I observed a bizarre thing this morning. We were in a 200 HP Arrow-II
equipped with a JPI FS-450 fuel computer and were talking about leaning on the ground to prevent plug fouling. With the engine running at about 1000 RPM shortly after startup and the brakes on, we were drawing 2.6 GPH. EGT was about 1000 F. As we leaned, we got to the point where the engine started to run a little rough, the EGT went up to about 1100 F, and (here's the strange part), the fuel flow rate went UP to 3.2 GPH. Does this make any sense? Why would leaning make the fuel flow rate go up? We ran through a couple of rich-lean cycles on the mixture, and the readings were repeatable. What's going on here? |
On Sat, 18 Mar 2006 19:21:29 -0500, Roy Smith wrote:
I observed a bizarre thing this morning. We were in a 200 HP Arrow-II equipped with a JPI FS-450 fuel computer and were talking about leaning on the ground to prevent plug fouling. With the engine running at about 1000 RPM shortly after startup and the brakes on, we were drawing 2.6 GPH. EGT was about 1000 F. As we leaned, we got to the point where the engine started to run a little rough, the EGT went up to about 1100 F, and (here's the strange part), the fuel flow rate went UP to 3.2 GPH. Does this make any sense? Why would leaning make the fuel flow rate go up? We ran through a couple of rich-lean cycles on the mixture, and the readings were repeatable. What's going on here? I suppose the reason for the 25% uplift in fuel consumption could have been due to a 12% increase in revs? If not, an artifact of the fuel computer, I'd think? Brian Whatcot Altus OK |
Probably due to hysteresis in the mixture cable. It would be impossible for the fuel flow to go up if the mixture was working properly and there were no hysteresis in the system.
Make sure you only go one direction with the turning of the mixture control. You can't be going back and forth twisting the mixture control. One way only and log your data. Karl ATP CFI ETC |
" wrote in message .com... Probably due to hysteresis in the mixture cable. It would be impossible for the fuel flow to go up if the mixture was working properly and there were no hysteresis in the system. Make sure you only go one direction with the turning of the mixture control. You can't be going back and forth twisting the mixture control. One way only and log your data. Karl ATP CFI ETC -- You'll have to excuse my ignorance. Are you saying it could be related to magnetism? |
A hysteresis loop in this context refers to the idea of a lag between
cause and effect. The mixture control cable is not going to accurately 100% of the time precisely represent your mixture knob movements. Slack and stretching in the system can make it such that, for instance, when you change the direction you are turning the knob, the actual mixture setting on the carb (or equiv for FI systems) might not move exactly the same at the same time. Imagine if the cable was very sticky for instance. You're not going to get ideal response from your inputs. As for whether or not that's your reason for increased fuel flow, I'm on the fence. I like the increased revs theory too... -Ferdi |
| Thread Tools | |
| Display Modes | |
| fuel leak or auxiliary fuel pump malfunction? | [email protected] | Owning | 7 | December 17th 06 01:57 PM |
| V8 fuel flow | Robert Bates | Home Built | 34 | January 24th 05 04:41 AM |
| Replacing fuel cut-off valve with non-a/c part??? | Michael Horowitz | Owning | 46 | January 15th 05 11:20 PM |
| fuel flow measurement | khanindra jyoti deka | Home Built | 0 | January 5th 05 05:34 AM |
| advanced fuel flow mesurement system using microcontroller | khanindra jyoti deka | Home Built | 4 | January 4th 05 02:18 AM |
