I've been trying to finish up an instrument rating in my 69 Arrow. I had
the check ride scheduled for this afternoon so thought a short final refresher with instructor yesterday would be a good idea. First approach, lowered the gear for descent, oooops, right main indicator still dark. Switch the bulbs, nope, same one. Flew by the tower, looked OK to them. Took it back home, landed fine, into the shop. The down indicator switch assembly is covered by a plastic housing, and the plastic eventually gets old and brittle and when asked to flex too many times eventually just broke the wire inside. So I'm going to replace the entire assembly and do the one on the left side as well - did the nose gear last year. It's a little nerve-wracking not knowing whether you're going to get that let-down feeling on touchdown. I'm concluding after a couple of years of ownership that buying an older airplane gives you the opportunity to replace every moving part one at a time. |
dutch wrote: I'm concluding after a couple of years of ownership that buying an older airplane gives you the opportunity to replace every moving part one at a time. There's a saying about motorcycles that if you maintain one yourself, you will eventually have two of them. George Patterson God grant me the senility to forget the people I never liked anyway, the good fortune to run into the ones I like, and the eyesight to tell the difference. |
Shoulda bought a 182. Same or more speed for less money.
dutch wrote: I've been trying to finish up an instrument rating in my 69 Arrow. I had the check ride scheduled for this afternoon so thought a short final refresher with instructor yesterday would be a good idea. First approach, lowered the gear for descent, oooops, right main indicator still dark. Switch the bulbs, nope, same one. Flew by the tower, looked OK to them. Took it back home, landed fine, into the shop. The down indicator switch assembly is covered by a plastic housing, and the plastic eventually gets old and brittle and when asked to flex too many times eventually just broke the wire inside. So I'm going to replace the entire assembly and do the one on the left side as well - did the nose gear last year. It's a little nerve-wracking not knowing whether you're going to get that let-down feeling on touchdown. I'm concluding after a couple of years of ownership that buying an older airplane gives you the opportunity to replace every moving part one at a time. |
In article . net, dutch wrote:
I'm concluding after a couple of years of ownership that buying an older airplane gives you the opportunity to replace every moving part one at a time. I disagree. Very often, I have to replace multiple moving parts at a time. Tina Marie (N3653P) -- http://www.tripacerdriver.com "...One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs." (Robert Firth) |
On 8-Oct-2003, "dutch" wrote: The down indicator switch assembly is covered by a plastic housing, and the plastic eventually gets old and brittle and when asked to flex too many times eventually just broke the wire inside. I had EXACTLY the same thing happen on our '79 Arrow, except it was the left main and it occurred while approaching Oshkosh during the big show! -- -Elliott Drucker |
On 8-Oct-2003, Newps wrote: Shoulda bought a 182. Same or more speed for less money. The 182 is a very fine airplane but you've got it reversed. The Arrow is typically a few knots faster, and for planes of comparable age, equipment, and condition the 182 will probably sell for thousands more. The 182 costs more to operate, too. Its engine is more expensive to overhaul, and the higher fuel costs for the 182 will usually more than offset the higher maintenance costs for the Arrow's landing gear. The planes actually have similar mission capabilities, but the more efficient Arrow will generally do it for somewhat lower cost at the expense of somewhat greater complexity. -- -Elliott Drucker |
airplane gives you the opportunity to replace every moving part one at a time. The trick is to find a good one that a previous owner has already gone through... -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
"dutch" wrote
The down indicator switch assembly is covered by a plastic housing, and the plastic eventually gets old and brittle and when asked to flex too many times eventually just broke the wire inside. So I'm going to replace the entire assembly and do the one on the left side as well Well, you can do that. Or you can splice in new wire in the area subject to flexing. If you have a cooperative A&P and are handy with tools, it's a simple procedure that will save you hundreds of dollars in one afternoon. Your call, but that's how I dealt with the same problem on my Twin Comanche. Still going strong after hundreds of cycles. I'm concluding after a couple of years of ownership that buying an older airplane gives you the opportunity to replace every moving part one at a time. Well, I would put it this way - unless you're going to do the maintenance yourself, you are not saving any money by buying an older complex airplane. Michael |
An airplane is like your grandfather's axe. Your father replaced the
handle, and you replaced the head, but it's still your grandfather's axe. "Michael" wrote in message m... "dutch" wrote The down indicator switch assembly is covered by a plastic housing, and the plastic eventually gets old and brittle and when asked to flex too many times eventually just broke the wire inside. So I'm going to replace the entire assembly and do the one on the left side as well Well, you can do that. Or you can splice in new wire in the area subject to flexing. If you have a cooperative A&P and are handy with tools, it's a simple procedure that will save you hundreds of dollars in one afternoon. Your call, but that's how I dealt with the same problem on my Twin Comanche. Still going strong after hundreds of cycles. I'm concluding after a couple of years of ownership that buying an older airplane gives you the opportunity to replace every moving part one at a time. Well, I would put it this way - unless you're going to do the maintenance yourself, you are not saving any money by buying an older complex airplane. Michael --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.524 / Virus Database: 321 - Release Date: 10/6/2003 |
| Thread Tools | |
| Display Modes | |
| I'm outta here | Richard Riley | Home Built | 0 | August 4th 03 06:15 PM |
