hlink.net... What's Caidin's track record? Mr. Gustin: His writing "never let the facts get in the way of a good story." He wrote a lot of books, always giving far more attention to being entertaining than to accuracy. That, of course, is not so harmful where his numerous works of fiction are concerned; his works of history however... Caidin's works are spreading and perpetuating more aviation history myths and errors than those of any other author, of course also because they were so widely sold. You can expound on the above as you see fit. So far, you've provided no facts, just gossip. Let's deal with this B-17/FW-190 collision story that you found so hard to swallow. This B-17 was named "TS". Caidin wrote: "Coming back from bombing an airdrome on July 14th, a Fortress met a nose attack by three FW-190's with a blast of fire that destroyed two of the fighters and evidently killed the pilot of the third. It crashed head on into the number three engine of the Fortress with an impact that that tore off the propeller and knocked the bomber completely out of formation. The German fighter did a cartwheel over the Fortress, cutting halfway through the wing and a third of the way through the horizontal stabliizer. Top and ball turrets on the bomber jammed, radio equipment was smashed; all the instruments, according to the co-pilot, 'went crazy'. Pieces of the metal from the disintegrating Focke-Wulf hurtled through the fuselage. A gun barrel burried itself in the wall between the radio room and the bomb bay. Other crews in the formation later reported that the Fortress had blown up as a result of the collision. It had not. On the contrary, it pulled itself together, shot down one more fighter, limped back under a canopy of sympathetic P-47's, and made a belly landing at an English base. None of the crew was scratched." -- "Flying Forts" pp 393-94, by Martin Caidin Now let's compare that to another source: "As "TS" was making her turn off the target, Lt. Weniger called in a pair of FW-190's who were climbing at full rate on a parallel course, and when far enough ahead reversing their course to make what he later described as a "balls to the wall" forward pass. The ensuing events are best related in his own words: "Prior to coming into range you could see their wings belching fire. All our gunner were firing at max rate, but they kept on coming. At this point I knew we were in for a real problem. The lead fighter rolled to the left and Split S down some four or five lengths ahead of us. Sgt. Tucker (BT) shouted out ' He almost took my guns with him!' The wingman to the right was either dead or damned mad at us for bombing his airfield when he also rolled left for a split S. His aircraft was perpendicular when he crashed into us between the number 3 engine and the fuselage. His nose section and propeller became unglued and departed over the top of number 4, cutting a deep gash in the nacelle top whch immediately poured forth a a big black stream of oil resembling a Texas oil gusher into the air. The crashing Fw. continued on down the fuselage, embedding one of his 20MM guns in our bomb bay and part of his fuselage lodged in our aircraft...Sgt. Budzik (RWG) was holding his gun when the Fw hit the barrel. He repoted the shock was so great that it threw him to the floor. The Fw's progress knocked the dorsal fin out of alignment and heavily damaged the right horizontal stabilizer....the FW left the scene in an un-controlled cartwheel -- that's the hard way to knock down one of Jerry's fighters, and is not recommended for longevity for bomber crews! Due to the impact "TS" was in a dead stall. Acting on reflex, Eddie and I rammed the yokes forward to their full extent and pushed the throttles forward for maximum power. Then it was time for a little prayer to see if TS would would either fly or fall off on one wing into an irretrieveable stall or spin...As the group began to fade into the distance and we were letting down at 500 ft a minute to maintain flying speed, 'Smitty' (Lt. Marvin Smith, naviagtor) came up from below to report that all was okay and that the nearest base was Manston. We could see the Channel when to our surprise and bad luck we flew over a flak battery, and big black smoke-puffs appeared all 'round. We received a number of hits, happily none direct; evasive action was very limited due to TS' condition. After running out of range (we later counted over 1000 holes in TS) we were sure nothing else could happen, although we were flying on a wing and a prayer.. In this we were soon proved wrong! O'Donnell, on hs second return from the rear, called in German fighters. When asked if he thought they would attack the question was answered a moment later when a 20MM exploded under Eddie's seat." -- "Ridgewell's Flying Fortresses" pp. 29-30 by Ron Mackay I don't see anything that contradicts what Caidin wrote, although there is no mention of kills by the pilot. In fact, the story is even more amazing that Caidin let on. But I think the onus in on Mr. Gustin to substantiate his claims or apolgize. And the serial. number on "TS" was 23211 I do have a picture of TS and I'll post the URL later. Walt |
Now that's what I call a fun mission. (sheesh)
Art, I'd suggest that colliding with an FW-190 at a closing speed of 450-500 MPH can ruin your whole day. Of course so can colliding with a B-17. What prompted me to mention this incident that so raised Mr. Gustin's ire was a thread in which the durability of the Lancaster was being put forward. After I posted TS' story, that thread sort of died out. Walt Walt |
Subject: Mr. Gustin, Mr Caidin, and B-17's
From: (WalterM140) Date: 4/16/04 7:31 PM Pacific Daylight Time Message-id: Now that's what I call a fun mission. (sheesh) Art, I'd suggest that colliding with an FW-190 at a closing speed of 450-500 MPH can ruin your whole day. .. But that still leaves the whole evening right? Arthur Kramer 344th BG 494th BS England, France, Belgium, Holland, Germany Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
I wrote:
But I think the onus in on Mr. Gustin to substantiate his claims or apolgize. I see nothing to apologize for. I do. Near as I can tell, Caidin got it right on. A B-17 survived a head on collision with an FW-190. Note that two Fw 190s have become three in Caidin's story, that Lt. Weniger makes no mention of Caidin's "blast of fire that destroyed two of the fighters and evidently killed the pilot of the third." Lt. Weniger says the gunners were firing at "max rate." He neither confirms nor denies any kills. The picture of "TS" on the URL I have provided shows 4 kills. You haven't -refuted- what Caidin said at all. And unless you can find a source that flatly states that the gunners on "TS" made no claims, you won't. Here's the URL: http://members.aol.com/walterm140/harrisb17ts.jpg Now, anyone who checks the URL will see that the prop was ripped off the B-17 just as Caidin said. Lt. Weniger says that the engine of the FW departed over the top of the # 4 engine. The # 3 engine was heavily involved, as the photo on my URL will show. There are numerous examples of Caidin's unreliability as a historical source... His rendering of the "Italian P-38" story, Show it. You sure missed the boat on the B-17/FW-190 collision story. his flawed account of the development of the Bf 109 Show it. his acceptance of the claim by a colorful American ex-mercenary that he had once fought an arranged dogfight with Bruno Mussolini, and so on and on and on... Show it. Check the archives for this newsgroup, you will find plenty of examples. No, it's your assertion. You show it. In summary, I still say: You can't use Caidin's writing in evidence, even anecdotal evidence, if you don't find a more reliable source to back it up; or, more likely, to correct it. It didn't take me long to corroborate Caidin's story re the B-17/FW-190 collision. He did give a date: 7/14/43. I found reference to this in Freeman's "Mighty Eighth War Diary." Hell, I even found a picture of the B-17 in question! Now it's your turn. I don't suggest that Caidin was correct in the Italian P-38 story, or any of the others you name. I don't have enough data. But I know as sure as little green apples that YOU were wrong in doubting that a B-17 did survive a head-on collision with an FW-190. And Martin Caidin was right. And the serial. number on "TS" was 23211 I suppose that must be 42-3211. I havent't yet found any information on it. Luckily for you, you can see a picture of the aircraft on the URL I've provided. The serial number is clearly visible in the photo. Lt Ed Manchester, the "Eddie" of Lt. Weniger's story, is second from left. He was the pilot. The photo was taken 7/15/43. This photo is from "Ridgewell's Flying Fortresses" by Ron Mackay. Walt |
I wrote:
I do. Near as I can tell, Caidin got it right on. A B-17 survived a head on collision with an FW-190. Mr. Gustin: 1. If Caidin (who, probably, was a far more intelligent and rational person than you) had just written that a B-17 survived a collision with a German fighter, I would not necessarily have expressed much doubt; although I would *still* have insisted on a better source. Head-on attacks were frequent; the risk of collision high; and the possibility that a B-17 would survive the collision could certainly not be excluded, on condition that the fighter hit the bomber with its wings, not its fuselage, which would probably send it cartwheeling over the B-17, which is what seems to have happened on this occasion. Well, this FW hit the B-17 with enough force to separate it from its engine. That's a lot of force. I have certainly seen enough evidence to know that Caidin was very often fast and loose with the facts. I hadn't known that before, I'm glad to know it now. The story about the Italian P-38 was especially distorted. I appreciate you bringing all this to my attention, really. On the other hand, the only discrepancy I've seen conclusively in the collision story is that Caidin says three fighters, Lt. Weniger indcates only two. Some FW's could have been shot down by "TS's" gunners. Weniger doesn't say. Walt |
In summary, I still say: You can't use Caidin's writing in evidence, even anecdotal evidence, if you don't find a more reliable source to back it up; or, more likely, to correct it. I agree with that statement - Caidin did most of his writing in the hayday of postwar aviation writing, before any archives had opened up to help sort the facts from the "really neat stories". Have a read through his various B-17 books and see how many times he mentions UFOs! Funny how those stories aren't mentioned in other books about the same events. I *loved* Caidin's books - but I agree with Mr. Gustin in this regard, MC just plain loved a good story, even if he couldn't provide backup information. Saburo Sakai wouldn't autograph Caidin's first version of his biography, for accuracy reasons. And the serial. number on "TS" was 23211 As EM pointed out, that's not an accurate serial number for any B-17. v/r Gordon ====(A+C==== USN SAR Its always better to lose AN engine, than THE engine. |
As EM pointed out, that's not an accurate serial number for any B-17. That is the serial number as it appears both in the photo I have of the aircraft and also the way it is recorded in the unit history of the 381st BG. That's why I reported it the way I did. But you are correct in that it is not a complete S/N. Walt |
| Thread Tools | |
| Display Modes | |
