Flow cloaking... I wonder if there are aeronautical possibilities...
Old August 14th 11, 11:34 PM posted to rec.aviation.soaring
sisu1a
Default Flow cloaking... I wonder if there are aeronautical possibilities...
Interesting article about Duke engineers applying their passive,
engineered material light/sound cloaking techniques to water,
theoretically (substantially) reducing the amount of drag generated by
a boat's hull by 'tricking' the surrounding water into standing still.
http://www.eurekalert.org/pub_releas...-esw081111.php
-paul
Old August 15th 11, 12:04 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Default Flow cloaking... I wonder if there are aeronauticalpossibilities...
theoretically (substantially) reducing the amount of drag generated by a
It will be interesting to see if it works, but I don't think it will help
us much, apart from the possibility of reducing friction drag in the
fuselage. The reason: since the whole point of this cloaking seems to be
to prevent momentum transfer to the surrounding fluid while a wing
generated lift by transferring momentum to the surrounding air, it ses to
me if you put the stuff on a wing, it would stop the wing from doing
anything useful.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old August 15th 11, 04:06 PM posted to rec.aviation.soaring
Dan Marotta
"Martin Gregorie" wrote in message
anything useful.
org |
Are you saying, then, that the velocity of the air moving over the top of
the wing will be reduced relative to that over the bottom? What would
Bernoulli say?
Old August 15th 11, 10:01 PM posted to rec.aviation.soaring
help us much, apart from the possibility of reducing friction drag in
the fuselage. The reason: since the whole point of this cloaking seems
to be to prevent momentum transfer to the surrounding fluid while a
wing generated lift by transferring momentum to the surrounding air, it
ses to me if you put the stuff on a wing, it would stop the wing from
doing anything useful.
of the wing will be reduced relative to that over the bottom? What
would Bernoulli say?
In the most general case a wing is a device that generates lift by
imparting downward momentum to the surrounding air in such a way that
that the resulting accelerating force counterbalances the force of
gravity acting on the aircraft. As the main effect of this 'cloaking'
seems to be to reduce momentum transfer from the moving body to the
surrounding fluid it seems to me that the 'cloaking' would also reduce
the amount of lift the wing would produce under normal flow conditions.
I wasn't being so specific about velocities or saying anything about
Bernoulli.
I don't much care for the application of Bernoulli to wing sections: that
theory applies to flow inside a pipe while airflow over a wing is not so
enclosed. Better aerodynamicists than I think its application to wing
sections is questionable. AFAICR straight application of Bernoulli can't
account for the upflow field in front of a wing and it certainly can't
account for the measured flow over a wing being so much faster than that
under it that air molecules separated by the LE don't rejoin at the TE:
the molecules passing over the top surface are long gone before molecules
passing under the lower surface arrive at the TE.
OTOH, if you were applying Prandtl..... My guess is that the cloaking
effect would reduce circulation.
org |
Old August 16th 11, 04:48 PM posted to rec.aviation.soaring
Dan Marotta
Thanks for a great explanation! My field is electrical engineering, though
I often wish I'd gone the aero path...
Bernoulli.
org |
SPOT Possibilities Tim Taylor Soaring 9 December 13th 08 04:50 PM
Oil for flow vis Steve Leonard Soaring 0 December 6th 07 01:40 AM
V8 fuel flow Robert Bates Home Built 34 January 24th 05 04:41 AM
V-4 Missile Possibilities robert arndt Military Aviation 42 January 23rd 04 06:40 AM
EXCITING NEW POSSIBILITIES John Roake Soaring 0 December 9th 03 01:59 AM
