Landing Check Lists
Old December 26th 05, 07:01 PM posted to rec.aviation.soaring
Default Landing Check Lists
I wonder how many different landing checklists are in use. If the list
you use is not USTALL, (Undercarriage, Speed, Trim, Airbrakes, Look out
for Traffic, Land), please post here and label the items.
Old December 26th 05, 07:08 PM posted to rec.aviation.soaring
On 26 Dec 2005 19:01:13 GMT, Nyal Williams
FUSTALL
Flaps
Undercarriage
Speed
TRim
Airbrakes
Look
Land.
Old December 26th 05, 07:15 PM posted to rec.aviation.soaring
FUSTALL
Flaps
Undercarriage
Speed
TRim
Airbrakes
Look
Land.
WUFSTALL
Water
Undercarriage
Flaps
Speed
Trim
Airbrakes
Look (traffic obstructions wind)
Land
What I wonder is *when* people run through their checklist. I do mine
before the IP so I have at least the time in the pattern to sort out any
problems (e.g. airbrake malfunction, wind direction different on ground
vs pattern altitude).
I've heard of some folks doing their list on downwind. Too late for my
comfort.
Shawn
Old December 26th 05, 07:32 PM posted to rec.aviation.soaring
WULF - Waterballast, U/C, loose articles, flaps.
in use. If the list
Airbrakes, Look out
items.
Old December 26th 05, 07:33 PM posted to rec.aviation.soaring
WUF - shortened to 'WU' since I don't have flaps and
to 'U(gh)' without the water.
in use. If the list
Airbrakes, Look out
items.
FUSTALL
Flaps
Undercarriage
Speed
TRim
Airbrakes
Look
Land.
WUFSTALL
Water
Undercarriage
Flaps
Speed
Trim
Airbrakes
Land
I do mine
to sort out any
different on ground
Too late for my
comfort.
Shawn
Old December 26th 05, 07:40 PM posted to rec.aviation.soaring
SWAFTS
Straps
Wheel (down)
Water (dumped)
Wind (speed and direction)
Approach Speed
Flaps
Traffic
Spoilers (check)
In use in Canada...
"Nyal Williams" wrote in message
Old December 26th 05, 07:49 PM posted to rec.aviation.soaring
I don't use a checklist, I configure the glider appropriate
for the stage of the flight.
Using a checklist which is not appropriate for the
glider being flown can mean that the automatic checklist
becomes an automatic response
in use. If the list
Airbrakes, Look out
items.
FUSTALL
Flaps
Undercarriage
Speed
TRim
Airbrakes
Look
Land.
WUFSTALL
Water
Undercarriage
Flaps
Speed
Trim
Airbrakes
Land
I do mine
to sort out any
different on ground
Too late for my
comfort.
Shawn
Old December 26th 05, 08:12 PM posted to rec.aviation.soaring
WUFSTALL
W - Water out
U - UNDERCARRIAGE DOWN AND LOCKED
F - FLAPS SET FOR LANDING
S - STRAPS ( BELTS ) TIGHT
T - TRIM FOR LANDING SPEED
A - AIRBRAKES / AIRSPEED / ANGLE TO RUNWAY
L - LOOSE OBJECTS ( NONE ) LANDING AREA CLEAR
L - LOOKOUT
Old December 26th 05, 08:18 PM posted to rec.aviation.soaring
This is a good question, since many standard checklists leave out
important things and add silly ones ("Land?" What, I'm going to forget
to land?!!).
Mine:
Wind (direction, strength, how strong will gradient/wind shadow be)
Ground (pick place to land, look for obstructions, wires, fences, pick
approach path to landing spot)
Gear (down and locked, and check)
Trim (pick speed appropriate to conditions, trim to it, configure
glider for landing including flaps and spoiler check)
Traffic (announce, look!)
Old December 26th 05, 10:09 PM posted to rec.aviation.soaring
For all landings, my pre-landing check is:
W- Water jettisoned.
U - Undercarriage down and locked.
L - Loose objects stowed away and, considering myself
as a potential loose object, straps tight.
F - Flaps set as appropriate.
For field landings I also do:
W - Wind speed and direction (estimate as best as possible)
W - Wires - power, telephone and electric fences
S - Size
S - Slope
S - Surface
S - Stock
T - Tramlines
Derek Copeland
leave out
important things and add silly ones ('Land?' What,
I'm going to forget
to land?!!).
Mine:
shadow be)
wires, fences, pick
it, configure
question about instrument proficiency check Sylvain Instrument Flight Rules 14 October 20th 05 09:11 AM
Tamed by the Tailwheel [email protected] Piloting 84 January 18th 05 04:08 PM
Slip to landing on PPG practical test Roger Worden Soaring 56 November 11th 04 09:38 PM
Diamond DA-40 with G-1000 pirep C J Campbell Owning 114 July 22nd 04 05:40 PM
