L-23 Loose Horizontal Stabilizer
Old September 10th 19, 06:11 PM posted to rec.aviation.soaring
Chris Snyder
Default L-23 Loose Horizontal Stabilizer
We just noticed some play on our club L-23. It was detected in the stick while on tow with a forward CG. Does anyone have experience with a horizontal stab being loose on an L-23? The elevator auto-hookups have large pins, but it seems like there's no way to really tighten anything:
https://www.screencast.com/t/iiOd0TSi8zpX
Old September 10th 19, 06:47 PM posted to rec.aviation.soaring
Tango Eight
Our L-23 would not go together with the pins looking like that. With everything shiny clean and well greased, it is a real chore to wiggle the elevator drive home. There is no play, anywhere, and certainly none that could be noticed from the cockpit.
I think I'd go have a very close look at that elevator and how assembled.....
best,
Evan Ludeman
Old September 10th 19, 07:08 PM posted to rec.aviation.soaring
Chris Snyder
best,
Evan Ludeman
That was a "stock photo" I found from an assembly manual, but good to know.
Old September 10th 19, 07:30 PM posted to rec.aviation.soaring
Bob Kuykendall
On Tuesday, September 10, 2019 at 10:11:32 AM UTC-7, Chris Snyder wrote:
We just noticed some play on our club L-23. It was detected in the stick while on tow with a forward CG. Does anyone have experience with a horizontal stab being loose on an L-23? The elevator auto-hookups have large pins, but it seems like there's no way to really tighten anything...
You should probably take any looseness in the elevator drive or horizontal stabilizer attachment quite seriously.
Can you describe the play more precisely? Is the play in the elevator actuation, or in the horizontal stab attachment?
--Bob K.
Old September 10th 19, 07:40 PM posted to rec.aviation.soaring
Charles Longley
I have a lot of experience on L-23 loose horizontal stabs. The first thing I would check is the fit of the pins. The maintenance manual will tell you the exact maximum number. You’ll need to measure the OD on the pins and the ID on the rocker assembly. Stock pins are pretty easy to find, oversized not so much. If you have to oversize you’ll need to ream the rocker assembly.
Clean and plenty of grease when the horizontal gets put on.
Old September 10th 19, 08:10 PM posted to rec.aviation.soaring
Chris Snyder
--Bob K.
Word from Blanik America is the MM provides the tolerance for how much movement is acceptable, so we're going to measure that tonight. The play is in the stab attachment. Apparently there are a few sources that can cause this.
Old September 10th 19, 08:12 PM posted to rec.aviation.soaring
Chris Snyder
Thanks for the tip. We'll measure these specs too.
Old September 10th 19, 11:02 PM posted to rec.aviation.soaring
Frank Whiteley
--Bob K.
Our former L-23 developed play in the horizontal that exceeded the limits. The yoke and pins had to be replaced. The yoke was ordered and arrived without new pins, so they had to be ordered separately. Be sure to order both together if that's the source of the play. Not sure about today, but IIRC it took 4-5 months to get the yoke. The pins, not so long.
Frank Whiteley
Old September 11th 19, 02:53 PM posted to rec.aviation.soaring
Chris Snyder
--Bob K.
Our former L-23 developed play in the horizontal that exceeded the limits.. The yoke and pins had to be replaced. The yoke was ordered and arrived without new pins, so they had to be ordered separately. Be sure to order both together if that's the source of the play. Not sure about today, but IIRC it took 4-5 months to get the yoke. The pins, not so long.
Frank Whiteley
Okay, that's good to know. Thankfully our stab measurement was within the specs, so we're good for now.
Thanks everyone for all of the help!
stowing horizontal stabilizer on tail boom in trailer [email protected] Soaring 24 June 19th 19 07:47 PM
Scheibe SF-25 Motorfalke horizontal stabilizer and other parts needed [email protected] Soaring 7 January 25th 17 05:51 PM
Looking for a Libelle Horizontal Stabilizer J Wahl Soaring 1 May 2nd 15 05:01 AM
G-103 horizontal stabilizer airfoil section ? [email protected] Soaring 3 November 23rd 08 04:30 AM
WTB: 1-34 Horizontal Stabilizer Jeremy Zawodny Soaring 1 October 15th 04 05:12 AM
