Antennae
Old July 20th 19, 03:30 AM posted to rec.aviation.soaring
George Haeh
Default Antennae
Hi Dan,
I do get different range patterns for the Flarm A&B antennae, which I have mounted on both sides of my canopy.
What I don't know is whether my Flarm is seeing a glider that's not seeing me.
But at least one of us knows about the other.
Old July 20th 19, 11:44 AM posted to rec.aviation.soaring
Dan Daly[_2_]
Default Antennae
On Friday, July 19, 2019 at 10:30:50 PM UTC-4, George Haeh wrote:
Hi Dan,
Interesting! I will have to install a second antenna (I'm grandfathered) and have a go...
Old July 20th 19, 02:07 PM posted to rec.aviation.soaring
Default Antennae
Hi Dan,
It's worth having the two antennas even if the "B" antenna only receives. That fills in gaps in your reception pattern. And as far as the FLARM range report, that is ONLY using reception data - it has no way to know who can receive your transmissions, since the protocol is a blind broadcast with no acknowledgment.
Old July 20th 19, 02:59 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Default Antennae
Hi Dan,
You can see some of that with the Open Glider Network (OGN). The KTrax range analysis shows receipt by OGN stations (if you have any nearby). Here is an example (ASW24): https://ktrax.kisstech.ch/cgi-bin/fl...flarmid=C05FDB from last week. You can see the glider got about 15 km from one station, and another 33 km distant picked up the glider from 33-38 km.
Here's another glider (PIK20) which flew from one OGN station to the other. At 40 km, still 5 dB.
The OGN network is also handy for troubleshooting cabling, antennae, etc since you can get a signal strength reading directly (swap a cable or antenna to see if they're bad - might save a trip for $$ troubleshooting). It also has SAR features.
Old July 20th 19, 03:36 PM posted to rec.aviation.soaring
Dan Marotta
Default Antennae
That's very interesting!
Having both A and B antennae on top of the glare shield in my Stemme, I
get poor results with gliders directly below me (carbon fuselage).Â* I'll
try this again afterI move the antennae to the canopy rail and see what
improvement I get.
Hi Dan,
Dan, 5J
Old July 20th 19, 04:22 PM posted to rec.aviation.soaring
Default Antennae
On Saturday, July 20, 2019 at 10:00:07 AM UTC-4, Tim Newport-Peace wrote:
Not quite true. If you are in an area where the OGN network is active and
has tracked you, you can see how others see you.
URL is https://ktrax.kisstech.ch/flarm-liverange/
I meant the range report the FLARM website offers, via analyzing your flight logs. Those capabilities of OGN are cool, but I didn't think about OGN since I am in the USA, where OGN is very sparse.
Old July 20th 19, 04:25 PM posted to rec.aviation.soaring
Default Antennae
improvement I get.
Dan, the benefit of using two antennas is maximized if you separate them as much as possible. That's why I'd like to install the "B" antenna behind the pilot seat, to help reception from the rear. Of course in a carbon fuselage that may not be a viable option. Unless you have a glass-fiber turtledeck, which I gather some gliders do, although the top part of the tailcone would still be in the way.
Old July 21st 19, 02:37 AM posted to rec.aviation.soaring
Dan Marotta
Default Antennae
The turtle deck on the Stemme is fiberglass but I already have two
antennae on top of the glare shield.Â* I'd like to put one on the bottom
of the aircraft.Â* An ideal location would be on the propeller dome, but
the transponder antenna is mounted on the bottom of that in the middle
fore and aft.Â* What's the minimum spacing required between a transponder
antenna and a flarm antenna?
Another possibility would be to install an antenna in the engine bay
right at the bottom.Â* I think the lower cowl is fiberglass, but I'd have
to check.
Since I trimmed the antenna cables to length when I installed them on
top of the glare shield, I'll have problems that may require buying new
antennae.Â* Bummer...
improvement I get.
Dan, 5J
Old July 21st 19, 03:36 AM posted to rec.aviation.soaring
Default Antennae
to check.
I'd keep all other antennas as far as possible from the transponder antenna, since it transmits (in short bursts) at about 200 watts.
Extra FLARM antennas are cheap he
https://www.mouser.com/Passive-Compo...16+MHW&FS=True
Best 3 antennae combo for PowerFLARM? [email protected] Soaring 5 April 15th 19 02:57 AM
VOR Antennae Installation guynoir Home Built 1 November 8th 06 03:37 AM
Pitot tube for the antennae Ernest Christley Home Built 12 May 29th 06 05:05 AM
Which antennae please? Robert Loer Home Built 1 October 27th 04 11:55 PM
Marine Radio using Aviation Antennae Jim Weir Home Built 13 August 12th 03 10:05 PM
