Common error in center of gravity calculation
Old May 25th 10, 07:53 AM posted to rec.aviation.soaring
Matt Herron Jr.
Default Common error in center of gravity calculation
I thought I should highlight an error that is being made in
calculating CG that appears to be widespread, and that can lead to a
miscalculation in center of gravity by up to 10% (or possibly more) of
the allowable CG range.
The problem arises from a difference in the way Europeans and
Americans calculate the CG.
In the US, we commonly use the formula: Center of gravity = total
moments / Total mass. So for an empty glider CG calculation, that
would be (datum to main wheel * main wheel weight) + (Datum to tail
wheel * tail wheel weight) / Total weight. This is the method taught
in the FAA “Glider Flying Handbook” (Sec 5-13)
In many European glider manuals (ASW20B and ASG29E, for example), the
formula given for the glider CG = ((Horizontal distance between the
wheels * tail wheel weight) / Total weight) + (datum to main wheel).
BOTH formulas are correct, but the problem arises when the tail wheel
datum is confused with the distance between the tail wheel and main
wheel. So far I have seen three or four examples of this. Once the
error was even made on a written weight and balance sheet done by a
repair facility.
I noticed the pattern when users of the weight and balance calculator
“SeeG” would inquire as to why the program did not yield the same
results as their own calculations, only to discover that they had made
this error in their own calculations long ago, and the SeeG result was
the correct one.
The resulting error is not obvious because it is not wildly off of
expectations, and therefore often goes undetected. For a Ventus C,
using the “main to tail” distance rather than the “datum to tail”
distance for an empty glider weighing results in the CG being placed
too far forward by 5%. For a Discus B, the same error places the CG
too far forward by 9% of the allowable range.
Whatever method is used; the SeeG program, a spreadsheet, or a pencil,
it might be worth double checking that the tail wheel distance being
used is appropriate for the CG formula being employed. If you think
your CG is at 80% aft, you might actually be flying at 90% aft or
more.
Matt Herron (Jr)
http://www.glideplan.com
Old May 25th 10, 03:16 PM posted to rec.aviation.soaring
Andy[_1_]
The formula provided by Schleicher for the ASW 28 recognizes that the
position of the main gear relative to the leading edge datum changes
with the mass of the glider. An accurate CG determination for this
glider, and any other with sprung main gear, requires that the
position of the main wheel is measured at the mass used for CG
determination and with the glider at the specified pitch attitude.
Andy (GY)
Old May 25th 10, 03:25 PM posted to rec.aviation.soaring
In the US, we commonly use the formula: *Center of gravity = total
moments / Total mass. *So for an empty glider CG calculation, that
wheel * tail wheel weight) / Total weight. *This is the method taught
formula given for the glider CG = *((Horizontal distance between the
wheels * tail wheel weight) / *Total weight) + (datum to main wheel).
BOTH formulas are correct, but the problem arises when the *tail wheel
wheel. *So far I have seen three or four examples of this. Once the
repair facility.
the correct one.
expectations, and therefore often goes undetected. *For a Ventus C,
distance for an empty glider weighing results in the *CG being placed
too far forward by 5%. *For a Discus B, the same error places the CG
used is appropriate for the CG formula being employed. *If you think
more.
Matt Herron (Jr)http://www.glideplan.com
If one follows the diagram provided in flight manual, this should not
be a problem. Almost every error I see in W&B info on ships I look at
is because someone did not apply the info from the original diagram
when doing home made spread sheet for calculation.
One of these guys is an FAA examiner- amazing.
FWIW
UH
FWIW
Old May 25th 10, 04:41 PM posted to rec.aviation.soaring
Richard[_9_]
repair facility.
the correct one.
more.
Matt,
I was helping a friend do a GC on a ASW 20 he purchased recently and
saw this common error. The error was made by a repair shop.
Your program helped identifing the problem, we were scratching our
head for a while. It actually could have been serious as the
previous owner was not a light weight and was putting 20 lbs in the
tail to compensate.
This 20 lbs with the erronious CG calc looked OK. When run with the
correct caclulation the pilot was flying with a CG of 128% aft.
Thanks for your program.
Richard
www.craggyaero.com
Longest X/C Using Gravity Launch? sisu1a Soaring 2 November 13th 09 07:28 PM
Center: Say type aircraft... Me: Citabria 7GCBC, Center: Ahhhhh??? Nik Piloting 13 October 4th 06 06:13 AM
Sub-gravity sensation Rod Soaring 4 March 7th 04 04:20 PM
Gravity Waves [email protected] Soaring 0 December 10th 03 07:13 AM
Gravity launch Mark James Boyd Soaring 9 October 8th 03 04:32 AM
