Do all transponder and ADS-B units require external antenna
Old March 17th 15, 12:26 AM posted to rec.aviation.soaring
Jonathan St. Cloud
Default Do all transponder and ADS-B units require external antenna
Was wondering if all transponder and ADS-B units require an external antenna to be mounted on the beautiful flowing lines of a glider? Is there a way to have an internal antenna?
Old March 17th 15, 01:21 AM posted to rec.aviation.soaring
Well, it depends. Metal gliders have to have external antennas for everything
since they're natural Faraday cages. Fiberglass gliders are transparent to
the microwave frequencies, so they can have internally mounted antennas.
More modern carbon fiber gliders are Faraday cages, but they often have
fiberglass tails to accommodate internal antennas. Still, I've seen
external transponder antennas on modern gliders.
Matt
JS are mounting their XPDR antennas in the fin. An elegant, low drag solution. If by ADB-B you're referring to out, your XPDR is going to do that job for you, ie. same antenna. If you're referring to the antenna of a certified GPS source such as a Trig TN70 or Freeflight 1201 then I've only seen external mount antennas. Having said that, I don't believe the manufacturers consider gliders at all as they are the standard, surface mount, 'do not paint' variety you find on metal aircraft. Shame really.
CJ
homemade external/internal antenna for handheld. gorgon Home Built 11 March 20th 08 10:38 PM
External antenna for air band handheld radio ToMasz General Aviation 1 January 26th 07 10:59 PM
How to hook handheld up to external antenna? Roy Smith Owning 6 January 26th 04 05:05 PM
External GPS Antenna Jim Weir Owning 0 November 29th 03 05:12 AM
External GPS Antenna Jim Weir Aviation Marketplace 0 November 29th 03 05:10 AM
