Oudie 2 airspace files
Old June 30th 14, 06:17 AM posted to rec.aviation.soaring
2G
Default Oudie 2 airspace files
I discovered that there are no airports south of Cedar City, about 37 degrees. I have checked all of the US airspace files. Does anyone know where I can get more complete airspace files?
Thanks, Tom
Old June 30th 14, 07:00 AM posted to rec.aviation.soaring
Paul Remde
Hi Tom,
What waypoint and airspace file are you using?
Try the new ones I created recently. They are available he
http://www.cumulus-soaring.com/seeyou.htm#Downloads
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
_______________________________________________
"2G" wrote in message
Thanks, Tom
Old June 30th 14, 05:05 PM posted to rec.aviation.soaring
Dan Marotta
If you can use .cup files on your oudie, this link points to a file with
all the US turnpoints:
https://www.dropbox.com/s/zj8ostk242...d%20States.cup
Dan Marotta
Thanks, Tom
Old June 30th 14, 05:20 PM posted to rec.aviation.soaring
2KA
Tom,
Sounds like you are really looking for an airport database, not airspace files. In any case you can find both on my website at http://www.soaringdata..info. To make your own airport database, go to the airports tab. Enter a center airport identifier and a radius, and out will pop a CUP file (or other of your choosing).
Lynn Alley
"2KA"
Old July 1st 14, 09:08 PM posted to rec.aviation.soaring
2G
On Monday, June 30, 2014 9:20:31 AM UTC-6, 2KA wrote:
Tom,
Sounds like you are really looking for an airport database, not airspace files. In any case you can find both on my website at http://www.soaringdata.info. To make your own airport database, go to the airports tab. Enter a center airport identifier and a radius, and out will pop a CUP file (or other of your choosing).
Lynn Alley
"2KA"
You are exactly correct: I was selecting airspace files when I should have been selecting waypoint files (who thinks of airports as waypoints, but that is the way it is!).
Thanks for all of the replies!
Tom
airspace file for oudie Blake Seese 9V Soaring 2 February 18th 14 06:58 PM
Oudie not making valid IGC files Tony[_5_] Soaring 2 May 31st 11 06:44 AM
US-Canada airspace/border files available Tuno Soaring 2 April 4th 10 12:25 AM
(USA) current TFRs available as airspace files Tuno Soaring 3 November 30th 08 06:11 AM
(USA) Soaring airspace files from NFD -- now available Tuno Soaring 11 December 23rd 07 05:15 PM
