Where do main pin holes come from?
Where do those big holes in the spars of composite gliders come from?
You know, the ones where they put the bushings that you insert the main pins through? Somebody with a big drill drills them. http://www.youtube.com/watch?v=FZ3rISscO2I Thanks, Bob K. http://www.hpaircraft.com/hp-24 |
On 11/1/2010 4:07 PM, Bob Kuykendall wrote:
Where do those big holes in the spars of composite gliders come from? You know, the ones where they put the bushings that you insert the main pins through? Somebody with a big drill drills them. http://www.youtube.com/watch?v=FZ3rISscO2I Thanks, Bob K. http://www.hpaircraft.com/hp-24 Interesting to compare your technique with the way it is done at Jonker Sailplanes: http://www.jonkersailplanes.com/factorypictures8.htm |
That's a good way to make a one-off homebuilt. In production, they use
a jig to make sure the parts are interchangeable. Nov 1, 7:07*pm, Bob Kuykendall wrote: Somebody with a big drill drills them. http://www.youtube.com/watch?v=FZ3rISscO2I Thanks, Bob K. http://www.hpaircraft.com/hp-24 |
On Nov 1, 4:07*pm, Bob Kuykendall wrote:
Where do those big holes in the spars of composite gliders come from? You know, the ones where they put the bushings that you insert the main pins through? Somebody with a big drill drills them. http://www.youtube.com/watch?v=FZ3rISscO2I Thanks, Bob K. http://www.hpaircraft.com/hp-24 Bob, Your design for the parts and the tooling is simply amazing............I tacked in the rear lift pin tube yesterday evening. This AM Doug and I pulled the wings off and put them back on a couple of times and they slid right in just like the real thing. We finished the day by shear taping in the rear tube. Tomorrow the shop gets cleaned up and we head home. Brad |
Where do those big holes in the spars of composite gliders come from? You know, the ones where they put the bushings that you insert the main pins through? Somebody with a big drill drills them. http://www.youtube.com/watch?v=FZ3rISscO2I Thanks, Bob K. http://www.hpaircraft.com/hp-24 The video must have cut off before the obligatory "oh sh!@ that's the wrong spot" comment from the person doing the drilling to the owner of the glider. That's got me more than once. Darryl |
On Nov 1, 4:44*pm, Martin wrote:
That's a good way to make a one-off homebuilt. In production, they use a jig to make sure the parts are interchangeable. Yes, interchangability is a definite concern. But I didn't want to invest mondo dollars in locking down all of the interfaces until we'd finished one ship and made sure it all works. The tooling that I did build to ensure interchangability at the lift pin interfaces is shown in this Update on my Web site: http://www.hpaircraft.com/hp-24/update_1b_nov_10.htm It is similar in function to that used by Jonkers, except that as you observe it does not embody the locations of the main pin bores. Also, as I understand it, a lot of European ships aren't really all that interchangable. In fact, I don't know of a factory that would send you an entire brand new wing and guarantee that it would mount right up to an existing fuselage and opposite wing without at least some drilling or adjustment. What I've heard and read is that if you need to replace an entire wing they want to handle the fitment either at the factory or at their authorized service shop. And what they'll probably do there is either start with a blank spar stub and match-drill it to the good wing, or go ahead and bore out the bushings in the good wing and match drill and re-bush both of them together. And either of those techniques would guarantee "interchangability" for the ship at hand. Thanks, Bob K. |
On Nov 1, 4:45*pm, Brad wrote:
On Nov 1, 4:07*pm, Bob Kuykendall wrote: Where do those big holes in the spars of composite gliders come from? You know, the ones where they put the bushings that you insert the main pins through? Somebody with a big drill drills them. http://www.youtube.com/watch?v=FZ3rISscO2I Thanks, Bob K. http://www.hpaircraft.com/hp-24 Bob, Your design for the parts and the tooling is simply amazing............I tacked in the rear lift pin tube yesterday evening. This AM Doug and I pulled the wings off and put them back on a couple of times and they slid right in just like the real thing. We finished the day by shear taping in the rear tube. Tomorrow the shop gets cleaned up and we head home. Brad Sounds great, Brad! Bob K. |
Btw, those two seat jet trainers at Mojave look like Impalas. They
are Aermacchi MB-326 built under license in South Africa. The National Test Pilot School operates a few of them. |
On Nov 1, 8:10*pm, Bob Kuykendall wrote:
On Nov 1, 4:44*pm, Martin wrote: That's a good way to make a one-off homebuilt. In production, they use a jig to make sure the parts are interchangeable. Yes, interchangability is a definite concern. But I didn't want to invest mondo dollars in locking down all of the interfaces until we'd finished one ship and made sure it all works. The tooling that I did build to ensure interchangability at the lift pin interfaces is shown in this Update on my Web site: http://www.hpaircraft.com/hp-24/update_1b_nov_10.htm It is similar in function to that used by Jonkers, except that as you observe it does not embody the locations of the main pin bores. Also, as I understand it, a lot of European ships aren't really all that interchangable. In fact, I don't know of a factory that would send you an entire brand new wing and guarantee that it would mount right up to an existing fuselage and opposite wing without at least some drilling or adjustment. What I've heard and read is that if you need to replace an entire wing they want to handle the fitment either at the factory or at their authorized service shop. And what they'll probably do there is either start with a blank spar stub and match-drill it to the good wing, or go ahead and bore out the bushings in the good wing and match drill and re-bush both of them together. And either of those techniques would guarantee "interchangability" for the ship at hand. Thanks, Bob K. I put 2 wings together on an ASW-19 which were 100 serial numbers apart and the only thing I had to do was shim the lift pins. But it don't always go that way. Answer to your question is that those holes come from the wing pin hole fairy. What an easy question. UH |
On Nov 1, 4:15*pm, Greg Arnold wrote:
On 11/1/2010 4:07 PM, Bob Kuykendall wrote: Where do those big holes in the spars of composite gliders come from? You know, the ones where they put the bushings that you insert the main pins through? Somebody with a big drill drills them. http://www.youtube.com/watch?v=FZ3rISscO2I Thanks, Bob K. http://www.hpaircraft.com/hp-24 Interesting to compare your technique with the way it is done at Jonker Sailplanes: http://www.jonkersailplanes.com/factorypictures8.htm Impressive looking jig, but it also looks like they are using filter respirators for what they are spraying the wings with, which looks like a topcoat. Wonder what they are spraying... Darryl |
Similar Threads | ||||
Mystery holes. | Monk | Piloting | 16 | January 2nd 09 05:43 AM |
Covering holes | [email protected] | Soaring | 9 | May 2nd 08 05:57 PM |
Tube Fuse Oil Holes | John[_17_] | Home Built | 8 | March 21st 08 01:11 PM |
When Poorboys drill holes ...was: Drilling holes in steel tubing | wright1902glider | Home Built | 4 | November 4th 05 02:19 AM |
Filling Holes | AKperson | Owning | 1 | July 20th 05 03:54 PM |
