Taking the plunge into ownership.
Old July 30th 03, 08:26 PM
Default Taking the plunge into ownership.
Well, today I put a deposit on an airplane! It's a 1961 C-175B with an
upgrade to an O360 with a constant speed prop. What a sweet plane, always
hangared with 2268TT. I only will own 1/3 of it, but the other two partners
only flew 200 hours in the last three years total. Can't wait to take her
out. Guess I will find out how the partnerships work after all. Apparently
they split the hangar and annuals equally in 1/3's and other things come
from the kitty (each partner pays $20.00 per hour flown). When there is not
enough money in the kitty, the balance is calculated according to who is
flying the plane the most. That part seems a bit strange to me. If I fly 10
hours to florida and land twice, I don't wear the tires as much as the guy
doing touch and goes for an hour.
Any insight on how other partnerships split these kinds of things?
Also, apparently I don't have to pay any sales tax because I am buying
shares of a corporation rather than a plane. Is this right?
Old July 30th 03, 08:46 PM
Newps
There is a C175 here that has the O-470R in it. Talk about short field
performance.
Old July 30th 03, 09:23 PM
Rosspilot
When there is not
Here is one conventional method:
Each partner pays 1/3 of the annual insurance, parking, and annual inspection
labor. Each partner pays 1/3 of any upgrades (new avionics, strobes,
panel-mounted GPS, etc). Each partner pays 1/3 of any administrative costs of
maintaining the partnership (books, accountant, taxes, attorneys, banking).
Each partner gets 1/3 of any end-of-the-year tax benefit (depreciation) that
ownership may allow.
EVERYTHING ELSE is "consumables" (fuel, oil, filters, belts, fuses, bulbs,
tires, brakes, batteries, washing or detailing, replaceable parts and the
associated labor to install or repair them.)
Those items should be paid for based on flight time. The "type of flying" is
not normally factored, but you could argue that touch'n'gos, instructional
flight, etc might be harder on the aircraft and make an agreement to adjust for
that if all 3 partners are equally anal-rententive G.
(example: 1 hour of T'N'G = 1.3 hrs CC).
Not the ONLY method, but seems fair to me.
www.Rosspilot.com
Old July 30th 03, 11:44 PM
Steve
If I fly 10
This kind of attitude is what causes partnerships to fail.
Old July 31st 03, 03:06 AM
David Megginson
"Steve" writes:
If I fly 10 hours to florida and land twice, I don't wear the tires
as much as the guy doing touch and goes for an hour.
Right. Besides, you burn a lot more gas and oil, and run the engine a
lot hotter in cruise than you do in circuits (at least, that's what
I've found with my plane). Everything balances out in the end.
All the best,
David
David Megginson, , http://www.megginson.com/
Old July 31st 03, 03:25 AM
Ray Andraka
You'll also be the guy incurring the emergency away-from-home maintenance,
which invariably seems to be more expensive than getting things fixed at
home (if for nothing else other than overnight shipping of the out of
stock part so you can get home).
David Megginson wrote:
"Steve" writes:
All the best,
David
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
Old July 31st 03, 05:34 PM
mfp
What I find interesting is that a deposit has already been put on the table
to join the partnership, but now there are questions on how things are done.
Shouldn't this be what was explored, considered, and questioned, prior to
putting the money on the table??
MP
"Wayne" wrote in message
news
partners
not
10
Old August 2nd 03, 07:11 PM
Tom Legg
I've seen arrangements where not only hours are factored, but also
cycles. This is more typical in Turbine partnerships than in simple
piston aircraft, as turbines have roatables that are rated in cycles, as
opposed to hours. Anymore, I can't even think in terms of $20 an hour
dry rate. Hell I haven't flown an airplane that costs under $300/hr to
operate in so long that that low of a number shocks me. It becomes a lot
more important when you are in a partnership where the dry rate is, say
$800/hr. Then usually there is an additional charge of like $150/cycle.
Tom Legg
*** Sent via http://www.automationtools.com ***
Add a newsgroup interface to your website today.
Monerai rights ownership fred D Home Built 3 June 9th 04 03:31 AM
Air Force captain finds passion in taking on physical challenges, By Kent Harris, Stars and Stripes Otis Willie Military Aviation 0 May 25th 04 01:31 AM
Fractional Ownership in Europe N-reg airplne EDR Aviation Marketplace 2 December 12th 03 10:42 AM
What should the flap postions be while taking off? Shi Jin Military Aviation 2 September 10th 03 02:22 AM
Questions about taking the plunge into a/c ownership SD Owning 7 July 23rd 03 06:52 AM
