Kawasaki Ki-45 "Toryu"
https://en.wikipedia.org/wiki/Kawasaki_Ki-45
The Kawasaki Ki-45 Toryu (??, "Dragon Slayer") was a two-seat, twin-engine fighter used by the Imperial Japanese Army in World War II. The army gave it the designation "Type 2 Two-Seat Fighter"; the Allied reporting name was "Nick". In response to the rapid emergence in Europe of twin-engine heavy fighters such as the Messerschmitt Bf 110, the army ordered development of a twin-engine, two-seat fighter in 1937, and assigned the proposal by Kawasaki Shipbuilding the designation of Ki-38. This only went as far as a mock up, but by December of that year, the army ordered a working prototype as the Ki-45, which first flew in January 1939. Results from the test flights, however, did not meet the army's expectations. The Ha-20 Otsu engine was underpowered and failure-prone, while the airframe suffered from nacelle stall. The Ki-45 did not enter service, but the army, insistent on having a working twin-engine fighter, ordered Kawasaki to continue development. Kawasaki responded by replacing the engines with the proven Nakajima Ha-25. Flight tests were promising. In October 1940, the army ordered continued improvements such as switching to 805 kW (1,080 hp) Mitsubishi Ha-102 engines. This craft, designated Ki-45 Kai, was complete in September 1941 and was officially adopted for use by the army in February 1942 as the "Type 2 Two-Seat Fighter". The prototype of a single-seat fighter variant, the Ki-45 II, was also built; development continued under the designation Ki-96. Role Heavy fighter/night fighter Manufacturer Kawasaki Kokuki Kogyo K.K. Designer Takeo Doi First flight January 1939 Introduction October 1941 Retired 1945 Primary users Imperial Japanese Army Air Force People's Liberation Army Air Force Number built 1,701 The Ki-45 was initially used as a long-range bomber escort. The 84th Independent Flight Wing (Dokuritsu Hiko Chutai) used them in June 1942 in attacks on Guilin, where they encountered, but were no match for, Curtiss P-40s flown by the Flying Tigers. In September of the same year, they met P-40s over Hanoi with similar results. It became clear that the Ki-45 could not hold its own against single-engine fighters in aerial combat. It was subsequently deployed in several theaters in the roles of interception, attack (anti-ground as well as anti-shipping) and fleet defense. Its greatest strength turned out to be as an anti-bomber interceptor, as was the case with the Bf 110 in Europe. In New Guinea, the IJAAF used the aircraft in an anti-ship role, where the Ki-45 was heavily armed with one 37 mm (1.46 in) and two 20 mm cannons and could carry two 250 kg (550 lb) bombs on hard points under the wings. 1,675 Ki-45s of all versions were produced during the war. The first production type (Ko) was armed with two 12.7 mm (.50 in) Ho-103 machine gun in the nose, a single Type 97 20 mm cannon in the belly offset to the right, and a trainable 7.92 mm (.312 in) machine gun in the rear cabin; this was followed by the Otsu with the lower 20 mm cannon replaced by a 37 mm (1.46 in) type 94 tank gun, to counter B-17 Flying Fortress bombers. While the firepower was devastating, manual reloading meant that typically only two rounds could be fired on each gunnery pass. The next type (Hei) restored the 20 mm cannon, and this time placed an automatic 37 mm (1.46 in) gun in the nose. A later addition in the "Tei" type were twin obliquely-firing 20 mm Ho-5 cannons behind the cockpit, and often propulsive exhaust stacks. The Ki-45 was to be replaced in the ground-attack role by the Ki-102, but was not wholly supplanted by the war's end. Three Ki-45s fell into communist Chinese hands after World War II. Unlike most captured Japanese aircraft, which were employed in the training role, the three Ki-45s were assigned to the 1st Squadron of the Combat Flying Group in March 1949 and were used in combat missions. These aircraft were retired in the early 1950s. Specifications (Ki-45 KAIc) General characteristics Crew: Two Length: 11.00 m (36 ft 1 in) Wingspan: 15.02 m (49 ft 4 in) Height: 3.70 m (12 ft 2 in) Wing area: 32.0 m² (344 ft²) Empty weight: 4,000 kg (8,820 lb) Loaded weight: 5,500 kg (12,125 lb) Powerplant: 2 × Mitsubishi Ha-102 14-cylinder radial engines, 783 kW (1,050 hp) each Performance Maximum speed: 540 km/h (292 kn, 336 mph) Range: 2,000 km (1,081 nmi, 1,243 mi) Service ceiling: 10,000 m (32,800 ft) Rate of climb: 11.7 m/s (2,300 ft/min) Wing loading: 171.9 kg/m² (35 lb/ft²) Power/mass: 0.26 kW/kg (0.16 hp/lb) Armament 1 × 37 mm (1.46 in) Ho-203, 1 × 20 mm Ho-3, 1 × 7.92 mm (.312 in) flexible * |
Similar Threads | ||||
Kawasaki Ki-61 "Hien" pics 2 [5/9] - Kawasaki Ki-61 4.jpg (1/1) | Miloch | Aviation Photos | 0 | September 3rd 18 03:44 PM |
Kawasaki Ki-61 "Hien" pics [09/10] - kawasaki ki 61 livery.jpg (1/1) | Miloch | Aviation Photos | 0 | September 3rd 18 03:43 PM |
Kawasaki Ki-61 "Hien" pics [08/10] - kawasaki ki 61 livery 2.jpg (1/1) | Miloch | Aviation Photos | 0 | September 3rd 18 03:43 PM |
Kawasaki Ki-61 "Hien" pics [07/10] - kawasaki ki 61 drawings.jpg (1/1) | Miloch | Aviation Photos | 0 | September 3rd 18 03:42 PM |
Kawasaki Ki-61 "Hien" pics [05/10] - crashed kawasaki ki 61.jpg (1/1) | Miloch | Aviation Photos | 0 | September 3rd 18 03:42 PM |
