We have a Cherokee 140. I want to know if anybody knows the simple
and cheap trick to clean our headliner. It is actually in fine condition, but it has a LOT of brownish spotting on it, apparently caused by moisture (you know, condensation, leakage, etc. - not that OUR plane leaks!). It looks like crap. The headliner appears to be a heavy fabric, almost seems like it is vinyl coated. I tried washing it, spraying it with a variety of liquids (ammonia, bleach and water, Formula 409). They helped to reduce the intensity of the spots by about 30%, which is not nearly enough. Ideas? Tim Long CMA, CA |
Ideas?
Try Castrol's "Super Clean." That stuff seems to remove just about anything. We use it on literally every tough stain at the hotel. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Prime wrote in message ...
We have a Cherokee 140. I want to know if anybody knows the simple and cheap trick to clean our headliner. We used vinyl spray paints to rejuvenate the interior of our 1970 Cardinal. The headiner, plastics and vinyl panels now look pristine. We used two types of paints (Krylon fusion and SEM vinyl paint) http://www.krylon.com/product/gp_pro....asp?sgID=GP07 http://www.levineautoparts.com/semvinandpla.html Our initial test showed that it took fewer coats to cover stains/old color with Krylon so we chose it for the headliner and upper plastic/panels. and used the more durable SEM paint for lower plastic/panels. The Krylon fusion worked great on the headliner and plastics but remained sticky on the vinyl panels (after weeks!). We ended up repainting the vinyl panels with SEM paints. Krylon fusion paints can be found at many hardware stores including walmart. We had to order the SEM paint through an autopart. This was part of the reason going with Krylon. It we were to do it all over again, we would just use SEM vinyl paint for everything. Do remember to take pictures during the headliner removal process. We did not any pictures or notes!. The entire interior was stripped bare last summer and we had just recently put everything back together (had to wait for the annual then was 'grounded' 3 months for an engine rebuilt). Everything felt into places in the end but it would have been easier with better planning. |
(hlongworth) wrote in message . com...
Prime wrote in message ... We have a Cherokee 140. I want to know if anybody knows the simple and cheap trick to clean our headliner. I can second the use of SEM paints. They work well, and make the part look like new. Stained plastic is almost impossible to clean, since the stain is often IN the plastic, not on it. That said, the plastic interior parts in many older airplanes are brittle and falling apart from heat and UV damage. Not worth fixing. Google "Plane Plastics" for affordable replacements. Dan We used vinyl spray paints to rejuvenate the interior of our 1970 Cardinal. The headiner, plastics and vinyl panels now look pristine. We used two types of paints (Krylon fusion and SEM vinyl paint) http://www.krylon.com/product/gp_pro....asp?sgID=GP07 http://www.levineautoparts.com/semvinandpla.html Our initial test showed that it took fewer coats to cover stains/old color with Krylon so we chose it for the headliner and upper plastic/panels. and used the more durable SEM paint for lower plastic/panels. The Krylon fusion worked great on the headliner and plastics but remained sticky on the vinyl panels (after weeks!). We ended up repainting the vinyl panels with SEM paints. Krylon fusion paints can be found at many hardware stores including walmart. We had to order the SEM paint through an autopart. This was part of the reason going with Krylon. It we were to do it all over again, we would just use SEM vinyl paint for everything. Do remember to take pictures during the headliner removal process. We did not any pictures or notes!. The entire interior was stripped bare last summer and we had just recently put everything back together (had to wait for the annual then was 'grounded' 3 months for an engine rebuilt). Everything felt into places in the end but it would have been easier with better planning. |
I bought a pack of those Armour All wipes and was amazed with how well
they cleaned up the interior plastic and headliner. The headliner did not get as clean as the rest of the plastic because the headliner in my Dakota 236 has a weave pattern. But these wipes did remove enough to make a drastic difference. I bought the orange kind, and I found that they also worked really well on the exterior of the plane for oil marks and bird poop! Greg King KVNY Prime wrote in message ... We have a Cherokee 140. I want to know if anybody knows the simple and cheap trick to clean our headliner. It is actually in fine condition, but it has a LOT of brownish spotting on it, apparently caused by moisture (you know, condensation, leakage, etc. - not that OUR plane leaks!). It looks like crap. The headliner appears to be a heavy fabric, almost seems like it is vinyl coated. I tried washing it, spraying it with a variety of liquids (ammonia, bleach and water, Formula 409). They helped to reduce the intensity of the spots by about 30%, which is not nearly enough. Ideas? Tim Long CMA, CA |
There is a quick and easy way to make a Piper headliner look good. Use
shoe polish. The kind that is in liquid form with the sponge applicator. I think the brand that many of us remember is "Kiwi". It takes a while to do it, but it covers most discolored spots and usually leaves a uniform color. It is a LOT less messy than vinyl sprays and dyes. You might want to get the plane up to about 65+ degrees F to use the stuff (heated hangar or warm Southern climate). You have to tip the bottle upside down and, if I remember right, touch the sponge enough to get it to soak up some polish. You may have to depress the sponge enough to scrunch the rubber collar that holds it. Put a rubber glove on one hand. The stuff may drip so cover up the interior. Last guy I saw who did it transformed a discolored, spotted headliner into like-new condition. Try it on a small spot to see if you like the result. Good Luck, Mike Prime wrote: We have a Cherokee 140. I want to know if anybody knows the simple and cheap trick to clean our headliner. It is actually in fine condition, but it has a LOT of brownish spotting on it, apparently caused by moisture (you know, condensation, leakage, etc. - not that OUR plane leaks!). It looks like crap. The headliner appears to be a heavy fabric, almost seems like it is vinyl coated. I tried washing it, spraying it with a variety of liquids (ammonia, bleach and water, Formula 409). They helped to reduce the intensity of the spots by about 30%, which is not nearly enough. Ideas? Tim Long CMA, CA __________________________________________________ _____________________________ Posted Via Uncensored-News.Com - Accounts Starting At $6.95 - http://www.uncensored-news.com The Worlds Uncensored News Source |
I second the use of Kiwi white shoe polish.
You may have to do a few "coats" but it works great! John |
On Tue, 10 Feb 2004 11:51:21 GMT, "John"
wrote: I second the use of Kiwi white shoe polish. You may have to do a few "coats" but it works great! WHITE!!? What am I gonna do now with this cordovan headlliner? Don |
Mike Spera wrote: There is a quick and easy way to make a Piper headliner look good. Use shoe polish. The kind that is in liquid form with the sponge applicator. I've not tried it, but I would think that leather dye might work a little better. George Patterson Love, n.: A form of temporary insanity afflicting the young. It is curable either by marriage or by removal of the afflicted from the circumstances under which he incurred the condition. It is sometimes fatal, but more often to the physician than to the patient. |
| Thread Tools | |
| Display Modes | |
| Simple & Cheap Tricks for your plane | Jay Honeck | Owning | 79 | April 21st 04 03:46 PM |
