AD note for G-103, Grob two seat gliders
Old October 30th 15, 05:06 PM posted to rec.aviation.soaring
Robert M
Default AD note for G-103, Grob two seat gliders
A new AD note has been issued by the FAA concerning the airbrake locking system of all models of the G-103 glider certificated in any category. This means it applies to G-103s in the EXPERIMENTAL category too.
AD 2015-22-04 becomes effective 4 December 2015. And has two different compliance times. It is available at: http://www.airweb.faa.gov/Regulatory...e?OpenFrameSet
The AD references two Service Bulletins issued by the Type Certificate holder, Fiberglas Technik Rudolf Lindner GmbH in Germany. http://ltb-lindner.com/
The SBs are available at Lindner's web site.
SB-G07 Instructions for installing an inspection opening to the underside of the wings.
SB-G08 Instructions for checking the locking force of the airbrake system and adjusting it if necessary, and inspection the locking lever for cracks. It also calls for this inspection to be performed at each Annual Inspection.
Lindner is working on a permanent fix which I assume would include replacing the locking lever in question. That may take a while.
Many G-103s already have the inspection hole installed. They are a great help when doing the inspection for cracks in the locking lever and mandatory for adjusting the over center locking force. I highly recommend installing the inspection holes even if your initial inspection shows no cracks and the locking force is within limits,
If you have questions contact me at 505 269-8234
Robert Mudd
Composite Aircraft Repair
Moriarty, New Mexico.
Old October 31st 15, 03:51 AM posted to rec.aviation.soaring
Bill T
We got a heads up based on the European AD equivalent release, Knowing the FAA would follow. Our Annual inspection was due so we completed and logged the SB inspections. All was good.
Now the AD says "unless already completed" comply within 30days. We are done until our next annual. Thanks for the heads up JS.
We do not have the inspection ports in the lower wing, we were able to inspect and take pictures with a long lighted bore scope through the wing root.
Interesting comment about installing those inspection ports, are clear plastic covers available?
BillT
Old October 31st 15, 03:47 PM posted to rec.aviation.soaring
Robert Mudd
Robert, as you will recall from our phone call, I suffered an uncommanded spoiler deployment earlier this year in a Twin Astir while on a winch launch.. I'm glad to see this AD issued.
Old October 31st 15, 05:04 PM posted to rec.aviation.soaring
bumper[_4_]
BillT
Polycarbonate sheet (aka Lexan), easy to machine/cut with woodworking tools, hell for stout.
http://www.amazon.com/Polycarbonate-.../dp/B00CPRCQ9E
Old November 1st 15, 12:40 PM posted to rec.aviation.soaring
Robert Mudd
The new AD is for the Twin IIs. The Twin Is had this for ages.
The incident which triggered the AD had one airbrake pop open at the start of the tow. The instructor opened the other one, continued the tow and landed safely. Thankfully, the tug was a Pawnee :-)
Subsequent inspection found another cracked bellcrank on another glider in the same club.
Uri
Old November 1st 15, 11:15 PM posted to rec.aviation.soaring
Bill T
Bill was your un commanded deployment from a cracked part?
BillT
Old November 2nd 15, 01:39 AM posted to rec.aviation.soaring
BillT
Not sure. The glider was not immediately inspected. The locking mechanism felt strange though.
Old November 2nd 15, 02:33 AM posted to rec.aviation.soaring
Tony[_5_]
How would a cracked bellcrank cause both airbrakes to open?
Old November 2nd 15, 04:16 AM posted to rec.aviation.soaring
Hard to say until someone who really knows how the thing is supposed to work looks at it. A developing crack in a bell-crank might allow the mechanism to bend so it couldn't completely lock closed.
Old November 2nd 15, 12:42 PM posted to rec.aviation.soaring
Bill T.
You need to keep in mind that the "Uncommanded" deployment was followed by an "Uncommanded" opening of the canopy which was followed by an "Uncommanded" release failure. No one was ever able to duplicate any of this so there was an "Uncommanded" invitation to leave the club.
Grob gliders, new TM about control system pulleys Robert M Soaring 5 February 14th 14 04:47 PM
Grob 102 Spar Spogot AD note [email protected] Soaring 0 January 10th 11 08:45 PM
Grob 103 AD note for bolt, USA [email protected] Soaring 2 March 2nd 09 05:47 PM
Grob G-103 AD note, USA [email protected] Soaring 1 February 27th 09 11:05 AM
Grob AD note. Stemme AD note. pbc76049 Soaring 0 August 21st 06 03:23 PM
