Coaxial generator development
Old August 3rd 08, 02:28 AM posted to rec.aviation.homebuilt
Default Coaxial generator development
On Aug 2, 3:38 pm, Ernest Christley wrote:
What d'ya think, veedubber?
Unit is from a Harley-Davidson.
9.5 lbs installed (including all mounting hardware).
$288.17 (including tax)
38 Amps
No belts or pulleys.
Seems like the way to go, doesn't it?
The first one I did like this was about 1970, using the dynamo from a
Honda 250cc motorcycle. At prop speeds it managed to produce enough
power for my ignition and an 8-track tape :-)
The later versions (as you are using) uses rare earth magnets... the
early jobbies used Alnico and weighed a ton. But the rare earth
magnets don't deal with heat very well and since the unit is only
about 50% effective, for every amps-worth of electrical output you've
got to deal with an amps-worth of heat. Usually, at prop speeds that
isn't a problem but spin it any faster and you can see some serious
side-effects due to overheating.
I mention this because of the 'submerged' location on your
installation. I think I can see a couple of oil pipes here that tells
me the excess heat is going to appear in your oil. You should know
that the rare-earth magnets tend to spall or flake when overheated.
I've also had problems keeping the suckers aligned, which is why I use
the rim of the central hole and five fasteners to try and keep things
on the same plane. They get balanced as a complete assembly, by the
way.
We appear to be using the same stator & rotor but a different reg/rec
module. (I'm using the one sold by Great Plains) When properly set-up
I've got about 1mm of axial clearance between the poles of the stator
and the magnets. At prop speeds (ie, 2800 to 3000 rpm) it doesn't
take much skew to cause contact. Since my installations are not
submerged they're pretty easy to inspect and the bright line caused by
the momentary contact is always accompanied by a spew of abrasive
residue, ground off of the magnets.
Being magnetic -- and external to the engine -- the residue isn't much
of a hazard but it isn't something I'd care to have in my oil.
Since I run mine at prop-speeds the output is rather modest, only 8A.
to 10A, even through the momentary peak output is rated at something
like 40A. But with an electronic ignition system you only need about
5A to power the ignition system and maintain the charge on a small
battery. Truth is, I didn't want a system capable of producing the
maximum amperage since it would only get turned into heat at the
rectifier/regulator module. (Indeed, I would have been perfectly
happy with the old style 10 ampere unit and wish Steve still sold
them.) If you'll look closely at the photos in my blog you can see
how I solved the problem :-)
-R.S.Hoover
Old August 3rd 08, 07:17 AM posted to rec.aviation.homebuilt
Ernest Christley
38 Amps
I'm not liking the sound of that. I'll be running it at 6000RPM, or so.
The intake air will be flowing over it, so that should do a lot to
keep it cool.
The thin line on top pumps oil into the gearbox, and the 3/8" line along
the bottom allows it to flow back into the sump. They're not really
connected to the generator in any significant way.
I need to verify, but I'm fairly certain that the reg/rec I'm using is a
switching type. It turns off the line when the power isn't needed.
Saving the generator from producing heat in both the rotor/stator and
generator.
I need to power ignition, injectors, pumps...and that's just to drive
the engine. There's radio's and lights that need a few electrons, too.
And off I go to take a look.
Old August 3rd 08, 03:48 PM posted to rec.aviation.homebuilt
RST Engineering
This may seem like a stupid idea, but good ideas sometimes come in stupid
clothes. In a normal air-cooled tractor engine, cold air comes in the
front, passes over and through the cylinders, and is exhausted through the
plenum chamber called the bottom of the cowl. Rapidly moving air, that
after it does it cooling job, is no longer of any use.
Remember back in dem halcyon days of the 50s and 60s we sometimes mounted
inefficient little generators on small pylons on the bottom of the airframe
and called them wind driven generators (the electrical equivalent of the
side-mounted venturi tube)?
I'm just wondering if anybody has used either this scrap dump air to run a
wind driven generator, or whether any one of a number of ways of generating
electricity from heat has been attempted to convert waste exhaust gas into
excited little electrons? SOrt of a turbogenerator, if you will.
"It is the mark of an educated mind to be able to entertain a thought
without accepting it."
--Aristotle
Old August 3rd 08, 05:03 PM posted to rec.aviation.homebuilt
Blueskies
"RST Engineering" wrote in message ...
Centrifugal blower run backwards...gotta watch out not to dam things up too much...
And...you could reverse drive it to pull air through the engine for cooling on the ground?
Old August 3rd 08, 06:09 PM posted to rec.aviation.homebuilt
Morgans[_2_]
generating electricity from heat has been attempted to convert waste
exhaust gas into excited little electrons? SOrt of a turbogenerator, if
you will.
Only problem I can see is that cooling runs on pressure differential, (as
you know) between the intake, and outlet.
Dam up the damn outlet, and it could have a drastic effect on the amount of
cooling air passing over the engine. People go to drastic measures to get
that outlet pressure low, like adding lips, ect, so I would not want to go
the other way with restricting the flow.
I would think that you would have to dam it up pretty good to get the 3-5 HP
you would probably need for a generator.
On the other hand, if you put a turbocharger hot section on the pipes, and
used that to drive a generator....?
Noah. Too big of a gear box would be needed to turn the high RPM of the
turbo down to prop RPM's for the generator.
Jim in NC
Old August 3rd 08, 06:15 PM posted to rec.aviation.homebuilt
Hahahahahaah,,, :-)
Don't be so silly :-) You're about two orders of magnitude out.
Minimum cool-down is going to take a pressure differential of about
3"H2O. With either suck-through or blow-through, for something like
an O-200 that's going to take about 3hp... about 2100 watts. You'd
need a couple of hundred pounds of batteries and a blower to match.
-R.S.Hoover
Old August 3rd 08, 06:23 PM posted to rec.aviation.homebuilt
Ernest Christley
I remember one company making such a contraption as a drop down
emergency back-up generator. As I recall, the problem with using them
full-time is their horrible overall efficiency.
I'd be careful with anything that pulled energy from the cooling
airstream. Like Blueskies said, you gotta watch that you're not damming
things up. If you have engine cooling air leaving the airplane still
cool, the first thing you'd want to do is close up and streamline the
cooling intakes to reduce drag.
There have been some interesting developments with materials utilizing
the Seebeck (sp?) Effect recently. The new materials are driving the
efficiency up. I think the ultimate generator would be a
cylinder-head/peltier-cooler-in-reverse combination.
Old August 3rd 08, 06:36 PM posted to rec.aviation.homebuilt
Ernest Christley
Lots of wind to cool around an exhaust pipe, and the rotary's exhaust is
noted for being exceptionally hot. Dang-it, Jim! Now you've got me
thinking again. Everytime I start doing that, by build time increases
by another three months.
Read this:
http://www.fieldlines.com/story/2005/11/2/31928/0770
Old August 3rd 08, 06:41 PM posted to rec.aviation.homebuilt
generator.
Dear Ernest,
I'm afraid that only addresses the power OUTPUT, not generation. So
long as the magnetic field is present and is being cut by the winding
of the coil, a voltage WILL appear across the coil, as will some
residual heating effects. The regulator can isolate this from the
battery but that only addresses the output-side of the equation.
That's a guess of course -- we're using different components. But in
a permanent-magnet type dynamo the Field is always 'on' so to speak --
there is no 'control' as is found in the typical generator-type dynamo
since there is no Field winding. In either case, I think your method
of installation calls for a bit more head-work.
-R.S.Hoover
E5-A generator-12V,50A jerry wass Restoration 0 April 8th 06 04:47 AM
Naval Air development history Larry Cauble Naval Aviation 0 October 16th 05 12:29 AM
XCSoar Still under development? Michael Pitoniak Soaring 0 November 30th 03 10:23 PM
Contra-Rotating Coaxial Rotor Helicopters James Cho Military Aviation 18 November 29th 03 07:48 AM
Is Falcon 5.0 in development? Radeon350 Simulators 7 July 21st 03 03:21 AM
