I tried to post some bitmap images with this but it didn't come up on my
server. Anyways.. Concerning the Chalks seaplane crash in Miami, fatigue features were observed in the lower spar cap of the rear spar of the inboard end of the right wing, bisecting 2 offset drilled holes. D. |
"Capt.Doug" wrote in message
... I tried to post some bitmap images with this but it didn't come up on my server. Anyways.. Concerning the Chalks seaplane crash in Miami, fatigue features were observed in the lower spar cap of the rear spar of the inboard end of the right wing, bisecting 2 offset drilled holes. D. Capt, This is a non-binary newgroup so most servers will strip the attachments. You might try alt.binaries.pictures.aviation as a place to post them. Regards, Jay Beckman PP-ASEL Chandler, AZ |
"Jay Beckman" wrote in message
news:ujkEf.24545$jR.8402@fed1read01... This is a non-binary newgroup so most servers will strip the attachments. You might try alt.binaries.pictures.aviation as a place to post them. Or just post them to http://www.tinypic.com and then post the resultant URL here... That's probably a better solution since that way, the photos stay around... The photos in a binary newsgroup get flushed out eventually when new ones come in, dependent upon the amount of traffic in the newsgroup... |
On Thu, 02 Feb 2006 09:26:20 GMT, "Capt.Doug"
wrote: I tried to post some bitmap images with this but it didn't come up on my server. Anyways.. Concerning the Chalks seaplane crash in Miami, fatigue features were observed in the lower spar cap of the rear spar of the inboard end of the right wing, bisecting 2 offset drilled holes. D. Send them to me. I've got the web space to share them. I'm not a lawyer, I'm just an engineer that is interested in metal fatigue and aging aircraft. In particular, I'm going to buy an old 7AC or L-16. Mike Weller |
"Mike Weller" wrote in message Send them to me.
They are on the way. D. |
Mike;
If you're interested in 7AC's I think Todd Pattist bought one recently. You might want to check with him on whatever fabric tests he did. Dudley Henriques "Mike Weller" wrote in message ... On Thu, 02 Feb 2006 09:26:20 GMT, "Capt.Doug" wrote: I tried to post some bitmap images with this but it didn't come up on my server. Anyways.. Concerning the Chalks seaplane crash in Miami, fatigue features were observed in the lower spar cap of the rear spar of the inboard end of the right wing, bisecting 2 offset drilled holes. D. Send them to me. I've got the web space to share them. I'm not a lawyer, I'm just an engineer that is interested in metal fatigue and aging aircraft. In particular, I'm going to buy an old 7AC or L-16. Mike Weller |
("Dudley Henriques" wrote)
If you're interested in 7AC's I think Todd Pattist bought one recently. You might want to check with him on whatever fabric tests he did. [Mike Weller] In particular, I'm going to buy an old 7AC or L-16. I believe Steven P. McNicoll flys a 7AC. Montblack |
I think you're right. McNicoll does fly a Champ!
Good luck with your quest. The Champ is a fine old bird. DH "Montblack" wrote in message ... ("Dudley Henriques" wrote) If you're interested in 7AC's I think Todd Pattist bought one recently. You might want to check with him on whatever fabric tests he did. [Mike Weller] In particular, I'm going to buy an old 7AC or L-16. I believe Steven P. McNicoll flys a 7AC. Montblack |
Mike Weller wrote:
"Capt.Doug" wrote: I tried to post some bitmap images with this but it didn't come up on my server. Anyways.. Concerning the Chalks seaplane crash in Miami, fatigue features were observed in the lower spar cap of the rear spar of the inboard end of the right wing, bisecting 2 offset drilled holes. Send them to me. I've got the web space to share them. I'm not a lawyer, I'm just an engineer that is interested in metal fatigue and aging aircraft. In case you hadn't seen it, there are a couple of articles on the Flight International web site, with photos of the cracking and some short discussion: http://tinyurl.com/brcwy http://tinyurl.com/9kslp |
"Capt.Doug" wrote in message ... I tried to post some bitmap images with this but it didn't come up on my server. Anyways.. Concerning the Chalks seaplane crash in Miami, fatigue features were observed in the lower spar cap of the rear spar of the inboard end of the right wing, bisecting 2 offset drilled holes. D. This scenario is almost the same scenario that killed a friend of mine in his F8F Bearcat. As these old airplanes age, even with constant care, it's extremely difficult to assess the actual wearing down process on a specific spot taking accumulated stress over time. Sooner or later, subjected to the dynamics involved with in-flight forces, all parts will deteriorate as we all know. Finding that "sweet spot" that defines total runout time for every piece of an airplane can be a daunting task. You can inspect, you can magnaflux, you can estimate a failure mode through a computer model, but in the end, something can and usually will give somewhere. What's insidious in all this is that when these failures happen, they come in two different scenarios. The first is obvious; a total failure of a part which is instantly catastrophic such as was the case with my friend's Bearcat where the wing sheared off the airplane coming out of a normal loop at normal g, or the failure of a minor part which isn't instantly catastrophic, but however instantly changes the entire failure model for parts down the line that are affected by the minor part's failure. It's a tough call on these old airplanes, and something that will be talked about and debated by those involved in flying older airplanes without finding a definitive answer ad infinitum. Total replacement of a part based on an estimated failure span is good, but even with that in place, considering the astronomical cost of doing this, flying these old airplanes past their projected airframe runout I think will always be a crapshoot. Dudley Henriques |
| Thread Tools | |
| Display Modes | |
| Seaplane crash details | Capt.Doug | Piloting | 11 | February 2nd 06 11:58 PM |
| Intersting tidbit about the Miami seaplane crash and fuel reserves | xyzzy | Instrument Flight Rules | 5 | December 24th 05 12:43 PM |
| Yet another A36 crash | H.P. | Piloting | 10 | April 23rd 05 06:58 PM |
| American Lake SPB Closing | C J Campbell | Piloting | 23 | December 27th 04 04:26 PM |
| Details on Baron Crash in Memphis? | Greg Esres | Piloting | 0 | July 11th 03 05:37 PM |
