Training Needed?
Old June 8th 11, 09:45 PM posted to rec.aviation.soaring
CF[_2_]
Default Training Needed?
I've an unrestricted private glider rating issused before 1994.. I believe
this measns I don't need a self launch endorsement? What training or
checkrides would I need to pilot a motorgliner like the Phoenix S-LSA
www.phoenixairusa.com I'm also an A&P I should be able to no my own
maintenance
Ads
Old June 8th 11, 10:15 PM posted to rec.aviation.soaring
R-Haggerty
maintenance
See this link for more info:
http://www.soaringsafety.org/ssf-06/MG-certs.pdf
If your rating is unrestricted it was most likely not properly issued.
What about winch launch or auto tow. Do you think you can do those without
training also ??
Old June 8th 11, 10:38 PM posted to rec.aviation.soaring
Tony[_5_]
have a read through FAR Part 61.31. See what applies to you. If you
received a motorglider certificate from the FAA before a certain date
(1997 I think) you do not need an endorsement to be legal.
Old June 8th 11, 10:47 PM posted to rec.aviation.soaring
Andy[_1_]
Nonsense!
In 79 I passed an FAA private flight test using aerotow. I was issued
private glider aerotow only. Later I passed a commercial flight test
using aerotow. I was issued commercial glider aerotow only. In 1981 I
passed commercial and CFI flight test using winch lauch. I was issued
and still, have "Glider" with no restriction on launch type. FAA does
not require me to have any further training to fly any glider launch
type including self launch, since I acted as pilot of command of a
self launch glider prior to the "grandfather" date.
My certificate is "unrestricted" and was properly issued.
Andy
Old June 8th 11, 10:55 PM posted to rec.aviation.soaring
R-Haggerty
Nonsense!
Andy
That may be fine for you since you flew a self launch prior to the Grandfather
date, but the original poster did not mention that he flew self launch or any of
the other launch methods prior to the "date". I have seen DPE's issue a glider
cert without the "aerotow only" clause by mistake. Do you think the FAA
questions the application or do they just go ahead and process it.
Old June 8th 11, 11:33 PM posted to rec.aviation.soaring
Tony[_5_]
Nonsense!
passed commercial and CFI flight test using winch lauch. *I was issued
and still, have "Glider" with no restriction on launch type. *FAA does
Andy
*That may be fine for you since you flew a self launch prior to the Grandfather
the other launch methods prior to the "date". *I have seen DPE's issue a glider
cert without the "aerotow only" *clause by mistake. *Do you think the FAA
since 1997, issuing glider certificates WITH an "aerotow only" clause
would be a mistake
Old June 9th 11, 01:29 AM posted to rec.aviation.soaring
R-Haggerty
maintenance
See also this link for opinions:
http://sites.google.com/site/motorgl.../licensing-faq
If you have the unrestricted glider rating than according to FAR 61.31.(j)(2)
you are good to go. However an insurance company may hold a diferent opinion as
to coverage.
Old June 9th 11, 01:45 AM posted to rec.aviation.soaring
this measns I don't need a self launch endorsement? *What training or
checkrides would I need to pilot a motorgliner like the Phoenix *S-LSAwww.phoenixairusa.com*I'm also an A&P I should be able to no my own
maintenance
If you have not had the training that would qualify you for the self
launch endorsment, you are unlikely to be
qualified to fly the motorglider anyway.
Take the time to get the training, you will be safer for having done
so and avoid any potential insurance issues.
The FAA instituted the endorsement process as a practical and
relatively painless way to handle this issue.
FWIW
UH
Old June 9th 11, 01:58 AM posted to rec.aviation.soaring
R-Haggerty
maintenance
If you seek proper training you could follow these guidelines
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/list/AC%2061-94/$FILE/ac61-94.pdf
Old June 9th 11, 04:38 AM posted to rec.aviation.soaring
T[_2_]
maintenance
Please define what you mean by "unrestricted glider rating", please
forgive my non knowledge of any reference to 1994 as it would apply to
gliders, unless that is the date the FAA changed their certification
practices.
Older glider certificates were issued with "aero tow only" or "ground/
winch launch only" restrictions. Those were removed in the 90s and the
certificate simply says "glider. The type of launch method authorized
or approved is now an instructor endorsement under 61.31(j).
You are still governed under 61.31(j) and would need a logbook
endorsement from a qualified glider instructor for "self launch".
More help needed ? Pintlar Home Built 9 March 21st 10 09:35 AM
ID needed Dingo[_4_] Aviation Photos 2 January 29th 10 11:57 PM
Tow Bar needed Burt Compton Soaring 0 January 20th 05 01:31 AM
Beech Baron training recommedation needed Tom Seneca Piloting 4 May 24th 04 02:26 PM
Just what we needed Jeff Franks Piloting 10 December 29th 03 05:24 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Copyright 2004-2022 AviationBanter.
