Tire Access for ASK-21
Anybody have a suggestion for how to easily get at the valve stem on an ASK-21 main wheel without dropping the shroud? Would like to make checking the pressure part of our club's daily routine, but hard to enforce if we have to unscrew the main gear fairing every time. Thanks...
On Friday, July 11, 2014 12:21:07 PM UTC-5, NG wrote:
Anybody have a suggestion for how to easily get at the valve stem on an ASK-21 main wheel without dropping the shroud? Would like to make checking the pressure part of our club's daily routine, but hard to enforce if we have to unscrew the main gear fairing every time. Thanks... Marks on the tire and fairing. When they are lined up, the valve stem is pointed at the hole (you maybe have just added) in the fairing. |
At 18:04 11 July 2014, Steve Leonard wrote:
On Friday, July 11, 2014 12:21:07 PM UTC-5, NG wrote: Anybody have a suggestion for how to easily get at the valve stem on an A= SK-21 main wheel without dropping the shroud? Would like to make checking t= he pressure part of our club's daily routine, but hard to enforce if we hav= e to unscrew the main gear fairing every time. Thanks... Marks on the tire and fairing. When they are lined up, the valve stem is p= ointed at the hole (you maybe have just added) in the fairing. Our club and many others leave the shroud off permanently as it jams the wheel when filled with grass. I do not believe there is a marked deterioration in peformance. Terry Walsh |
On Friday, July 11, 2014 1:21:07 PM UTC-4, NG wrote:
Anybody have a suggestion for how to easily get at the valve stem on an ASK-21 main wheel without dropping the shroud? Would like to make checking the pressure part of our club's daily routine, but hard to enforce if we have to unscrew the main gear fairing every time. Thanks... We cut the fairing in half and added a splice plate bonded to the front half that has 3 nut plates per side to screw the rear half to the front. This makes it removable fairly easily. UH |
On Friday, July 11, 2014 10:21:07 AM UTC-7, NG wrote:
Anybody have a suggestion for how to easily get at the valve stem on an ASK-21 main wheel without dropping the shroud? Would like to make checking the pressure part of our club's daily routine, but hard to enforce if we have to unscrew the main gear fairing every time. Thanks... Drill a hole in the fairing that aligns with the stem and use valve extender. Or remove it so you can truly inspect the tire/gear. |
Similar Threads | ||||
ACCESS GRANTED! | GARY BOGGS | Soaring | 2 | May 24th 08 04:23 PM |
newsserver access | Martin Hotze | Piloting | 7 | April 21st 07 04:35 PM |
OLC Access | [email protected] | Soaring | 2 | March 24th 06 06:08 PM |
GA Access to DCA | john smith | Piloting | 0 | August 20th 05 10:25 PM |
ng access | Stu & Kathy Fields | Home Built | 4 | April 1st 04 06:09 PM |
