https://en.wikipedia.org/wiki/Mikoyan-Gurevich_MiG-25
The Mikoyan-Gurevich MiG-25 (Russian: ?????? ? ??????? ???-25) (NATO reporting name: Foxbat) is a supersonic interceptor and reconnaissance aircraft that was among the fastest military aircraft to enter service. It was designed by the Soviet Union's Mikoyan-Gurevich bureau primarily using stainless steel; one of the few combat aircraft to do so. It was the last plane designed by Mikhail Gurevich before his retirement. The first prototype flew in 1964, and the aircraft entered service in 1970. It has an operational top speed of Mach 2.83 (Mach 3.2 is possible but at risk of significant damage to the engines), and features a powerful radar and four air-to-air missiles. When first seen in reconnaissance photography, the large wing suggested an enormous and highly maneuverable fighter, at a time when U.S. design theories were also evolving towards higher maneuverability due to combat performance in the Vietnam War. The appearance of the MiG-25 sparked serious concern in the West and prompted dramatic increases in performance for the McDonnell Douglas F-15 Eagle then under development in the late 1960s. The capabilities of the MiG-25 were better understood in 1976 when Soviet pilot Viktor Belenko defected in a MiG-25 to the United States via Japan. It turned out that the aircraft's weight necessitated its large wings. Production of the MiG-25 series ended in 1984 after completion of 1,190 aircraft. A symbol of the Cold War, the MiG-25 flew with Soviet allies and former Soviet republics, remaining in limited service in Russia and several other nations. It is one of the highest-flying military aircraft, and the second fastest after the SR-71 reconnaissance aircraft. Role Interceptor and reconnaissance aircraft Design group Mikoyan-Gurevich OKB First flight 6 March 1964 Introduction 1970 Status In limited service Primary users Soviet Air Defense (historical) Algerian Air Force Syrian Air Force Ukrainian Air Force (historical) Produced 1964–84 Number built 1,186 Developed into Mikoyan MiG-31 Inaccurate intelligence analysis caused the West initially to believe the MiG-25 was an agile air-combat fighter rather than an interceptor. In response, the United States started a new program which resulted in the McDonnell Douglas F-15 Eagle. NATO obtained a better understanding of the MiG-25's capabilities on 6 September 1976, when a Soviet Air Defence Forces pilot, Lt. Viktor Belenko, defected, landing his MiG-25P at Hakodate Airport in Japan. The pilot overshot the runway on landing and damaged the front landing gear. Despite Soviet protests, the Japanese invited U.S. Air Force personnel to investigate the aircraft. On 25 September, it was moved by a C-5A transport to a base in central Japan, where it was carefully dismantled and analyzed. After 67 days, the aircraft was returned by ship to the Soviets, in pieces. The aircraft was reassembled and is now on display at the Sokol plant in Nizhny Novgorod. The analysis, based on technical manuals and ground tests of engines and avionics, revealed unusual technical information: Belenko's particular aircraft was brand new, representing the latest Soviet technology. The aircraft was assembled quickly, and was essentially built around its massive Tumansky R-15(B) turbojets. Welding was done by hand. Rivets with non-flush heads were used in areas that would not cause adverse aerodynamic drag. The aircraft was built of a nickel steel alloy and not titanium as was assumed (although some titanium was used in heat-critical areas). The steel construction contributed to the craft's high 29,000 kg (64,000 lb) unarmed weight. Maximum acceleration (g-load) rating was just 2.2 g (21.6 m/s²) with full fuel tanks, with an absolute limit of 4.5 g (44.1 m/s²). One MiG-25 withstood an inadvertent 11.5 g (112.8 m/s²) pull during low-altitude dogfight training, but the resulting deformation damaged the airframe beyond repair. Combat radius was 299 kilometres (186 mi), and maximum range on internal fuel (at subsonic speeds) was only 1,197 kilometres (744 mi) at low altitude ( 1000 meters). The airspeed indicator was redlined at Mach 2.8, with typical intercept speeds near Mach 2.5 in order to extend the service life of the engines. A MiG-25 was tracked flying over Sinai at Mach 3.2 in the early 1970s, but the flight led to the engines being damaged beyond repair. The majority of the on-board avionics were based on vacuum-tube technology, not solid-state electronics. Although they represented aging technology, vacuum tubes were more tolerant of temperature extremes, thereby removing the need for environmental controls in the avionics bays. With the use of vacuum tubes, the MiG-25P's original Smerch-A (Tornado, NATO reporting name "Foxfire") radar had enormous power – about 600 kilowatts. As with most Soviet aircraft, the MiG-25 was designed to be as robust as possible. The use of vacuum tubes also made the aircraft's systems resistant to an electromagnetic pulse, for example after a nuclear blast. The unarmed 'B' version had greater impact than the interceptor when the USSR sent two MiG-25R, and two MiG-25RB to Egypt in March 1971 and stayed until July 1972. They were operated by the Soviet 63rd Independent Air Detachment (Det 63) set up specially for this mission. Det 63 flew over Israeli held territory in Sinai on reconnaissance missions roughly 20 times. The flights were in pairs at maximum speed and high altitude (between 17,000–23,000 m). On 6 November 1971, a Soviet MiG-25 operating out of Egypt flying at Mach 2.5 was met by Israeli F-4Es and fired upon unsuccessfully. A MiG-25 was tracked flying over Sinai at Mach 3.2 during this period. The MiG-25 engines went into overspeed, which led to them being scrapped. Unit Det 63 was sent back home in 1972, though reconnaissance Foxbats were sent back to Egypt in 19–20 October 1973 during the Yom Kippur War. Unit Det 154 remained there until late 1974. During the 1970s, the Soviet air force conducted reconnaissance overflights across Iran using its MiG-25RBSh aircraft in response to joint US-Iran recon operations. The Swedish Air Force observed via radar a Soviet Air Defense MiG-25 at 63,000 ft trailed 2.9 km behind the Lockheed SR-71 Blackbird at 72,000 ft over the Baltic Sea in the 1980s. Specifications (MiG-25P) General characteristics Crew: One Length: 19.75 m (64 ft 10 in) Wingspan: 14.01 m (45 ft 11.5 in) Height: 6.10 m (20 ft 0.25 in) Wing area: 61.40 m² (660.93 ft²) Empty weight: 20,000 kg (44,080 lb) Loaded weight: 36,720 kg (80,952 lb) Powerplant: 2 × Tumansky R-15B-300 afterburning turbojets Dry thrust: 73.5 kN (16,524 lbf) each Thrust with afterburner: 100.1 kN (22,494 lbf) each Performance Maximum speed: High altitude: Mach 3.2 (3,470 km/h, 2,170 mph); Mach 2.83 (3,200 km/h, 1,920 mph) continuous engine limit Low altitude: 1,200 km/h (648 knots, 746 mph) at altitude[87] Range: 1,730 km (935 nmi, 1,075 mi) with internal fuel Ferry range: 2,575 km (1,390 nmi) Service ceiling: 20,700 m (67,915 ft) with four missiles; over 24,400 m (80,000 ft) for RB models Rate of climb: 208 m/s (40,950 ft/min) Wing loading: 598 kg/m² (122.5 lb/ft²) Thrust/weight: 0.41 Time to altitude: 8.9 min to 20,000 m (65,615 ft) Armament 2x radar-guided R-40R (AA-6 "Acrid") air-to-air missiles, and 2x infrared-guided R-40T missiles Avionics RP-25 Smerch radar A RV-UM or a RV-4 radar altimeter |
| Thread Tools | |
| Display Modes | |
| Mikoyan-Gurevich MiG-23 pics [20/20] - Mikoyan-Gurevich_MiG-23UB,_Czech_Republic_-_Air_Force.jpg (1/1) | Miloch | Aviation Photos | 0 | August 23rd 16 07:40 AM |
| Mikoyan-Gurevich MiG-23 pics [19/20] - Mikoyan-Gurevich_MiG-23MLD_Flogger_K_USAF.jpg (1/1) | Miloch | Aviation Photos | 0 | August 23rd 16 07:40 AM |
| Mikoyan-Gurevich MiG-21 pics [18/21] - Mikoyan-Gurevich_MiG-21PF_USAF.jpg (1/1) | Miloch | Aviation Photos | 0 | August 22nd 16 04:24 AM |
| Mikoyan-Gurevich MiG-21 pics [17/21] - Mikoyan-Gurevich_MiG-21bis,_Hungary_-_Air_Force_AN0740836.jpg (1/1) | Miloch | Aviation Photos | 0 | August 22nd 16 04:24 AM |
| Mikoyan-Gurevich MiG-19 pics [4/8] - Mikoyan-Gurevich_MiG-19S_at_the_National_Museum_of_the_United_States_Air_Force.JPG (1/1) | Miloch | Aviation Photos | 0 | August 21st 16 07:48 AM |
