Apart from the Quickie group of planes why aren't there more fast
biplanes? The quickies aren't exactly biplanes I know. It would appear that 2 short wings can be built lighter than one long one since the moment arm is half as long for the shorter wing pair. No struts used because of drag, just short cantilever wings. You'd have a more compact airplane that way with less weight that had the same drag as an equal wing area monoplane. |
Jay wrote:
It would appear that 2 short wings can be built lighter than one long one since the moment arm is half as long for the shorter wing pair. There are a lot of benefits to higher aspect ratio wings that far outweigh the structural advantage of low AR wings. Reduced drag is but one. Ever wonder why you don't see any biplane sailplanes? You'd have a more compact airplane that way with less weight that had the same drag as an equal wing area monoplane. 'Fast' and 'biplane' just don't go together. Fast "biplanes"(*) like the Quickie, Mong, etc. do not get their speed and low drag from the fact that they have two wings, but rather in spite of it. Induced drag decreases as aspect ratio increases, so a longer span wing of equivalent area and wing section will have less induced drag than two wings with a lower AR. Two wings will also have at least double the interference drag of one, regardless of whether or not they use interplane struts. Dave 'dragster' Hyde (*) Jay has already stated that he knows the Quickie is not a true biplane. The same principles apply, however. |
Dave Hyde wrote in message
There are a lot of benefits to higher aspect ratio wings that far outweigh the structural advantage of low AR wings. Reduced drag is but one. Ever wonder why you don't see any biplane sailplanes? You bring up a good point about sailplane wings having the best L/D ratios. But why not take each of those sailplane wings and put one over the top of the other? You mentioned the interference drag, so how far do wings need to be vertically separated for a given airfoil and stagger for this effect to be negligable? The fact that you don't see something commonly done says more about the methods of development starting with what currently works, and trying to make incremental improvement on it than anything else. Sometimes the rat maze requires the rats (RAH) to back up and choose another path, which in the short term means he is actually retreating from the cheese (speed). |
Jay wrote:
You bring up a good point about sailplane wings having the best L/D ratios. But why not take each of those sailplane wings and put one over the top of the other? Because a single wing of equivalent area but longer span will be more efficient in terms of drag. Biplanes are a simple, but inefficient, way of getting more lift from wing area when an increase in span is not feasible. The are not, nor in general are they intended to be, "low drag." You mentioned the interference drag, so how far do wings need to be vertically separated for a given airfoil and stagger for this effect to be negligable? *negligible?* Some *large* fraction of the span. At a minimum. Some airplanes are able to use the interaction for benefit, but it's usually for things like lift improvement at high AOA. Drag reduction requires doing things at the tips to make the wings 'think' they are longer and thus have a higher AR. Just slapping another wing on there ain't gonna do it. Sometimes the rat maze requires the rats (RAH) to back up and choose another path, which in the short term means he is actually retreating from the cheese (speed). And knowing where to depart from the maze requires either a foundation in basic principles or blind luck. Given the well- known relationship between drag and aspect ratio, these principles lead most people *away from*, not *to* biplanes for drag reduction. How 'bout a challenge: I can show you mathematically and using physical relationships why (without aerodynamic treatments like winglets or conjoined wings) two wings will produce more drag than a single wing of equivalent area but higher aspect ratio. Your challenge: Prove the physics wrong. Show how a second wing will result in less drag. Show me the math. Dave 'usenet wind tunnel' Hyde |
In article , Dave Hyde says...
Don't bet any big money cause Dave (usenet wind tunnel) Hyde is right. Just think, if he was wrong we'd be seeing Biplane Boeing 777's,these guys spend millions to get a couple percent increased efficiency on their transports. Better believe if a biplane was more efficient they'd be doing it. No if's, ands, or buts. :-) Chuck(Lewis 10X10 wind tunnel) S How 'bout a challenge: I can show you mathematically and using physical relationships why (without aerodynamic treatments like winglets or conjoined wings) two wings will produce more drag than a single wing of equivalent area but higher aspect ratio. Your challenge: Prove the physics wrong. Show how a second wing will result in less drag. Show me the math. Dave 'usenet wind tunnel' Hyde |
Dave Hyde wrote in message ...
Thanks for taking the time to make insightful comments on the discussion. Because a single wing of equivalent area but longer span will be more efficient in terms of drag. Biplanes are a simple, but inefficient, way of getting more lift from wing area when an increase in span is not feasible. The are not, nor in general are they intended to be, "low drag." You must understand that when I say "biplane" I'm not talking about a Jenny or Spad, I just mean an airplane that meets the requirement of having 2 lifting surfaces. I understand those early designs were optimized for the heavy powerplants and weak construction materials of the era, and had high drag wings that developed a lot of lift at low speeds. *negligible?* Some *large* fraction of the span. At a minimum. Some airplanes are able to use the interaction for benefit, but it's usually for things like lift improvement at high AOA. Drag reduction requires doing things at the tips to make the wings 'think' they are longer and thus have a higher AR. Just slapping another wing on there ain't gonna do it. Okay, I think you nailed the departure of my logic from yours. I don't believe that span is in the formula (at least not in high order). I think its a function of the airfoil dimensions (chord, thinkness, shape) and stagger. I do realize that near the fusalage/tip there is disturbance but this diminishes as you move away on the span. Imagine that you're an air molecule; how do you know if you're 5' or 10' along the wing? You don't, when the wing comes along, you just move along the bottom or zip across the top. I know that the rule of thumb is higher aspect, higher efficiency (L/D), but this is only part of the story. That rule makes an assumption of a single wing. That is to say, assuming you only have a single wing, and you need to decide how you can distribute your square feet of area, you'd pick a long skinny wing. And knowing where to depart from the maze requires either a foundation in basic principles or blind luck. Given the well- known relationship between drag and aspect ratio, these principles lead most people *away from*, not *to* biplanes for drag reduction. Thats the problem with rules of thumb, often the people using them forget the assumptions that went into the rule. How 'bout a challenge: I can show you mathematically and using physical relationships why (without aerodynamic treatments like winglets or conjoined wings) two wings will produce more drag than a single wing of equivalent area but higher aspect ratio. Your challenge: Prove the physics wrong. Show how a second wing will result in less drag. Show me the math. That sounds like a fun challenge. I think we're going to have to speak in realtionships instead of mathematic expression because we're using the usenet as our white board. Okay, why don't you start off by showing me how span comes into the relationship of air moving over a wing's airfoil. Dave 'usenet wind tunnel' Hyde There was someone that commented that if 2 lifting surfaces made sense, you'd see the 777 with 2 wings because they're Boeing and have lots of money and super human engineers. I've worked for lots of companies like Boeing (but not them because they tried to low ball me) and they're made up of regular guys like you and me. Many of them have interests and responsibility outside of designing the best aircraft ever, and really just want to pay their bills and go home and have a beer. You work as one guy in a huge machine where decisions are often made on what's politicaly the best answer rather than what's technically best. You get one tiny componant of this huge project. These kinds of organizations often punish risk taking in that there is no upside pay-off if you're right. But if you're wrong, and it was because you did something different than before, you get hammered. So the larger the project, the more conservative the approach tends to be. Remember, bean counters hate risk of any kind. |
you're 5' or 10' along the wing? You don't, when the wing comes along, you just move along the bottom or zip across the top. Those molecules are smarter than you might expect. G There can be significant spanwise flow of the air. Like most things in nature air finds the path of least resistance and sometimes this is not where it was headed when the wing bounced into it. Even if you take the same 40 ft high aspect ratio wing, saw it into 2 halves and manage to attach it to the fuselage with no increase in interference drag it's going to be less efficient than the 1 long wing - because of the spanwise flow. Winglets help, flow fences help, joined wing tips help, elliptical planform helps. Look up W. Kaspar and his work on tip vortices. |
Earlier, (Jay) wrote:
Okay, why don't you start off by showing me how span comes into the relationship of air moving over a wing's airfoil. That's generally covered in what they call "Theory of Finite Wings." There's a chapter on it in Abbott and Doenhoff. This Desktop Aero page is a good introduction to the topic: http://www.desktopaero.com/appliedae...ingmodels.html Bob K. |
Jay wrote:
Okay, I think you nailed the departure of my logic from yours. I don't believe that span is in the formula (at least not in high order). The generally accepted definition of the induced drag coefficient is: CDi=CL^2/pi/e/AR, where CL is the wing lift coefficient at the conditions under consideration, pi=3.14159... e = Oswald's efficiency factor (typically 0.8 or so) AR = aspect ratio The _definition_ of aspect ratio is chord/span, or span^2/aero (they're equivalent), so as area remains the same but aspect ratio increases, induced drag decreases by 1/span^2. That's what I call a primary effector. If you add wing treatments like winglets, fences, etc, you can increase the effective AR, but the big effects are gained by working at the tips, not across the span, as another wing typically does. Look at the lift side. The formula becomes messier, but for a finite wing: CL,finite ~= CL,infinite*(1/(1+(dCL,inf/daoa)/pi/AR)) As span increases through increased aspect ratio, the finite wing lift coefficient gets closer to the infinite wing CL. Can we agree that this is a good thing? In the lift case, there is *some* easily realizable benefit. A forward surface like a canard can be used as a big vortex generator to keep flow attached over the 'main wing' and increase lift/delay stall. That's why you see a lot of close-coupled canards on fighters these days. There's also the trim drag benefit of another surface if that surface can be configured to reduce the total downforce required to trim. That's another reason for canards and relaxed stability airliners. This benefit is usually not as pronounced as the high AR benefit. Imagine that you're an air molecule; how do you know if you're 5' or 10' along the wing? You don't, when the wing comes along, you just move along the bottom or zip across the top. Um...you might want to review some finite wing theory. There can be quite a bit of spanwise flow at the root _or_ the tip. When subsonic you make a bow wake. The air is moving before you hit it, and it's not just front-to-back. I know that the rule of thumb is higher aspect, higher efficiency (L/D), but this is only part of the story. That rule makes an assumption of a single wing. That's not a rule of thumb, that's physics. All other things being equal, the highger AR wing *will* have less drag. Okay, why don't you start off by showing me how span comes into the relationship of air moving over a wing's airfoil. Done and done. Your turn. I've worked for lots of companies like Boeing... Have you ever worked in conceptual design and/or aerodynamics? Most of your risk aversion comments were way off the mark. A trip to the Air Force museum to see the Bird of Prey or the X-36 could be illuminating. Dave 'misconceptual design' Hyde |
| Looking for a fast light plane | Dave lentle | Home Built | 2 | August 6th 03 04:41 AM |
| Glass Goose | Dr Bach | Home Built | 1 | August 3rd 03 06:51 AM |
