A quick question:
On a Ventus2C main wheel inner tube, does it require a long or a short valve stem ? How to identify what is in there right now, without disassembling the main wheel ? Looks like the main wheel is a standard 5 inch Tost wheel with disk brake. 3U |
short TR87
also TOST come out with a special tire for the later Discus / Ventus gliders due to the standard 500x5 tires rubbing on the gear frames...Wings & Wheels should ahev both these tires and innetr tubes in stock. tim wrote in message ... A quick question: On a Ventus2C main wheel inner tube, does it require a long or a short valve stem ? How to identify what is in there right now, without disassembling the main wheel ? Looks like the main wheel is a standard 5 inch Tost wheel with disk brake. 3U |
| Thread Tools | |
| Display Modes | |
| valve stem thread length too short | [email protected] | Soaring | 3 | August 12th 13 05:05 PM |
| ASW-24 Main Wheel Removal | Lauren Rezac | Soaring | 5 | March 19th 12 05:20 PM |
| Glider Main Wheel Dolly | Jim[_18_] | Soaring | 0 | March 9th 11 05:19 PM |
| main wheel dollies, plans? | [email protected] | Soaring | 1 | July 18th 07 07:55 AM |
| Brass Ball Valve,Gas Valve,Needle Valve,Angle Valve,Hose Bibcock Sale on good price | valvetom | Piloting | 0 | November 28th 06 03:25 AM |
