LiFePO4 chargers
Old November 14th 18, 08:09 PM posted to rec.aviation.soaring
Default LiFePO4 chargers
On Wednesday, November 14, 2018 at 2:56:35 PM UTC-5, kinsell wrote:
On 11/14/18 9:03 AM, moshe... wrote:
On Tuesday, November 13, 2018 at 11:11:52 PM UTC-5, kinsell wrote:
On 11/13/18 6:08 PM, bruce... wrote:
Mark, When K2 was fairly new on the market I contacted them asking if Battery Tender Jr. is okay and safe, they replied that it is perfectly okay and nearly the same as their charger. I also contacted Battery Tender Jr. with the reverse question and they said the BTJr is fine for LiFePO4. I used the BTJr for years on my K2 with no issues. They're about $25 on internet sites.
Have you measured the amount of charge you're getting into the K2's? It
will be considerably less than the rated amount due to using a lead-acid
charger.
Also, if K2 has cell balancing capability, it won't be used because your
Battery Tender doesn't put out enough voltage to make it work.
Many simple lead-acid chargers reach up to around 14.2-14.8 volts. That voltage would suffice to charge an LFP battery to well above 90% capacity if it stays there for a while. If it quickly shifts to "float" at 13.5V or so then it won't do well in charging LFP. So simpler is better in this case. Measure what your charger does. And disconnect it after several hours, don't leave it on "float".
Hate to break this to you, but at $24, the Battery Tender Junior is one
of the cheapest chargers on the market, and is fully featured with a
float mode.
14.2 volts wouldn't begin to charge an LFP to "well over 90%" as you
claim. If you found a charger that delivers 14.8 volts under load, then
it would overcharge an SLA and would be considered defective.
If you're going to spend big bucks for an LFP, you ought to get a proper
charger for it. Still waiting to hear just how much charge the K2's got
in them from a BTJ.
-Dave
That's the conventional wisdom, but see experimental results he
https://www.powerstream.com/lithium-...ge-voltage.htm
- well above 90% capacity even at a bit lower than 14V!
A cheap dumb 14.x volt fixed-voltage source with limited current output (and perhaps aided by the battery's BMS) would charge an LFP just fine. I'm not saying that's the ideal charger, but in a pinch it would work well enough. I am not happy with the several chargers I have that push SLAs well above 14V (even above 15V), but they may be handy for LFPs.
Old November 15th 18, 12:42 AM posted to rec.aviation.soaring
Graham Drinkell[_2_]
them asking
if=
oka=
Tender
Jr.=
LiFePO4. I
us=
on
intern=
et sites.
the K2's?
It
lead-ac=
id
charger.
because
yo=
ur
work.
=20
volts.
Tha=
capacity=
o=
this
c=
several
hour=
=20
=20
is one=
=20
with a=20
float mode.
=20
you=20
load, then=
=20
=20
proper=
=20
K2's got=
=20
in them from a BTJ.
=20
-Dave
https://www.powerstream.com/lithium-phosphate-charge-
voltage.htm
output
(an=
fine. I'm
n=
enoug=
well
abo=
Personally, I would fly a model aircraft with a lipo battery. Full
size, definitely not! They deform at high altitudes, with the
possibility of fracturing cells? The best bet is to use military spec
batteries that work in space?
Old November 15th 18, 12:47 AM posted to rec.aviation.soaring
them asking
if=
perfectly
oka=
Tender
Jr.=
LiFePO4. I
us=
$25
on
intern=
et sites.
into
the K2's?
It
using
lead-ac=
id
charger.
because
yo=
ur
work.
=20
14.8
volts.
Tha=
90%
capacity=
13.5V
o=
this
c=
several
hour=
=20
=20
is one=
=20
with a=20
float mode.
=20
as
you=20
load, then=
=20
=20
a
proper=
=20
K2's got=
=20
in them from a BTJ.
=20
-Dave
he
voltage.htm
output
(an=
fine. I'm
n=
well
enoug=
SLAs
well
abo=
Old November 17th 18, 03:04 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
kinsell wrote on 11/14/2018 12:55 PM:
for years on my K2* with no issues. They're about $25 on internet sites.
Have you measured the amount of charge you're getting into the K2's?* It
charger.
Many simple lead-acid chargers reach up to around 14.2-14.8 volts.* That voltage
there for a while.* If it quickly shifts to "float" at 13.5V or so then it won't
do well in charging LFP.* So simpler is better in this case.* Measure what your
charger does.* And disconnect it after several hours, don't leave it on "float".
Hate to break this to you, but at $24, the Battery Tender Junior is one of the
cheapest chargers on the market, and is fully featured with a float mode.
14.2 volts wouldn't begin to charge an LFP to "well over 90%" as you claim.* If
you found a charger that delivers 14.8 volts under load, then it would overcharge
If you're going to spend big bucks for an LFP, you ought to get a proper charger
for it.* Still waiting to hear just how much charge the K2's got in them from a BTJ.
Bienno Power has a $25, 12V/4A LiFePO4 charger. I'd trust that over a BT Jr, and
it's the same price.
- "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm
http://soaringsafety.org/prevention/...anes-2014A.pdf
Old November 17th 18, 03:18 AM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
Craggy Aero has a 5A LiFePO4 Smart Charger
http://www.craggyaero.com/lifepo4_battery.htm
Richard
Old November 17th 18, 03:20 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
kinsell wrote on 11/13/2018 9:18 PM:
scinating videos on YouTube.
However, "safer" isn't actually the same as "safe", LFP's are quite
capable of burning, despite what the scholarly articles say.* There have
been a number of fires, particularly when they're used as starter
batteries.* High charge rates and very high discharge rates seem to
cause problems, as homebuilders of small power planes have discovered.
There was also that LFP battery fire in an EB-28 in Finland this summer.
-Dave
Dave, if you look around youtube long enough, you will find that a AAA battery
can make a fire. Certainly a 12V lead-acid has enough juice to do that if
circumstances are right. The overwhelming evidence of many years of usage of
LiFePo4 chemistry in glider batteries suggests that they are as safe as the old
gel-cells. Give progress a chance, I'm not saying be a Progressive.
Herb
If you come across a YouTube video of an AAA battery filling a cockpit with toxic
smoke, you be sure to post the link, OK?
Meanwhile, this is the sort of progress I can live without:
https://www.pilotsofamerica.com/comm...-fires.102016/
I did not see any indication the burning battery had a BMS. Some builders put in
the "starter" LiFe batteries that do not have a BMS, so perhaps that is the reason
the battery burned. I think LiFe batteries from the usual suppliers (Bienno, K2,
Stark - for example) with a BMS, used for instrument batteries, and charged with
the recommended charger are as safe as a comparable capacity SLA.
Old November 17th 18, 05:22 PM posted to rec.aviation.soaring
capable of burning, despite what the scholarly articles say.Â* There have
batteries.Â* High charge rates and very high discharge rates seem to
cause problems, as homebuilders of small power planes have discovered..
-Dave
Herb
Several years ago I had a bad batch of batteries from one of the suppliers you mentioned in your post. 4 to 5 aH capacity in a 10 Ah battery. I quit selling them. I now sell LiFePO4 batteries that I personally test before shipping with a West Mountain Radio computer tester. Document is supplied with the battery.
Richard
www.craggyaero.com
Old November 18th 18, 02:51 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Richard Pfiffner wrote on 11/17/2018 10:22 AM:
reason the battery burned. I think LiFe batteries from the usual suppliers
(Bienno, K2, Stark - for example) with a BMS, used for instrument batteries,
and charged with the recommended charger are as safe as a comparable capacity
SLA.
the battery.
I test every battery before installing it, also using a West Mountain tester. Over
the years, I've had three SLA batteries that had half their rated capacity, and
returned them. I've only used one LiFe battery, and it had exactly the rated
capacity. Couldn't believe it - tested it again, and got the same answer.
Battery Chargers Stan Amyett Soaring 2 March 12th 04 05:27 AM
Solar Battery Chargers Jay Honeck Piloting 32 February 22nd 04 11:17 PM
Battery Chargers Mike Rapoport Owning 11 December 2nd 03 11:55 PM
Rechargable AA batteries and chargers TripFarmer General Aviation 2 October 17th 03 06:34 PM
Rechargable batteries and chargers....... TripFarmer Products 2 October 17th 03 06:31 PM
