Wedekind sleeve
Old February 4th 14, 10:00 PM posted to rec.aviation.soaring
Hartley Falbaum[_2_]
Default Wedekind sleeve
Need the plastic inner bushing for a Wedekind sleeve on a 90 deg l'Hotelier connector.
Any ideas for source of supply? Google search no joy!
Thanks
Old February 4th 14, 10:08 PM posted to rec.aviation.soaring
Thanks
Are you referring to the plastic (red) safety sleeves?
If so, when I owned an LS-1f I was able to purchase from Pacific Aero sports
r/Jim
N9XL/H201B
Old February 5th 14, 02:45 AM
dbrunone dbrunone is offline
Member
First recorded activity by AviationBanter: Oct 2011
Wedekind sleeves are no longer made, neither are Uerling (spelling?). The "Red" sleeves are also not what you want, I believe they had some sort of issue, not exactly sure what.
The only sleeves I know of are known as "White LS" sleeves. I have a set of them on my LS1-f, they work awesome, and "installation" takes literally 5 seconds with no modification to the aircraft. Call Chris Klix at Pacific Aerosport, he sells them, I think mine were $35 per sleeve a few years ago. Good luck
Old February 5th 14, 07:34 AM posted to rec.aviation.soaring
Thanks
Wedekind sleeves and also spare parts are available from LTB Lindner http://www.ltb-lindner.com/home.104.html
Old February 5th 14, 12:54 PM posted to rec.aviation.soaring
Thanks
Many thanks! I have sent them an email. They were very good to work with, replacing the master brake cylinder on our G102 Club III
Wedekind sleeve for Std Cirrus John Galloway Soaring 8 July 9th 13 02:15 PM
Wedekind Sleeves for GROB ASTIR CS Juliet11[_2_] Soaring 2 April 1st 13 03:39 PM
Wedekind Safety Sleeves ContestID67 Soaring 3 March 5th 07 12:04 PM
Wedekind Safety Sleeves Huds Soaring 5 May 8th 05 03:07 AM
Source for Wedekind sleeves - AS-W20a Mark Grubb Soaring 7 April 6th 04 08:19 PM
