance will be best at 57.6. On Friday, June 14, 2019 at 9:02:57 PM UTC-4, Dan Marotta wrote: I looked at configuring the ports on my PF portable and it appears to me that there's only one.Â* My options were to set the baud rate which was at 9600 and the messages, flarm, nav, or both.Â* I tried other baud rates and lost the connection to my CNII. Here's what I found today.Â* My CNII recognizes the connection to the Flarm (as evidenced by the black "f" on the CNII display).Â* Changing the baud rate causes the "f" to turn red.Â* Also, until the Flarm locks on to the GPS, the "f" is red. Looking at message traffic on the Streak showed nothing, zip, nada. Not knowing the protocol, I can only guess that the "keep alive" message is on the line, but no data.Â* I tried rolling back to Flarm v. 6.60 but was told that it was already installed.Â* Actually, 6.67 is installed. What's next?Â* I think I need to build a configuration file and reconfigure the Flarm.Â* I'll be off to a fly-in in the 180 tomorrow so it'll be a couple of days before I get to try it out. On 6/14/2019 10:06 AM, Tango Eight wrote: Which port is clearnav on? You have port 2 switched off. You should set the port speed to 57600. Port 1 is set to 19200. best, Evan On Friday, June 14, 2019 at 11:18:00 AM UTC-4, Dan Marotta wrote: You've read on another thread that, since updating the firmware in my PF Portable and updating the FlarmNet data file in my ClearNav II, I've not been receiving Flarm targets on the ClearNav or on my wife's Streak. Yesterday, full of hope, I downloaded and installed the just released FlarmNet file (data.fln).Â* No joy! The next easiest thing to try would be to roll back the PowerFlarm firmware from 6.67 to 6.60 but I suspect that that won't work.Â* I would expect a message telling me that I have a newer version installed. So I figured I'd try to reset the configuration of the Flarm.Â* I went to Flarm.com and started the Configuration Tool.Â* One of the earliest questions asked was for the serial number of my unit and, when I entered that, I got an error stating that the serial number was invalid!Â* True, I did not have the unit with me at home to check, but I do have the SD card and it looks to me like the serial number is either 960 or 000960.Â* I entered both and got errors.Â* My PFP00960.txt file is here to be looked at for any advice.Â* I'm out of ideas. -- Dan, 5J -- Dan, 5J |
Similar Threads | ||||
FS: Power FLARM Portable | Nick Gill | Soaring | 3 | June 11th 17 06:48 AM |
power flarm portable is sold | [email protected] | Soaring | 0 | February 18th 16 10:00 PM |
Power FLARM Portable for sale | [email protected] | Soaring | 0 | December 25th 14 03:31 PM |
Portable Power Flarm for sale | [email protected] | Soaring | 1 | June 2nd 12 01:14 AM |
Power FLARM portable reports? | Andy[_1_] | Soaring | 2 | December 9th 11 03:58 PM |
