Can hydraulic lifters cause inadequate full power?
Old October 13th 08, 06:31 PM posted to rec.aviation.owning
Default Can hydraulic lifters cause inadequate full power?
On Oct 12, 8:03 pm, wrote:
We've put new points and condensers in both, including internally (and
of course externally) timing them. No change. I've done full-power mag checks
and misfires would be apparent in that case. New plugs make no change, either.
One other possibility: A bad plug lead or two. They can be open
(arcing internally) or shorted (arcing to the coax). They often won't
show up on mag checks but will, like a bad resistor in a plug, cause
some roughness if trhe mags aren't timed pretty close together. The
firing of the early mag can create enough pressure rise that the
second has trouble firing its plugs. I would doubt that yours are that
far apart.
: If the carb is a Marvel Schebler/Precision Airmotive unit, have
: the ADs been done with regard to the two-piece venturi and fuel
: nozzle?
Venturi AD's checked and CW. Restriction or mixture would show up as low
MP or abnormal EGTs anyway, no? Neither is the present.
The two-piece venturi had the risk of losing its secondary
venturi into the engine. The AD-mandated one-piece has squared-off
support arms that disrupt airflow around the nozzle and a second AD
required a new nozzle to try to fix this. The new nozzle made things
worse on some engines, so a third AD allowed the reinstallation of the
old venturis and nozzles, to be checked every 100 hours for looseness.
Except that Precision had recalled all the old parts and crunched
them. I know of one rebuilder that dresses the secondary support arms
and achieves better running. EGTs won't show anything, since it's
random turbulence around the venturi that screws up the atomization.
My 60-year-old Bendix/Stromberg is a better carb than any of
these MA-3s or -4s. What does all the money get us? Maybe Tempest will
fix these problems. They've purchased the carb line from Precision.
Dan
Old October 22nd 08, 08:42 PM posted to rec.aviation.owning
On Oct 12, 9:03*pm, wrote:
* * * * We've put new points and condensers in both, including internally (and
of course externally) timing them. *No change. *I've done full-power mag checks
and misfires would be apparent in that case. *New plugs make no change, either.
Advance the static spark timing on both mags by a degree or two more
than where it's sitting at now (e.g. 26 or 27 deg BTC instead of 25
deg) and see if that makes a noticeable improvement on static RPM and
takeoff power.
Old October 23rd 08, 06:42 PM posted to rec.aviation.owning
: On Oct 12, 9:03??pm, wrote:
: ?? ?? ?? ?? We've put new points and condensers in both, including internally (and
: of course externally) timing them. ??No change. ??I've done full-power mag checks
: and misfires would be apparent in that case. ??New plugs make no change, either.
: Advance the static spark timing on both mags by a degree or two more
: than where it's sitting at now (e.g. 26 or 27 deg BTC instead of 25
: deg) and see if that makes a noticeable improvement on static RPM and
: takeoff power.
What would that tell me, aside from that it makes more power when you reduce the detonation
margin and violate the TC for the engine? I run autofuel often, so advancing the timing isn't a safe
(or legal) option. It should be able to make the power at book timing.
-Cory
* Cory Papenfuss, Ph.D. Electrical Engineering, PPSEL-IA *
* Research Associate, Vibrations and Acoustics Laboratory *
* Mechanical Engineering *
Old October 23rd 08, 07:40 PM posted to rec.aviation.owning
nrp
Obviously you have checked the tachometer for accuracy by now. I
agree you should not have to go out of spec with the ignition timing,
but at least make sure it is set on the slightly high side (i. e. up
to the + 1/2 degree from spec. And you should at least witness (or
do) the timing check.
My O-320 seemed very sensitive to seemingly minor timing variances.
BTW make sure the 180 degree timing is correct too - just in case your
mag ignition point cam is not symmetrical.
Hydraulic Pump [email protected] General Aviation 2 March 28th 06 05:09 AM
Power setting table and best economy/best power... xerj Piloting 29 October 20th 05 02:44 AM
Heavy lifters... Darrel Toepfer Rotorcraft 2 August 13th 05 10:20 PM
wanted-Melling part number 29840 solid lifters-Chevy V-8 [email protected] Home Built 1 March 9th 05 03:52 AM
Radio protocol regarding full stops on full stop only nights Ben Hallert Piloting 33 February 9th 05 07:52 PM
