#101
Conventional v tricycle gear
On Sat, 12 Jul 2008 20:10:47 +0800, Stealth Pilot
wrote: $aus6,000 to fill the tanks with avgas! There used to be a DC-3 at Hampton Airfield. Its alternate airport was in Massachusetts. Whenever he took off, the owner used Runway 20 regardless of which way the wind was blowing because he didn't want to spend the extra money to take off to the north and have to circle back to the south. Blue skies! -- Dan Ford Claire Chennault and His American Volunteers, 1941-1942 new from HarperCollins www.FlyingTigersBook.com |
#102
Stealth Pilot wrote in
: On Fri, 11 Jul 2008 22:36:42 GMT, Marty Shapiro wrote: Stealth Pilot wrote in m: what were they like to fly? the dak I mean. it is one aircraft I'd really love to fly just to see what they were like, having read Gann's masterpieces. I had an old airline dak pilot as a customer once. he reckoned that they were a really sweet aircraft to fly and lifting the tail on takeoff was a non event. Stealth Pilot Why not fly one and see for yourself? See http://www.incredible-adventures.com/dc3.html Or, you can go all the way and get a DC-3 type rating added to your certificate at http://www.douglasdc3.com/ I'm sure there must be some places closer to you. (No, I haven't done either of these, but it's fun to think about!) $aus6,000 to fill the tanks with avgas! thats an enthusiasts aeroplane. the bugger is that in not being an american citizen it isnt available to me. or is it.... marty that's very interesting. thats blown the next few nights :-) Stealth Pilot Stealth - I believe it is now possible for a non-US citizen to get flight training in the U.S., but there is a bunch of TSA BS you've got to go through. The flight schools will know the drill and what it required. There is an article on how a US company trained Mexican Air Force pilots for DC-3 operations at http://findarticles.com/p/articles/m...2/ai_n21451823 A quick Google search turned up 3 places in Australia which have DC- 3s. They need to get DC-3 pilots from somewhere and might know of a place there which will let you purchase a DC-3 lesson. http://www.onedge.com.au/adventures/...roductid=16199 http://virginblue.godo.com.au/activity/SJCH102/gift http://www.shortstop.com.au/gooney.html Enjoy. -- Marty Shapiro Silicon Rallye Inc. (remove SPAMNOT to email me) |
#103
More_Flaps wrote in
: On Jul 12, 6:03*am, Bertie the Bunyip wrote: wrote in news:47b87223-e8df-49d1-a167-6efa72157885 @c58g2000hsc.googlegroups.com: Well, three pointing it means you're going as slowly as you can -- guts football would be to have it hanging by the props and touch down tail first -- so when it's on the ground it's done flying, and breaking should be effective. Did the 3's props have a beta setting? With Reverse pitch the damned thing would probably stop short of the numbers! No, it didn't have beta or reverse. Only the larger piston trikes had tha t for the most part. I'm intrigued by the *wheel landing shorter concept, but I'll have to t ry it for myself. I'll only have one taildraggr to do it with, bu tI will be flying out of some very short fields so if there's an advantage I'd use i t. It's true, you push the stick forward and stomp on the brakes. Much more downforce for braking than a 3 point Maybe, but if the braking you have is sufficient to get the airplane's tail up in the three point attitude, then the co-efficient of braking is enough to rotate the airplane around the main wheels in either case. If this is so, then thee is no more braking available anywa. In the wheel landing scenario, there is more of the airplane on the wrong side of the deceleration vector than there is in the three point attitude. Simply put, you tip the airplane forward enough and the thing will nose over by itself. And you're not too far from that tipping point in a nose low attitude even with the aircraft static with many taildraggers. This limits the amount of brake you may apply nose low since the only thing acting against your braking is the horizontal stab and whatever tiny bit of work gravty is accomplishing over deceleration. In the 3 point attitude this vector is altered considerably, and more brake can be applied than in the nose low scenario, providing the Cf is enough and the brakes themselves are powerful enough, to raise the tail from three point. In my experience, it usually is. If the surface is slimy, like wet grass, applying more downforce will only increase the Cf appreciably if you are managing to dig a few ruts! This is the way I see it, but the proof is in the pudding. I'll just have to try t at the next opportunity and decide for myself. Bertie |
#104
"Bertie the Bunyip" wrote in message ... Maybe, but if the braking you have is sufficient to get the airplane's tail up in the three point attitude, then the co-efficient of braking is enough to rotate the airplane around the main wheels in either case. If this is so, then thee is no more braking available anywa. In the wheel landing scenario, there is more of the airplane on the wrong side of the deceleration vector than there is in the three point attitude. Simply put, you tip the airplane forward enough and the thing will nose over by itself. And you're not too far from that tipping point in a nose low attitude even with the aircraft static with many taildraggers. This limits the amount of brake you may apply nose low since the only thing acting against your braking is the horizontal stab and whatever tiny bit of work gravty is accomplishing over deceleration. In the 3 point attitude this vector is altered considerably, and more brake can be applied than in the nose low scenario, providing the Cf is enough and the brakes themselves are powerful enough, to raise the tail from three point. In my experience, it usually is. If the surface is slimy, like wet grass, applying more downforce will only increase the Cf appreciably if you are managing to dig a few ruts! This is the way I see it, but the proof is in the pudding. I'll just have to try t at the next opportunity and decide for myself. Bertie You're totally full of ****. |
#105
On Jul 13, 11:07 pm, "Maxwell" luv2^fly99@cox.^net wrote:
"Bertie the Bunyip" wrote in 8.18... Maybe, but if the braking you have is sufficient to get the airplane's tail up in the three point attitude, then the co-efficient of braking is enough to rotate the airplane around the main wheels in either case. If this is so, then thee is no more braking available anywa. In the wheel landing scenario, there is more of the airplane on the wrong side of the deceleration vector than there is in the three point attitude. Simply put, you tip the airplane forward enough and the thing will nose over by itself. And you're not too far from that tipping point in a nose low attitude even with the aircraft static with many taildraggers. This limits the amount of brake you may apply nose low since the only thing acting against your braking is the horizontal stab and whatever tiny bit of work gravty is accomplishing over deceleration. In the 3 point attitude this vector is altered considerably, and more brake can be applied than in the nose low scenario, providing the Cf is enough and the brakes themselves are powerful enough, to raise the tail from three point. In my experience, it usually is. If the surface is slimy, like wet grass, applying more downforce will only increase the Cf appreciably if you are managing to dig a few ruts! This is the way I see it, but the proof is in the pudding. I'll just have to try t at the next opportunity and decide for myself. Bertie You're totally full of ****. And you repeatedly demonstrate yourself to be a moron. At least MX provides humor for the rest of us, you're a waste of bandwidth. |
#106
"Maxwell" luv2^fly99@cox.^net wrote in newsqzek.13942$Fj5.2750
@newsfe23.lga: "Bertie the Bunyip" wrote in message ... Maybe, but if the braking you have is sufficient to get the airplane's tail up in the three point attitude, then the co-efficient of braking is enough to rotate the airplane around the main wheels in either case. If this is so, then thee is no more braking available anywa. In the wheel landing scenario, there is more of the airplane on the wrong side of the deceleration vector than there is in the three point attitude. Simply put, you tip the airplane forward enough and the thing will nose over by itself. And you're not too far from that tipping point in a nose low attitude even with the aircraft static with many taildraggers. This limits the amount of brake you may apply nose low since the only thing acting against your braking is the horizontal stab and whatever tiny bit of work gravty is accomplishing over deceleration. In the 3 point attitude this vector is altered considerably, and more brake can be applied than in the nose low scenario, providing the Cf is enough and the brakes themselves are powerful enough, to raise the tail from three point. In my experience, it usually is. If the surface is slimy, like wet grass, applying more downforce will only increase the Cf appreciably if you are managing to dig a few ruts! This is the way I see it, but the proof is in the pudding. I'll just have to try t at the next opportunity and decide for myself. Bertie You're totally full of ****. Oh do tell us whow you do it, wannabe boi. Bwawahwhahwhahwhahhwhahwhahwhahwhahwha! Bertie |
#107
wrote in message ... And you repeatedly demonstrate yourself to be a moron. At least MX provides humor for the rest of us, you're a waste of bandwidth. Sorry Robert, but if you find Mx entertaining, your are clearly the clueless moron,,,or just another Burtie sock. |
#108
: wrote in message .. . And you repeatedly demonstrate yourself to be a moron. At least MX provides humor for the rest of us, you're a waste of bandwidth. Sorry Robert, but if you find Mx entertaining, your are clearly the clueless moron,,,or just another Burtie sock. Well, we al find you entertaining, anyway! Anthony has nowhere near your level of idiocy.... Bertie |
#109
In article , Bertie the
Bunyip says... "Maxwell" luv2^fly99@cox.^net wrote in : wrote in message .. . And you repeatedly demonstrate yourself to be a moron. At least MX provides humor for the rest of us, you're a waste of bandwidth. Sorry Robert, but if you find Mx entertaining, your are clearly the clueless moron,,,or just another Burtie sock. Well, we all find you entertaining, anyway! At least those of us with an appreciation for Vogon poetry do -- "Tis an ill wind that blows no minds" |
#110
Maxwell luv2^fly99@live.^com wrote in
: In article , Bertie the Bunyip says... "Maxwell" luv2^fly99@cox.^net wrote in : wrote in message m.. . And you repeatedly demonstrate yourself to be a moron. At least MX provides humor for the rest of us, you're a waste of bandwidth. Sorry Robert, but if you find Mx entertaining, your are clearly the clueless moron,,,or just another Burtie sock. Well, we all find you entertaining, anyway! At least those of us with an appreciation for Vogon poetry do True... Now I'm depressed. Bertie |
Similar Threads | ||||
Tricycle gear Cub? | Ken Finney | Piloting | 8 | September 17th 07 11:43 PM |
Hiroshima/Nagasaki vs conventional B-17 bombing | zxcv | Military Aviation | 55 | April 4th 04 07:05 AM |
Tricycle Midget Thought | Dick | Home Built | 4 | March 26th 04 11:12 PM |
WarPac War Plans-any conventional? | Matt Wiser | Military Aviation | 1 | December 8th 03 09:29 PM |
tricycle undercarriage | G. Stewart | Military Aviation | 26 | December 3rd 03 02:10 AM |
