should I become familiar with glass?
Old September 5th 10, 02:53 AM
gpick gpick is offline
Junior Member
First recorded activity by AviationBanter: Sep 2010
Default should I become familiar with glass?
Hello again. I met with my flight instructor today just to get some information. Now it's time to schedule a flight. The ideal plane for me would be the 09 DA40 with the G1000, but it is $35 more per hour more than either the 03 DA40 or 07 172. Therefore, I am flying the two latter planes and deciding which will be better for me. There are both the same price per hour.
2003 Diamond DA40 with: IFR/VFR Garmin 530W WAAS-certified GPS/NAV/COMGarmin 430 GPS/NAV/COMBendix/King KCS 55A Slaved HSIBendix/King KAP 140 Dual-Axis AutopilotGarmin GTX 327 Digital TransponderGarmin GMA 340 Audio PanelXM Weather Datalink (AKA: NOT GLASS)
2007 Cessna 172 with: IFR/VFR
Garmin 1000 Integrated Avionics System
Bendix King KAP 140 Dual-Axis Autopilot
XM Weather Datalink (AKA: Glass)
The reason for the choice here is the famous high vs. low wing debate. Also, the diamond tops out 10 knots faster. Any suggestions or opinions as to which I should go with? Again, I will be flying both to decide eventually. Is glass going to be more prevalent down the road and more expensive to transition then, rather than start with it now?
Old September 5th 10, 10:24 AM posted to rec.aviation.piloting
a[_3_]
price per hour.
GLASS)
gpick
My observation is most general aviation careers, with the exception of
instructing and A&E, involve low winged airplanes. Never the less,
transitions from one to the other is simply not a big deal, so choose
what you like for primary training. Ground effect is more pronounced
in low wing.
You'll probably have to learn to fly behind conventional as well as
glass instrumentation, start with the less costly. The money ($35 an
hour?) you'll save before you move to glass will be more than the cost
of learning glass later when you move on to your instrument rating.
Keep things simple during primary training.
Old September 5th 10, 04:20 PM posted to rec.aviation.piloting
Dudley Henriques[_2_]
price per hour.
GLASS)
gpick
Transition into either high or low wing from the other should be a
minimum time checkout. Familiarization with glass is the future for
pilots either flying professionally or for pleasure.
Dudley Henriques
Old September 5th 10, 05:24 PM posted to rec.aviation.piloting
vaughn[_3_]
"gpick" wrote in message
information.
Since you haven't told us anything about yourself, and especially what type of
flying you plan to do in the future, how can we possibly give you a meaningful
answer?
If you think you may want to own an airplane but have a limited budget, then the
plane you buy will be unlikely to have a glass panel. Therefore, you may want
to train with "steam gauge" instruments..
If you are seeking the "fast track" to the front seat of an airliner, perhaps
you want to start with glass; but perhaps not, because you may find yourself
instructing in simple aircraft along the way.
There really is no 100% right answer. I see a day when pilots who have never
flown a "steam gauge" panel will be seen in the same light as those who have
never flown a tailwheel.
Vaughn
Old September 5th 10, 05:49 PM posted to rec.aviation.piloting
Capt. Geoffrey Thorpe
Fly what ever you find most comfortable. The differences between are pretty
minor in the grand scheme of things.
I would point out that all three of the aircraft you mention have the
tailwheel on the wrong end. But, with any luck, you will overcome that
handicap some day.
Geoff
Old September 5th 10, 07:08 PM
Junior Member
in low wing.
Keep things simple during primary training.[/quote]
I'm sorry if my post wasn't clear, but the DA40 with the glass was the aircraft that was $35 more per hour. The 172 with the glass is actually $5
cheaper than the DA40 without glass. That's why I think it would be more expensive later if I didn't do the $5 cheaper glass setup.
Old September 5th 10, 10:38 PM
Junior Member
in low wing.
cheaper than the DA40 without glass. That's why I think it would be more expensive later if I didn't do the $5 cheaper glass setup.[/quote]
Old September 5th 10, 10:40 PM
Junior Member
information.
answer?
Vaughn
Sorry Vaughn, I recently posted on this site and assumed it would be the same people answering most likely. I am 16 and just started flight training. I have not yet chosen which aircraft I'm going to stick with. I fly in the 172 on wednesday and the da40 on friday. I hope to have a career in aviation rather than just a hobby which is why I am considering the 172 at all. For the glass panel.
Even if I do learn on the G1000, will it help me in the future? Will the panels not just be outdated and I'll have to learn a completely new setup down the road anyway? Or will it perhaps give me at least a basic knowledge on glass panels in general?
Old September 6th 10, 12:32 AM posted to rec.aviation.piloting
sambodidley
handicap some day.
Geoff
Right! Here's the low wing I transitioned to from the high wing Piper J3.
Tail draggers rule. grin
http://www.warbirdalley.com/bt13.htm
Old September 6th 10, 03:48 PM posted to rec.aviation.piloting
"sambodidley" wrote in message
handicap some day.
Geoff
J3. Tail draggers rule. grin
Now THAT's a transition.
Geoff
Sounds familiar... Marc Ramsey[_2_] Soaring 4 February 23rd 08 07:39 PM
Does this look familiar? C J Campbell Piloting 14 September 10th 04 06:55 AM
What's your most familiar route? Ben Jackson Piloting 30 April 19th 04 12:30 PM
Anyone familiar with Whiteman AFB? John A. Weeks III Military Aviation 6 April 3rd 04 08:26 PM
Anyone familiar with ATC-510 simulator? John Harlow Piloting 4 August 9th 03 05:28 PM
