Tow Pilot Checkouts, Rough-Field Tri-Gears?
All -
Do any of the USA folks here on RAS operate in a club without a 2-seat towplane? If so, how do you check out new towpilots? Do you find simulated towing acceptable training? On a related topic: Given the dearth of Robins in the USA for tri-gear towing, does anyone have suggestions on a tri-gear towplane that can operate out of a rough grass strip? We now land on asphalt, but our takeoff area has some broad swales and occasional mole-holes. It has spawned legends of bent Cessna firewalls; so a 180 or 182 seems to be out of the running. Any alternatives out there that are capable of hauling up a loaded 2-seater like a G-103 or L-23? Thanks, --Noel |
On Nov 12, 5:28*pm, "noel.wade" wrote:
All - Do any of the USA folks here on RAS operate in a club without a 2-seat towplane? *If so, how do you check out new towpilots? *Do you find simulated towing acceptable training? On a related topic: Given the dearth of Robins in the USA for tri-gear towing, does anyone have suggestions on a tri-gear towplane that can operate out of a rough grass strip? *We now land on asphalt, but our takeoff area has some broad swales and occasional mole-holes. *It has spawned legends of bent Cessna firewalls; so a 180 or 182 seems to be out of the running. *Any alternatives out there that are capable of hauling up a loaded 2-seater like a G-103 or L-23? Thanks, --Noel Socata Rallye, one for sale here in Logan I think. |
At 01:00 13 November 2012, Tim Taylor wrote:
On Nov 12, 5:28=A0pm, "noel.wade" wrote: All - Do any of the USA folks here on RAS operate in a club without a 2-seat towplane? =A0If so, how do you check out new towpilots? =A0Do you find simulated towing acceptable training? On a related topic: Given the dearth of Robins in the USA for tri-gear towing, does anyone have suggestions on a tri-gear towplane that can operate out of a rough grass strip? =A0We now land on asphalt, but our takeoff area has some broad swales and occasional mole-holes. =A0It has spawned legends of bent Cessna firewalls; so a 180 or 182 seems to be out of the running. =A0Any alternatives out there that are capable of hauling up a loaded 2-seater like a G-103 or L-23? Thanks, --Noel Socata Rallye, one for sale here in Logan I think. Varga Kachina, Maule? |
On Nov 12, 4:28*pm, "noel.wade" wrote:
All - Do any of the USA folks here on RAS operate in a club without a 2-seat towplane? *If so, how do you check out new towpilots? *Do you find simulated towing acceptable training? On a related topic: Given the dearth of Robins in the USA for tri-gear towing, does anyone have suggestions on a tri-gear towplane that can operate out of a rough grass strip? *We now land on asphalt, but our takeoff area has some broad swales and occasional mole-holes. *It has spawned legends of bent Cessna firewalls; so a 180 or 182 seems to be out of the running. *Any alternatives out there that are capable of hauling up a loaded 2-seater like a G-103 or L-23? Thanks, --Noel Any airplane is going to have problems with runways with mole holes, you can drop a main tire into the hole as easily as nose wheels or tail wheels. A C180 is a taildragger, a C182 a nose dragger. So why is the 180 out of the running? We have a single seat Pawnee for towing, best tow plane made, Piper Pawnees. Simulated tow training works, we've used Super Cub, Decathlon, and C170 for training. First three tow flights for the new tow pilot, a CFIG is in the glider, first tow is normal, 2nd tow, worst student you can be, moving all around and box wake and slack line training. 3rd flight, pattern tow. Followed by critique and question/answer session. A good tow plane? Depending on where you are and density altitude issues. C150 with 150HP or better. C182 if light weight, high DA you'll not want full fuel. Super cub with 180HP. Scout. T |
One club I was in used a 180hp 150 with a 172 nose wheel. We operated off of pavement and the grass cross strip, as well as the grass along the edge of the paved runway. This is some ancient history, I vaguely remember that the nose wheel has some issues with shimmy, and there were some issues regarding the STC for a climb prop for that engine/airframe combo.
P9 |
On Nov 13, 6:19*pm, T wrote:
Any club trying to maintain more than one tow plane with only 600 tows per year is going to have financial issues. A Super Cub is a high capital investment. The concern of grounding for an AD for a single type (2 Pawnees) is understandable, but the capital investment of the second tow plane could be higher than the revenue lost while completing the AD. T Thanks for the info on your simulated tow regimen! Can I ask which club this is? Our club consistently does ~1300 tows per year. We never seem to use our towplanes evenly; often the "nicest" Pawnee gets 700-800 tows per year while the remaining 550-650 are split between the other two planes (effectively at a loss). My analysis of our club finances shows that 1300 tows is sufficient to support 2 towplanes as long as you use them equally (i.e. about 650 tows per plane); but definitely not 3 towplanes. Just as you've noted, doing less than about 600 tows per towplane just doesn't make economic sense (the fixed costs are way too high on a per-tow basis, you'd end up having to charge something like $65+ for a 3000' tow just to keep up with yearly costs - and at that rate you're not saving any money for long-term items like engines, paint, fabric, etc). --Noel |
Similar Threads | ||||
Gear Up, pt 7 - pilot Howard Hughes in a ploughed field.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | April 20th 07 02:21 PM |
Rough Field Landings | [email protected] | Piloting | 38 | December 19th 04 02:42 PM |
PIREP: 2I3 (Rough River State Park, Falls of Rough, KY) | Kyler Laird | General Aviation | 0 | March 1st 04 01:11 AM |
J-3 Checkouts/vacations | Dave | Owning | 9 | August 14th 03 10:32 PM |
J-3 Checkouts/vacations | Dave | Owning | 4 | August 11th 03 02:07 AM |
