#21
Use of weak links
On Jun 4, 10:15*am, Chris Nicholas wrote:
For clarity, did the original poster mean Chief Flying Instructor by "CFI" (UK and some other countries' usage), *or "some CFIG” as another (USA?) poster thought? Either way, what is the safety officer doing, not caring and deferring to the the CFI whoever it is? Chris N. The original message was from South Africa. Presumably the OP meant Chief Flying Instructor. Darryl |
Use of weak links
On Jun 4, 6:27*am, Andreas Maurer wrote:
As long as the IAS is below VA (in other words: in the green range of the airspeed indicator), no control input at all can damage the glider Are you sure about that? It was my understanding the Va is never marked in the ASI and that the top of the green arc is the maximum operating speed in rough air. Va may be lower than that. Andy |
Use of weak links
On Jun 4, 1:53*pm, Andy wrote:
On Jun 4, 6:27*am, Andreas Maurer wrote: As long as the IAS is below VA (in other words: in the green range of the airspeed indicator), no control input at all can damage the glider Are you sure about that? *It was my understanding the Va is never marked in the ASI and that the top of the green arc is the maximum operating speed in rough air. Va may be lower than that. Andy andy - that is correct |
Use of weak links
On Jun 3, 6:43*pm, brian whatcott wrote:
Brian wrote: /snip/ Specifically what I am saying is that unless you are exceeding the Maximum Winch Launch speed of the glider it should be impossible to overstress the wings as the wing will stall before exceeding maximum structural load of the aircraft. Brian This is a perfectly sound argument in many phases of flight. * But a *tow capable of exerting enough force on a stalled structure will certainly break it. A winch need not relax when a wing stalls.... Visualize an airframe being hauled along at an AoA of 90 degrees, to exaggerate this point... Brian W While technically correct, in practice it probably isn't much of a factor. For my 750lb glider with a 120sq.ft. of wing rated for 6g's and as 1g stall speed of 40 mph the 6g stall speed is 97mph. For the flat plate drag of the wing area to exceed 6g's on the wing a 120mph is required by my calculation, which means the winch operator is going to have be pulling me at 120mph since I am stalled and no longer have any angular acceleration. A 200% weak link should break at 69mph if I understand it correctly (3G load) Interestingly IIRC my max ground launch speed is 69mph. Brian C. |
Use of weak links
On 6/2/2010 7:23 AM, Paul wrote:
On Wed, 02 Jun 2010 04:28:31 -0700, T8 wrote: Here's hoping that the signal to noise ratio of a one on one conversation with your CFI is better than that on r.a.s. (see concurrent thread on altimeter settings, for example :-)). Yours is a reasonable question that deserves a reasonable response. My $0.02: you are not being 'paranoid' about anything. -Evan Ludeman / T8 Thanks for the input everyone. I'll take the matter up with my CFI and if not successful will stick to aerotows while the rest of the club can risk their lives using the winch. Weak links are there to protect the structural integrity of the glider. If your club is not using weak links, they may be damaging the glider, which might not be obvious. You are still putting yourself at risk if you are flying a club glider that may have been damaged, regardless of whether you are winch launching or using aero tows. -- Mike Schumann |
Use of weak links
On Thu, 03 Jun 2010 19:43:46 -0500, brian whatcott wrote: Specifically what I am saying is that unless you are exceeding the Maximum Winch Launch speed of the glider it should be impossible to overstress the wings as the wing will stall before exceeding maximum structural load of the aircraft. Brian This is a perfectly sound argument in many phases of flight. But a tow capable of exerting enough force on a stalled structure will certainly break it. A winch need not relax when a wing stalls.... Visualize an airframe being hauled along at an AoA of 90 degrees, to exaggerate this point... This won't break the wing spars either. As long as the IAS is below VA (in other words: in the green range of the airspeed indicator), no control input at all can damage the glider - the definition of VA is that this is the speed under which a high speed stall will prevent exceeding the maximum g-load. So, as long as you are slower than VA, you are safe. (Of course - combined control inputs can indeed break the structure even below VA, usually by torsional load on the tail boom by a deflected rudder at speeds close to VA combined with significant yaw angle.) The problem of exceeding the Maximum Winch Launch speed is not the wing, but the attachment of the tow hook to the fuselage structure. Pretty hard to explain why you landed with the belly hook missing... Cheers Andreas Bye Andreas Better to think twice and write once. For instance, how does your ASI indicate at 90 deg AoA ? If an airframe is designed for 1.5 (the design factor) times limit load (often 4 g) then if it is pulled with a force exceeding this, at high AoA, wing breakage is guaranteed. Sincerely Brian W |
Use of weak links
On Thu, 3 Jun 2010 14:38:51 -0400, "Tim Mara" wrote: 80-200% for aero-towing * 100-200% for ground launching * of max certificated gross weight * Most amazing. This violates the POHs of all the gliders I know. Cheers Andreas Bye Andreas There you go again, Andreas :-) The thread indicated that the regs specify: poh, or if not specified, the other. Better to think twice and write once Brian W |
Use of weak links
Brian wrote:
On Jun 3, 6:43 pm, brian whatcott wrote: Brian wrote: /snip/ Specifically what I am saying is that unless you are exceeding the Maximum Winch Launch speed of the glider it should be impossible to overstress the wings as the wing will stall before exceeding maximum structural load of the aircraft. Brian This is a perfectly sound argument in many phases of flight. But a tow capable of exerting enough force on a stalled structure will certainly break it. A winch need not relax when a wing stalls.... Visualize an airframe being hauled along at an AoA of 90 degrees, to exaggerate this point... Brian W While technically correct, in practice it probably isn't much of a factor. For my 750lb glider with a 120sq.ft. of wing rated for 6g's and as 1g stall speed of 40 mph the 6g stall speed is 97mph. For the flat plate drag of the wing area to exceed 6g's on the wing a 120mph is required by my calculation, which means the winch operator is going to have be pulling me at 120mph since I am stalled and no longer have any angular acceleration. A 200% weak link should break at 69mph if I understand it correctly (3G load) Interestingly IIRC my max ground launch speed is 69mph. Brian C. There is plenty I don't know about gliders. That you believe a glider is designed for 6g limit loads for example. I thought the load limit was lower, on condition parachutes are worn? But then, there's plenty I don't know about sailplane design... Brian W |
#29
Use of weak links
On Jun 4, 6:54*pm, brian whatcott wrote:
I thought the load limit was lower, on condition parachutes are worn? Do any sailplanes require a parachute to be worn as a condition of operation. I don't know of any. Schleicher required equipment for my glider is a parachute or a cushion of a specified thickness. Andy |
#30
Use of weak links
On Jun 4, 7:41*pm, brian whatcott wrote:
Andreas Maurer wrote: On Thu, 03 Jun 2010 19:43:46 -0500, brian whatcott wrote: Specifically what I am saying is that unless you are exceeding the Maximum Winch Launch speed of the glider it should be impossible to overstress the wings as the wing will stall before exceeding maximum structural load of the aircraft. Brian This is a perfectly sound argument in many phases of flight. *But a *tow capable of exerting enough force on a stalled structure will certainly break it. A winch need not relax when a wing stalls.... Visualize an airframe being hauled along at an AoA of 90 degrees, to exaggerate this point... This won't break the wing spars either. As long as the IAS is below VA (in other words: in the green range of the airspeed indicator), no control input at all can damage the glider - the definition of VA is that this is the speed under which a high speed stall will prevent exceeding the maximum g-load. So, as long as you are slower than VA, you are safe. (Of course - combined control inputs can indeed break the structure even below VA, usually by torsional load on the tail boom by a deflected rudder at speeds close to VA combined with significant yaw angle.) The problem of exceeding the Maximum Winch Launch speed is not the wing, but the attachment of the tow hook to the fuselage structure. Pretty hard to explain why you landed with the belly hook missing... Cheers Andreas Bye Andreas Better to think twice and write once. For instance, how does your ASI indicate at 90 deg AoA ? If an airframe is designed for 1.5 (the design factor) * times limit load (often 4 g) then if it is pulled with a force exceeding this, at high AoA, * wing breakage is guaranteed. Sincerely Brian W Back to the OP question. It's absolute insanity to winch launch a glider with anything but the exact weak link demanded by the POH. There's simply no wiggle room - you have to do what the manual says. However, with that link, there's zero risk of overloading the wing structure. (If the POH doesn't specify a winch weak link, I wouldn't winch launch the glider.) While you're at it, buy a "preamble" from W&W (Tost) or Klaus Fey's (www.eqip.de) and don't try to cobble up one with rope, hardware store carabiners and a surplus 'chute. There's some real safety issues with how these things are put together you don't want to learn the hard way. |
Similar Threads | ||||
Weak link - single or reserve? | Tom Nau | Soaring | 20 | January 19th 08 07:34 PM |
Are Weak Links really Necessary for Aero Tow? | [email protected] | Soaring | 41 | September 19th 06 06:49 PM |
Garmin 430, weak Loc/VOR | Greg Esres | Instrument Flight Rules | 8 | January 24th 05 05:49 PM |
Weak link for PW-5 | Nyal Williams | Soaring | 4 | June 1st 04 08:46 AM |
American soldiers are weak... | Gordon | Military Aviation | 0 | July 17th 03 07:55 PM |
