Fatal Towplane Accident 5-9-20
Old June 4th 20, 01:35 AM posted to rec.aviation.soaring
Tom[_21_]
Default Fatal Towplane Accident 5-9-20
Preliminary report: https://app.ntsb.gov/pdfgenerator/Re...relim&IType=LA
  #202
Old June 4th 20, 04:56 AM posted to rec.aviation.soaring
2G
After examining the photos, it appears that the towplane's altitude was approximately 3 wing spans, or about 100 ft AGL. The towpilot did cut the tow rope with the internal guillotine mechanism, but by that time was in an unrecoverable attitude.
The glider pilot did go thru a pre-launch checklist that included checking that the canopy was closed and locked. I don't see how more training and drilling on checklists and procedures could have prevented this accident. The glider pilot, however, could have prevented it by immediately releasing when the canopy flew open, and could have safely landed straight ahead.
Tom
  #203
Old June 4th 20, 07:58 AM posted to rec.aviation.soaring
Bob Youngblood
Tom
The photos and the timeline are very telling. Unless I am reading the timeline incorrectly the glider pilot was on tow for 13 seconds before the executed detachment and return to the airport. Unfortunate and preventable, obviously the canopy was not latched as stated.
  #204
Old June 4th 20, 01:47 PM posted to rec.aviation.soaring
It's not clear from the report what sort of canopy or if checking included pushing up on the plexi to try to open it.
Definitely a sad day.
  #205
Old June 4th 20, 06:17 PM posted to rec.aviation.soaring
Hightime
If you don’t physically push (lightly ) up on canopy after it is closed and locked you will have a inflight opening eventually. A tried and true failsafe
Just watch and see who at your club is actually doing that final crucial piece of the puzzle
Once I pushed lightly up just before launch and couldn’t believe I had forgotten to lock the canopy , it was at a different airport and things were different , or I was , I had opened the canopy more then once The final push revealed the sin
Watch for sinners and tongue lash them
  #206
Old June 4th 20, 11:07 PM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
Quote:
Originally Posted by Rakel View Post
Since we have now decided to re-invent the tow plane to put the tow hook on the CG, has anybody considered a canard design with a front or mid fuselage mounted engine?
Not quite what you have in mind but I've towed behind one of these back in the 80s and it was a pretty darn good towplane and apparently good to fly
https://en.wikipedia.org/wiki/Transavia_PL-12_Airtruk
ID:	123948  Click image for larger version
  #207
Old June 4th 20, 11:46 PM posted to rec.aviation.soaring
I also forgot to latch the canopy once, but it has a forward hinge, so it just rattled a bit. I latched it after releasing from tow. A side hinge canopy should ALWAYS get some fingerprints on the inside of the plexiglass. EVERY TIME! It's a lot easier (and CHEAPER!) to clean off the greasy fingerprints than to hunt down all the shards and pay for a replacement.
  #208
Old June 4th 20, 11:53 PM posted to rec.aviation.soaring
Waveguru
I feel irritated when people go around telling people that their way is the only way. There is more than one way to confirm that the canopy is latched. If you tongue lash me you will regret it.
Boggs
  #209
Old June 4th 20, 11:56 PM posted to rec.aviation.soaring
Bob Youngblood
It is more likely that it is what you don't do than what you do that creates the bigger problem. Having the canopy latched is different than having the canopy latched and locked. Again, if you lose sight of the tow plane simply release immediately.
  #210
Old June 5th 20, 12:00 AM posted to rec.aviation.soaring
Waveguru
And if you really want to get someone to understand the problem and change, tongue lashing is not a good way to do it. Berating someone rarely gets them to change.
Boggs
Towplane-Baron accident Jp Stewart Soaring 58 June 11th 18 10:03 PM
Fatal accident in Scotland Ian Soaring 51 September 6th 07 10:55 AM
Another fatal accident Mike the Strike Soaring 0 September 20th 06 11:50 PM
Fatal accident in Italy 2cernauta2 Soaring 1 April 4th 06 05:50 PM
Hawaii Fatal Accident Rocky Rotorcraft 0 July 25th 03 03:01 PM
