FAA AND BUSH BS PUBLIC OVER MILITARY AIR ROUTES
By now the last scraps of turkey have been gobbled up, the travelers are back in their home towns, and the President and the FAA spokesflack of the moment should be getting ready to saunter up to the microphones and declare "Mission Accomplished" with their hokey holiday reroute game. Forget for a moment that the military turns these routes over to the FAA every heavy traffic holiday, and always has, rendering the Decider Guy's announcement a sort of, "Sun Comes Up In The East!" affair...here's a field perspective and the idiotic back-story to the FAA's latest shell game, the over-water express routes for LGA and other East Coast departures for Thanksgiving and Christmas. Let's call it "Hide The Airplanes In Military Airspace, No-One Will Think To Look There!" About a week ago an East Coast automation manager was called into the air traffic manager's office for a "briefing." With about seven day's notice (enroute automation is updated on a near-monthly schedule) he was told to implement the President's turkey of an idea...new express routes. Since it was far too late to make the NAS software recognize new routes, assign them and process them correctly (hey, it's not like we KNEW when Thanksgiving was coming or anything), the best that could be done is draw the routes on the video map. And draw them they did. But drawing lines on a map, or dictating that airplanes will get a straight shot after departure, won't fix the congestion problem in the air any more than hub-and-spoke will let us solve the problem on the ground. Here's why. When a flight plan hits the NAS, it's taken apart by the software in order to assign the right preferred route. These new routes aren't adapted into NAS so they won't be assigned by that center...ZNY for instance. Instead, the standard routes we've been using for years will be assigned and either LGA or ZNY departure pit controllers will have to re-assign them manually, using the override (splat) in the route of flight. Oops, overriding NAS preferred routing wrecks havoc with processing. Which enroute sector will the new departure flash to at? Who will get flight plan information? Who knows?!? So now the airplane is in the air, headed out to sea. Are the pilots over-water qualified? Why would they put over-water qualified crews, or overwater equipment for that matter, on the LGA-RDU run? Or any of the others coming out of the NY airports, destined for domestic airports well inland? If they're not qualified, they won't accept the new route. What percentage of flights will be exempt from the new routes on this count? Hmm, lots of RJs running those routes. This isn't looking like such a good idea anymore. And hey, they're really packing onto those routes. They don't all fly at the same airspeed, so what kind of in-trail spacing will the Command Center impose to keep this on an even keel? How much work will the enroute guys have to do to keep that spacing? Wouldn't they have to do the same work on the old routes? And here's the real kicker: At some point these flights HAVE TO MERGE BACK ON TO THE OLD ROUTES in order to hit an arrival route transition fix into the approach control airspace. That's where all the airplanes they DIDN'T move merge with those they DID, airplanes that would likely already be separated if they had left well enough alone in the first place. Increased workload, increased risk, great photo op. Now you're on the ground...but it's a HUB-TIME traffic jam. New routes didn't help that. Just like GPS hasn't solved that. Just like Reduced Vertical Separation Minima didn't solve that. Just like ADS-B won't solve that. More planes may or may not get in the air. Whoopee. That's like saying more and more people will get through Best Buy on the morning after Thanksgiving if you keep the same number of registers open but add four hundred parking spaces. Duh. All you've done is increase the pressure on an already overtaxed ground infrastructure. Here's a funny thing: we've been here before. During the Clinton administration. On the evening news we saw the president before the cameras in the Rose Garden telling us that a new set of routes, which we later referred to as "VS routes," were being implemented to re-route traffic over the Atlantic when thunderstorms encroached on the east coast. Five parallel "airways" running over the water, through military airspace. They were news to us; we're accustomed to getting our work requirements from the air traffic folks, not the president. But hey, we implemented it right down to sector airspace re-assignments and video map updates. They rarely used them. Why? All the reasons above. Mostly because the airlines couldn't guarantee that east coast departure airplanes and crews would be over-water qualified on the small chance they might have to fly those VS routes. Eventually we did all the work again to undo what had been implemented. Apparently the Bush administration has run out of ideas and they're using the Clinton playbook. Jeez, I'd love to hear Brian Williams broadcast THAT! Hang in there guys, we re-built the system after 1981 and we'll do it again after the Bush-Blakey-Sturgell Era of Incompetence And Failure is over. There are solutions that can incrementally increase safety, efficiency, airport throughput and decrease flight times and congestion. And eventually one of these idiots is going to ask the people who actually have the answers how to fix the problem. Until then? Remain calm, and remain in the breakroom, calculating your TSP and your retirement date. |
| Thread Tools | |
| Display Modes | |
| Bush administration finalizes military attack on Iran | [email protected] | Naval Aviation | 11 | January 5th 06 10:38 AM |
| Bush is ashamed of what was written in his military records | WalterM140 | Military Aviation | 0 | August 13th 04 12:49 AM |
| So Who Has More Military Command Experience, Bush Or Kerry? | W. D. Allen Sr. | Military Aviation | 11 | April 22nd 04 02:27 AM |
| So Who Has More Military Command Experience, Bush Or Kerry? | W. D. Allen Sr. | Naval Aviation | 11 | April 19th 04 06:12 PM |
| Military Slow Routes | R22AV8R | Rotorcraft | 0 | April 17th 04 02:51 AM |
