I have seen that indication when the antenna did not have a clear view
of the sky. The installed aircraft was an EADS/Socata TB-9 with gull wing doors. Coming out of the pad, the pilot's door when up (as it was in the summer) would obscure much of the sky and not allow the GPS to get a position. Resolved by removing the blockage by repositioning the plane or lowering the door. The antenna in this case was on the roof of the cabin between the two gull-wing-doors. Peter wrote: http://www.peter2000.co.uk/aviation/kln94-failure/ This unit has been working perfectly for four years, and works fine now. Peter. -- Return address is invalid to help stop junk mail. E-mail replies to but remove the X and the Y. |
Ooops. Only looked at pic number 1, not the ones showing the sat
reception. Only time I've had a slow position computation is when the unit has been powered down for a LONG (weeks to months) time. Takes up to 15 mins for it to "find itself" while remaining still. An intermittent connection on the internal battery (there is a small watch battery on the board inside - at least the KLN-89/B does) to keep last known position and user waypoints stored. You didn't have any error/hardware error messages on startup? Dave Dave S wrote: I have seen that indication when the antenna did not have a clear view of the sky. The installed aircraft was an EADS/Socata TB-9 with gull wing doors. Coming out of the pad, the pilot's door when up (as it was in the summer) would obscure much of the sky and not allow the GPS to get a position. Resolved by removing the blockage by repositioning the plane or lowering the door. The antenna in this case was on the roof of the cabin between the two gull-wing-doors. Peter wrote: http://www.peter2000.co.uk/aviation/kln94-failure/ This unit has been working perfectly for four years, and works fine now. Peter. -- Return address is invalid to help stop junk mail. E-mail replies to but remove the X and the Y. |
In rec.aviation.misc Dave S wrote:
Ooops. Only looked at pic number 1, not the ones showing the sat reception. Only time I've had a slow position computation is when the unit has been powered down for a LONG (weeks to months) time. Takes up to 15 mins for it to "find itself" while remaining still. An intermittent connection on the internal battery (there is a small watch battery on the board inside - at least the KLN-89/B does) to keep last known position and user waypoints stored. You didn't have any error/hardware error messages on startup? That would be a pretty big watch. The battery in my 89/B is about the size of a AA. I think it lasted about 8 years before failing. It gave warnings before it died though. The battery is soldered to the circuit board, so I think if it had been working and isn't now, it's either dead, or the wire has broken somehow. Dave Dave S wrote: I have seen that indication when the antenna did not have a clear view of the sky. The installed aircraft was an EADS/Socata TB-9 with gull wing doors. Coming out of the pad, the pilot's door when up (as it was in the summer) would obscure much of the sky and not allow the GPS to get a position. Resolved by removing the blockage by repositioning the plane or lowering the door. The antenna in this case was on the roof of the cabin between the two gull-wing-doors. Peter wrote: http://www.peter2000.co.uk/aviation/kln94-failure/ This unit has been working perfectly for four years, and works fine now. Peter. -- Return address is invalid to help stop junk mail. E-mail replies to but remove the X and the Y. -- Don Poitras |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Hagerstown Aviation History To Be Auctioned, Museum Working to Save Last Flying Hagerstown-Made Fairchild C-82 | [email protected] | Restoration | 0 | August 10th 06 02:17 AM |
| General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Home Built | 3 | May 14th 04 12:55 PM |
| General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Aerobatics | 0 | May 11th 04 11:43 PM |
| Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! | Jay Honeck | Home Built | 18 | January 20th 04 05:02 PM |
