UPDATE Starter question
On Jan 31, 6:53 pm, john smith wrote:
In article .com, wrote: Any contactor has a coil, the starter has several coils, and the alternator has a field coil. All coils create a sharp voltage spike when the current is cut off. Switching the master off, the alternator off, or releasing the start switch all create that spike (I've measured the master contactor's spike at 600 volts) and those expensive radios aren't all built to put up with it, especially considering that the spike creates an electron flow in the wrong direction through the bus. That's why many aircraft have an avionics master switch (that has no coil involved). The rest should have the radios shut off before shutdown. Coils (inductors) are current storage devices. Capacitors are voltage storage devices. As if current and voltage were independent of each other? The coil will produce a surge of current, which has a specific pressure that we call voltage. You can't have current flow without voltage; any flow (amperage) requires pressure (voltage) to drive it. Just like water in a hose. The magneto produces a pressure upward of 20,000 volts. It does this using a pair of coils and a switch (points). Your automobile's ignition system probably produces 40,000 volts, again using paired coils. Both of those systems have a primary coil that produces the current surge (which has a voltage spike) when its current flow is interrupted, and the collapsing magnetic field produces the huge spike in the secondary coil for use at the spark plug. The argument re current vs. voltage is a little like Bernoulli's vs. Newton's theories of lift. They're both right, but they address different aspects of the phenomenon. Dan |
Similar Threads | ||||
Lightweight Starter for Sale! | Tom Enterline | Home Built | 0 | July 4th 05 09:25 PM |
Stumped by new starter | Jim Burns | Owning | 16 | January 13th 05 03:42 PM |
Starter Questions | Aaron Coolidge | Owning | 4 | June 30th 04 02:52 PM |
Stuck starter solenoid? | Paul Lee | Home Built | 4 | April 16th 04 02:58 PM |
Starter selection -- seeking input | [email protected] | Owning | 3 | April 5th 04 12:43 AM |
