#21
Fuel tank balance
Doug wrote: There is no percent power guage that gives a direct measure of the engines output. Sure there is. JPI has one in their engine monitors. There are others. |
Fuel tank balance
I'd never heard of these, but, right you are! Check out
http://www.jpinstruments.com/edm_700.html Quite the guage! Newps wrote: Doug wrote: There is no percent power guage that gives a direct measure of the engines output. Sure there is. JPI has one in their engine monitors. There are others. |
Fuel tank balance
Newps wrote: Doug wrote: There is no percent power guage that gives a direct measure of the engines output. Sure there is. JPI has one in their engine monitors. There are others. I suppose it depends on what you mean by "direct measure". Power delivered by a rotating shaft is RPM * Torque. RPM is easy to measure directly, torque is somewhat more difficult. In any case, the JPI gizmo doesn't measure torque. It measures manifold pressure, and fuel flow, and intake air temperature, and maybe a few other things, and computes how much power the engine must be delivering based on those inputs. That's not quite the same thing as measuring the output directly. I'm not saying that what the JPI does isn't useful. Just that it doesn't fit my definition of "direct measure". |
#24
Fuel tank balance
Roy Smith wrote: In article , Newps wrote: Doug wrote: There is no percent power guage that gives a direct measure of the engines output. Sure there is. JPI has one in their engine monitors. There are others. I suppose it depends on what you mean by "direct measure". Power delivered by a rotating shaft is RPM * Torque. RPM is easy to measure directly, torque is somewhat more difficult. In any case, the JPI gizmo doesn't measure torque. It measures manifold pressure, and fuel flow, and intake air temperature, and maybe a few other things, and computes how much power the engine must be delivering based on those inputs. That's not quite the same thing as measuring the output directly. I'm not saying that what the JPI does isn't useful. Just that it doesn't fit my definition of "direct measure". As long as it's accurate, who cares? |
#25
Fuel tank balance
"Newps" wrote: I'm not saying that what the JPI does isn't useful. Just that it doesn't fit my definition of "direct measure". As long as it's accurate, who cares? I would not accept as accurate a calculation that leaves out essential parameters. It's an educated guess. -- Dan C172RG at BFM |
#26
Fuel tank balance
with 4 main body tanks fore to aft
2 wing tanks (1 each wing) 2 Main tanks 1 each side over each nacelle of 2 engines each (4 engines) and 1 weapons bay tank added, #20,000# apprx other two weapons bays carry 54, 500# gravity weapons Total full up fuel load, apx 210,000#, aircraft weight, apx 200,000#, weapons, 27,000# plus racks (4,000#) Take off weight, apx 441,000#, Max GW for take off 477,000# -Starting with full fuel all tanks, all tanks feed to the Mains.. keep the mains above 10,000 # -Burn from tanks 1 and 4 first (apx 18,000pph at this weight) -Trap 35,000# fuel between the body tanks number 1 and 4 tanks for CG control later in the flight -Move 35,000# trapped fuel between tanks 1 and 4 to maintain CG when wings sweep -Burn off body tanks 2 and 3 -Burn off the weapons bay tank -Burn off the wing (if fuel imbalance in wings we can cross feed, more than 10,000# fuel imbalance will cause roll control problems) may have to cross feed if one or more engines on the same side are shut down -Now down to 10,000# in each main and 35,000# in tanks 1 and 4 (total 55,000#) -You best be at the IAF for the primary airport, 55,000 is enough to weather divert to the approved alternate (apx 13,000pph fuel flow) and land with apx 20,000-25,000# in the tanks.. -Fuel slosh.. 20,000# is just 10,000# in each main tank, direct feed to the engines -Not enough weight forward to keep nose wheel steering squat switch engaged for ground taxi, you need to be above 7,000# each tank to start the approach BT "Mxsmanic" wrote in message ... Is there any reason to drain fuel tanks in any way other than symmetrically in normal flight? I notice that most aircraft have complex controls for fuel flow from the tanks, and I wonder if there are things one is suppposed to do during normal flight, or if this is just to provide for possible equipment failures or a need to shift the center of gravity of the aircraft in an emergency. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#27
Fuel tank balance
The PT6 engine measures torque, which is shown in ft.lbs,
although the higher rated engines often use percent. Measuring torque cost money, it isn't "cost effective" on low powered engines. "Roy Smith" wrote in message ... | In article , | Newps wrote: | | Doug wrote: | | | There is no percent power guage that gives a direct measure of the | engines output. | | | Sure there is. JPI has one in their engine monitors. There are others. | | I suppose it depends on what you mean by "direct measure". | | Power delivered by a rotating shaft is RPM * Torque. RPM is easy to | measure directly, torque is somewhat more difficult. In any case, the JPI | gizmo doesn't measure torque. It measures manifold pressure, and fuel | flow, and intake air temperature, and maybe a few other things, and | computes how much power the engine must be delivering based on those | inputs. That's not quite the same thing as measuring the output directly. | | I'm not saying that what the JPI does isn't useful. Just that it doesn't | fit my definition of "direct measure". |
#28
Fuel tank balance
Dan Luke wrote: "Newps" wrote: I'm not saying that what the JPI does isn't useful. Just that it doesn't fit my definition of "direct measure". As long as it's accurate, who cares? I would not accept as accurate a calculation that leaves out essential parameters. It's an educated guess. No, it's either accurate or it's not. Compare what the JPI says to what the chart in the POH says. If it's accurate then it is irrelavant how it got the information. |
#29
Fuel tank balance
Mxsmanic wrote: Robert M. Gary writes: working by itself. Okay, but that's an exceptional situation. For a normal flight, do you have to change the fuel settings? I know Lindbergh did, but that was an unusual aircraft. If you ran all your gas out of one tank you would only have 1/2 the capacity. I switch tanks every hour. -Robert |
#30
Fuel tank balance
Mxsmanic wrote: Doug writes: How do I determine how much actual propulsive thrust I'm generating? I see a throttle setting, manifold pressure, RPM, and pitch, but I'm not sure how to set all this in order to increase or decrease total thrust. Set power using throttle to the appropriate setting on your manifold pressure. If you fly around full throttle down low you'll over stress your engine. At cruise you usually leave the throttle full forward (unless you have turbo charged). You can't set the propeller pitch but you can adjust the propeller RPM. Higher RPMs are good for higher power but for cruise you want something less. Your POH will show you a manifold pressure(throttle)/RPM (prop control) combo for the power setting you are looking for. We usually refer to it as say 23/25 (meaning 23" manifold pressure, 2500 RPM). Dumping extra fuel into the cylinders is good when climbing but not so good during cruise. In cruise we lean the plane out for a more optimal mixture. You car does the same. For the same RPM your car will set a higher mixture during acceleration vs. in freeway driving. Most planes have a EGT (exhaust temp ) to measure mixture, but you can do it just by sound in a more basic plane. Planes don't do this all at once for the same reason I have to shift my car, because they don't use an automatic system. There are such systems out there for planes but they are very expensive since it would be very bad if it didn't work correctly. -robert |
Similar Threads | ||||
Exposed Electrical Wires in Boeing 737 Fuel Tanks! | Larry Dighera | Piloting | 0 | July 17th 06 06:13 PM |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
C-172 Fuel | [email protected] | Piloting | 23 | November 23rd 05 09:39 PM |
More long-range Spitfires and daylight Bomber Command raids, with added nationalistic abuse (was: #1 Jet of World War II) | The Revolution Will Not Be Televised | Military Aviation | 161 | September 25th 03 07:35 AM |
First flight tests of systems to mitigate fuel tank explosions | Peter Duniho | Piloting | 1 | July 16th 03 10:49 PM |
