trig tt22 into a standard cirrus, or another Schempp-Hirth Glider
Old September 25th 17, 08:20 PM posted to rec.aviation.soaring
Scott Williams
Default trig tt22 into a standard cirrus, or another Schempp-Hirth Glider
Hello Forum,
Could anyone willing to share a copy of their 337 documenting the installation of a transponder, maybe battery, and antenna contact me.
I am compiling a preliminary plan for installing a trig tt22 in my Cirrus, and want to have a complete plan of action before I spend. especially an internal antenna location.
Thanks In advance,
Scott, N8915
Old September 25th 17, 10:44 PM posted to rec.aviation.soaring
Scott Williams
On Monday, September 25, 2017 at 1:20:47 PM UTC-5, Scott Williams wrote:
Hello Forum,
Thanks In advance,
Scott, N8915
I suppose I should also ask, Does the installation of a transponder even require a 337?
Scott.
Old September 25th 17, 11:15 PM posted to rec.aviation.soaring
Frank Whiteley
Hello Forum,
Thanks In advance,
Scott, N8915
Scott.
Wouldn't think so since you already have a Mode S Code assignment for that glider. http://registry.faa.gov/aircraftinqu...NumberTxt=8915
Frank
Old September 26th 17, 02:39 AM posted to rec.aviation.soaring
Dan Marotta
A 337 is for major modifications.Â* I think you can install the
transponder with a mechanic's signature in your log book.Â* You will have
to have the installation tested and certified.
Hello Forum,
Thanks In advance,
Scott, N8915
Scott.
Frank
Dan, 5J
Old September 26th 17, 04:34 AM posted to rec.aviation.soaring
Scott,
You should be able to log into the SchemppHirth Hirth website and look under the TN/AD page for the Standard Cirrus. There is some information there that talks about transponder installation and antenna location/type. Not sure if the links below will work or not:
https://www.schempp-hirth.com/en/sup...D %5BisAd%5D=
https://www.schempp-hirth.com/en/sup...ller%5D =File
Garmin GPS 20A with Trig TT22 in Experimental Glider - OK? Paul Remde Soaring 35 December 21st 15 06:17 AM
Bent up wings on Schempp-Hirth and Jonkers glider Jonathan St. Cloud Soaring 16 June 5th 15 01:42 PM
Schempp-Hirth 'Standard Austria' control surface balancing Matt G. Soaring 3 August 3rd 12 04:21 AM
FS Schempp-Hirth Standard Austria Tim Hanke Soaring 0 October 9th 09 03:42 PM
FS: Schempp-Hirth Standard Austria Tim Hanke Soaring 0 June 24th 08 03:47 PM
