Iis there a weather chart with cloud base and tops depicted?
Here in the San Francisco Bay Area we've had coastal clouds in the
mornings with ceilings in the 1000-2000 range recently, 10-20 miles west of Oakland the clouds dissipate completely. I was wondering weather there exists a reliable way of determining the cloud tops (other than PIREPs). TIA |
A Skew-T would give you the temperature-dewpoint spread at various
locations...seems to me that there should be a number of reporting points in the Bay Area, although you could do it by lat-long. An altitude where the T-DP exceeds 3 degrees (maybe, 5 would be better) should be cloud-free. Go to http://rucsoundings.noaa.gov/, read the tutorials, etc at the bottom (especially the article from "The Front"), and have at it. Then go to www.chesavtraining.com to get acquainted with Scott Dennstaedt, meteorologist/CFII; buy his CD program on Skew-T for a real education. Scott participates in the AOPA and Pilots of America forums. Bob Gardner "Terence Wilson" wrote in message ... Here in the San Francisco Bay Area we've had coastal clouds in the mornings with ceilings in the 1000-2000 range recently, 10-20 miles west of Oakland the clouds dissipate completely. I was wondering weather there exists a reliable way of determining the cloud tops (other than PIREPs). TIA |
Area Forecast.
On Fri, 30 May 2008 09:39:00 -0700, Terence Wilson
wrote: Here in the San Francisco Bay Area we've had coastal clouds in the mornings with ceilings in the 1000-2000 range recently, 10-20 miles west of Oakland the clouds dissipate completely. I was wondering weather there exists a reliable way of determining the cloud tops (other than PIREPs). TIA Here's a site that I use: http://www.usairnet.com/cgi-bin/laun...l=avn&state=TX Note that in the URL, the airport ID (KSGR) and state would have to change - but it's a resonably decent site. Good luck. Karl - PP/ASEL/IA |
If we're both looking at the same site, Karl, I can see the cloud bases but
nothing about tops. Bob Gardner "Karl" wrote in message ... On Fri, 30 May 2008 09:39:00 -0700, Terence Wilson wrote: Here in the San Francisco Bay Area we've had coastal clouds in the mornings with ceilings in the 1000-2000 range recently, 10-20 miles west of Oakland the clouds dissipate completely. I was wondering weather there exists a reliable way of determining the cloud tops (other than PIREPs). TIA Here's a site that I use: http://www.usairnet.com/cgi-bin/laun...l=avn&state=TX Note that in the URL, the airport ID (KSGR) and state would have to change - but it's a resonably decent site. Good luck. Karl - PP/ASEL/IA |
Just noticed that in their FAQ they say unequivocally that the site does not
provide tops. Bob Gardner "Karl" wrote in message ... On Fri, 30 May 2008 09:39:00 -0700, Terence Wilson wrote: Here in the San Francisco Bay Area we've had coastal clouds in the mornings with ceilings in the 1000-2000 range recently, 10-20 miles west of Oakland the clouds dissipate completely. I was wondering weather there exists a reliable way of determining the cloud tops (other than PIREPs). TIA Here's a site that I use: http://www.usairnet.com/cgi-bin/laun...l=avn&state=TX Note that in the URL, the airport ID (KSGR) and state would have to change - but it's a resonably decent site. Good luck. Karl - PP/ASEL/IA |
wrote in : Here in the San Francisco Bay Area we've had coastal clouds in the mornings with ceilings in the 1000-2000 range recently, 10-20 miles west of Oakland the clouds dissipate completely. I was wondering weather there exists a reliable way of determining the cloud tops (other than PIREPs). TIA A little research yielded this information: http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/702ef0bfe021ab3986256bb2005c1458/$FILE/sec1-5.pdf In addition, pilots are a vital source of upper-air weather observations. In fact, aircraft in flight are the only means of directly observing turbulence, icing, and height of cloud tops. For more information on PIREPs, see Section 3. Recently some US and other international airlines have equipped their aircraft with instruments that automatically send weather observations via a satellite downlink. These are important observations which are used by NCEP in their production of forecasts. 1999 http://adds.aviationweather.noaa.gov/pireps/java/ PIREPs Java Tool http://aviationweather.gov/obs/radar/ Radar Coded Message Composite Image with Tops http://www.crh.noaa.gov/gjt/?n=tweb Transcribed Weather Broadcasts http://www.srh.noaa.gov/srh/cwwd/faqs/twb.htm TRANSCRIBED WEATHER BROADCAST ROUTE FORECAST To assist pilots in preflight and enroute planning. The forecast provides expected conditions (sky condition, cloud tops, surface visibility, weather and obstructions to visibility, and significant surface wind) along and 25 nautical miles either side of a specified route. TWEB route forecasts are disseminated via appropriate Federal Aviation Administration (FAA) communications systems,including low frequency navigational aids. CONTACT: Judson Ladd, W/SR1x2 Regional Aviation Meteorologist (817) 978-2652 Ext. 109 Inquire he http://www.weather.gov/tg/radarimage.html The NCEP/AWC composite image is produced which includes aviation used cloud tops, convective sigmets, and outlooks. |
TWEB products have been discontinued.
Bob Gardner "Larry Dighera" wrote in message ... On Fri, 30 May 2008 09:39:00 -0700, Terence Wilson wrote in : Here in the San Francisco Bay Area we've had coastal clouds in the mornings with ceilings in the 1000-2000 range recently, 10-20 miles west of Oakland the clouds dissipate completely. I was wondering weather there exists a reliable way of determining the cloud tops (other than PIREPs). TIA A little research yielded this information: http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/702ef0bfe021ab3986256bb2005c1458/$FILE/sec1-5.pdf In addition, pilots are a vital source of upper-air weather observations. In fact, aircraft in flight are the only means of directly observing turbulence, icing, and height of cloud tops. For more information on PIREPs, see Section 3. Recently some US and other international airlines have equipped their aircraft with instruments that automatically send weather observations via a satellite downlink. These are important observations which are used by NCEP in their production of forecasts. 1999 http://adds.aviationweather.noaa.gov/pireps/java/ PIREPs Java Tool http://aviationweather.gov/obs/radar/ Radar Coded Message Composite Image with Tops http://www.crh.noaa.gov/gjt/?n=tweb Transcribed Weather Broadcasts http://www.srh.noaa.gov/srh/cwwd/faqs/twb.htm TRANSCRIBED WEATHER BROADCAST ROUTE FORECAST To assist pilots in preflight and enroute planning. The forecast provides expected conditions (sky condition, cloud tops, surface visibility, weather and obstructions to visibility, and significant surface wind) along and 25 nautical miles either side of a specified route. TWEB route forecasts are disseminated via appropriate Federal Aviation Administration (FAA) communications systems,including low frequency navigational aids. CONTACT: Judson Ladd, W/SR1x2 Regional Aviation Meteorologist (817) 978-2652 Ext. 109 Inquire he http://www.weather.gov/tg/radarimage.html The NCEP/AWC composite image is produced which includes aviation used cloud tops, convective sigmets, and outlooks. |
On Mon, 2 Jun 2008 08:28:25 -0700, "Bob Gardner"
wrote in : TWEB products have been discontinued. Well, perhaps inquiring of the person who was responsible for TWEB, and asking him which products now contain the cloud top data might be fruitful: Judson Ladd, W/SR1x2, Regional Aviation Meteorologist, (817) 978-2652 Ext. 109. |
I listened to a TWEB earlier today, so they are not discontinued. (ENM).
"Bob Gardner" wrote in : TWEB products have been discontinued. Bob Gardner |
Similar Threads | ||||
Actual Cloud Tops | john smith | Owning | 7 | July 15th 06 12:01 AM |
Weather chart oddity? | Dylan Smith | Piloting | 8 | April 21st 06 04:47 PM |
cloud base forecasting question | William_F | Piloting | 7 | June 24th 05 02:55 PM |
Cloud Tops/bases forecast? | David | Instrument Flight Rules | 4 | October 20th 04 10:08 PM |
Winter Cloud Tops | O. Sami Saydjari | Instrument Flight Rules | 5 | January 9th 04 09:11 PM |
